PS2 20Mhz resonator not working?
MY PS2 has a strange problem, it works when connected a wire is
connected to the 9pin. I thought it was the RF linnk, but it does the
same thing when just mounted by itself on the test board. It will
accept and run prgrams when connected to a computer AND also when the
serial cable si left connected. Removing the serial cable but leaving
power on and the STAMP still works fine. If I then take pwoer off the
STAMP and repower it willnot function. Simply connecting to the serial
cable and plugging into a computer starts it up fine.
I tired to check if the resonator was working as it seemed like it
might be a touchy oscillator problem. What should I expect to see on
the controller chip pins 26 and 27 that go to the resonator? I have a
good HF scope but so far have found nothing active on these pins!! ?
Has anyone changed out the resonator succesfully and where did you get
it. ( part number etc please )
sorry for long post but if I make it too short I am often
mistunderstood).
ron
mistunderstood).
ron
or you may have a flaky ground.
Tie ATN to ground through 10Kohm resistor, to
guarantee a 'soft' 0 there, so you won't get
held in reset.
the
the
leaving
the
serial
on
a
get
> mistunderstood).
> ron
computer is on or off. It would seem that one of the 3 connections to
the serial 9 pin has to be connected to something to make this STAMP
work..I checked out the resonator and it works all the time. Any more
ideas welcomed..
ron
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> The ATN line (BS2 pin 3) may be floating HIGH,
> held in reset.
> the
> the
> leaving
> the
> serial
it
> on
have
> a
pins!!
you
> get
> > mistunderstood).
> > ron
>NIce idea but it made no difference..problem is the same if the
>ideas welcomed..
>ron
How is the Stamp being powered, from a wall wart, or a battery ?
Are you using a test board of your own design or one that was pre-built
and purchased ?
I'm beginning to wonder if there is a missing ground somewhere.
Bruce Bates
dev. board that Parallax supplies and the board in which it is used.
Either way the problem is the same. If I put a 1.5K from the SIN pin
2 on the STAMP2 ) to ground the STAMP will run normally. If this
resistor is removed the STAMP will run until either a reset or power
cycled, so it seems that the condition is marginal. The SIN goes to a
3904 NPN base , the collector goes to pin 7 or RX on the PIC
microcontroller chip. ( schematic from Parallax ). (BTW The 3904 and
micro are all part of the STAMP board. )
SInce I can get the STAMP to run I wondered if it would be OK to just
put the resistor in and leave it there. I would really like a
response
on this from an engineer at Parallax inc as it might be a dumb thing
to do and it mught indicate that the PIC chip is failing..
(btw The schematic shows SIN going to PIN3 of the 9pin connector and
is labelled Tx .. I am a bit confused as this line also controls the
NPN
transistor that goes RX on the pic... is this an error or what? )
to
STAMP
more
> >ideas welcomed..
> >ron
pre-built
> and purchased ?
> Bruce Bates
>( 2 on the STAMP2 ) to ground the STAMP will run normally.
Did you try the idea of connecting ATN to ground (either directly or
via a 1.5k resistor), to see if that would have the same effect as
the 1.5 K from SIN to ground? (ATN pin 4 on the DB9, pin 3 on the
BS2 carrier, via npn xistor to MCLR on the PIC)
>NPN
The pins on the DB9 connector are labeled from the point of view of
the PC, which is the DTE device (Data Terminal Equipment), and
transmits its data from pin 3 of its DB9. The Stamp carrier boards
are wired DCE (Data Communications Equipment) and expects to receive
data pin 3 of its DB9. The cable from DTE to DCE is straight thru,
pin 1 to pin 1 on up to pin 9 to pin 9. No crosses. The
convention is to label signals from the point of view of the DTE.
When the signal gets into the heart of the BS2, they call it Sin.
-- Tracy Allen
If at all possible, can you find someone in your area with a Stamp? See if
their Stamp will program without the resistor.
Good luck,
Jonathan
www.madlabs.info
Sent: Saturday, July 12, 2003 3:24 PM
Subject: [noparse][[/noparse]basicstamps] Re: PS2 20Mhz resonator not working?
> I have checked , the board makes no differecne as I have tried it the
> response
> NPN
> to
> STAMP
> more
> > >ideas welcomed..
> > >ron
> pre-built
> > and purchased ?
> > Bruce Bates
nothing. This is becauase the ATN does a RESET , it seems that the
problem is with the RX pin on PIC controller, the RESET seems to be
rock solid.
I live in Santa Barbara.. anyone live nearby that would loan me a
STAMP just be sure I am not crazy..
It seems that the PIC chip is bad or that the transistors on the STAMP
have failed. Can anyone give me some resistance figures for the pins
1,2 3 also pins 7 and 8 on the PIC to each other and to ground, on A
stamp ps2? I am going to try and look at the transistors on the STAMP
to see if they are OK. I think that they are as I can still program
the STAMP fine.
Anyone have a spare STAMP PS2 they want to sell?
3-- In basicstamps@yahoogroups.com, "Jonathan Peakall" <jpeakall@m...
> wrote:
> Rondoc,
See if
> Good luck,
> Jonathan
> www.madlabs.info
> From: "rondoc69" <rdoctors@c...>
the
used.
pin
power
to a
and
just
> > response
thing
and
the
> > NPN
connections
> > to
> > STAMP
Any
> > more
> > > >ideas welcomed..
> > > >ron
> > pre-built
> > > and purchased ?
> > > Bruce Bates
Subject and
com/info/terms/
without any resistors as long as plugged into the serial line. That is
why I was so confused, it would run fine on the bench then when I
disconnected it from the programming board and went to use it on the
main system it did nothing. The system is a solar tracking system that
is on the roof of an RV, so it a pain to keep plugging and unplugging
the STAMP. I have a 50 foot long serial cable but it so haevy that I
hate to use it.
I have now moved everything to the computer room so I can prgram the
STAMP in situ.. problem the same but easier to trouble shoot..
ron
--- In basicstamps@yahoogroups.com, "Jonathan Peakall" <jpeakall@m...>
wrote:
> Rondoc,
See if
> Good luck,
> Jonathan
> www.madlabs.info
the
used.
pin
power
to a
and
just
> > response
thing
and
the
> > NPN
connections
> > to
> > STAMP
Any
> > more
> > > >ideas welcomed..
> > > >ron
> > pre-built
> > > and purchased ?
> > > Bruce Bates
Subject and
com/info/terms/
-12 volt signal, which the BS2 then modulates
for its SOUT signal. This means every byte
sent to the BS2 comes back to the PC. However,
this lets the BS2 send 'true' 232 levels back
to the PC.
the
power
a
and
just
> response
thing
and
the
> NPN
connections
> to
> STAMP
> more
> > >ideas welcomed..
> > >ron
> pre-built
> > and purchased ?
> > Bruce Bates
