PWMPAL and BS2p problems
Recently I just got the PWMPAL and it works great on the BS2.
However running the same program on the BS2p doesnt work.
SEROUT 0, 6,[noparse][[/noparse]"!PWMM1", $6D, $00, $94, $02]
SEROUT 0, 6,[noparse][[/noparse]"!PWMM2", $6D, $00, $94, $02]
SEROUT 0, 6,[noparse][[/noparse]"!PWMM3", $6D, $00, $94, $02]
SEROUT 0, 6,[noparse][[/noparse]"!PWMM4", $6D, $00, $94, $02]
SEROUT 0, 6,[noparse][[/noparse]"!PWMSP", %00000000]
SEROUT 0, 6,[noparse][[/noparse]"!PWMSS", %11110000]
Any help would be appreciated. The BS2p check out fine on other
applications.
David
applications.
David
wrote:
> May be you did not change the baud rate
I tried several baud rates and nothing seemed to work. I dont know
if the BS2p and the PWMPAL are compabiable or not.
David
I am using a PWMPAL with a BS2P24 and 40 with no problems. Are you sure of
the baudrates? The BS2 uses a different table to determing baud rate codes,
are you sure you are using a P baudrate?
Jonathan
www.madlabs.info
Sent: Sunday, July 13, 2003 3:30 PM
Subject: [noparse][[/noparse]basicstamps] Re: PWMPAL and BS2p problems
> --- In basicstamps@yahoogroups.com, "acatano2002" <acatano2002@y...>
> David
6.
