Real Time Clock Question
Any one know of a real time clock chip that has an output variable of less than
1 second?
i.e. tenths/hundredths etc...
And how realistic is it to be able to use this with a BS2?
I'm looking at a data logger running at ideally 20Hz sampling about a dozen
bytes...
Cheers very much all,
Kev/.
1 second?
bytes...
Kev/.
The PCF8385 will do the trick.
Down to 100th of a second timekeeping. Only catch is, it is I2C.
The BS2 does not have I2C built in, but you can easily "Bit Bash"
a solution.
Visit
http://www.lennard.net.nz/lennardelectronics/electronics/i2c.html
#rtc for an idea on how to use the chip. I think I used a BS2sx for
this example for some reason, but it also works OK on a BS2.
Of course, I'd actually use a BS2pe if I were you, esp if you are
serious on a Datalogging application. The BS2pe also has built
in I2C Commands, therefore no Bit Bashing required.
cheers,
Ben,
Windy (and friggin' cold) Wellington, NZ (winter has FINALLY
arrived!)
--- In basicstamps@yahoogroups.com, "Kev Pearce
variable of less than 1 second?
about a dozen bytes...
> Kev/.
The philips PCF8583 (I2C bus) has hundredth of seconds. With a Bs2P with its
builtin I2C commands
You should be able to read this device several times per second.
If seconds resolution is enough you can consider DS1207 (SPI) or DS1302
(I2C).
Also nice is a Xicor X1227 (I2C, seconds resolution, dual alarm, builtin 4K
eeprom,
1.75 seconds watchdog timer).
Regards peter
Oorspronkelijk bericht
Van: Kev Pearce (kevp.com) [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=L-sDuKwIsXDUs4hwu3k6n0TwzFnzECqE9f3bLWDauIsZ1aln_VE1tIDBAO3YXRT6GuWhAixWftgi-Lo]email.me@k...[/url
Verzonden: vrijdag 11 juli 2003 13:27
Aan: basicstamps@yahoogroups.com
Onderwerp: [noparse][[/noparse]basicstamps] Real Time Clock Question
than 1 second?
bytes...
Kev/.
own sort of communications. Closer to SPI with a bi-directional I/O pin
instead of MISO/MOSI.
The DS1307 is real I2C
Sent: Friday, July 11, 2003 6:55 AM
Subject: RE: [noparse][[/noparse]basicstamps] Real Time Clock Question
> Hi,
its
> (I2C).
4K
> eeprom,
> Regards peter
> Van: Kev Pearce (kevp.com) [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=oJJycOsNjypjDwF7tbZJOcL_alpkFPxbUsDpCk4fJ_NiG2eR1eBMwCadfnxJKxsCPvGpQ5F-yLoEeJ-c]email.me@k...[/url
> than 1 second?
dozen
> bytes...
> Kev/.
I took a look at the xicor website.
The X1286 offers hundredth of a seconds plus 256K of builtin eeprom (I2C
bus).
No watchdog timer. The X1288 includes a watchdog timer.
So Kev, you can have a single chip for both of your needs.
http://www.xicor.com/folders/X1288.php
regards peter
Van: pm [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=veyrJMzt5Exe1ahL4ONIXto-4GNC6N9VzcbGU51mCCuweKRpmmhus-6putbvWJ1rpN85GUWAAaHP]pmeloy@s...[/url
Verzonden: vrijdag 11 juli 2003 21:12
Onderwerp: Re: [noparse][[/noparse]basicstamps] Real Time Clock Question
Bit of a correction, the DS1302 isn't I2C, its three wire serial using its
> Hi,
its
> (I2C).
4K
> eeprom,
> Regards peter
> Van: Kev Pearce (kevp.com) [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2RGYSWR5oLJAwYkcg9xlf5_IZWXfAWDPKYZx8Y-uXSyDaWc5TJGvuR-TYcLRbz1X9Mdck9r22M5oag]email.me@k...[/url
> than 1 second?
dozen
> bytes...
> Kev/.
