Pressure sensor for water tank/should be level sensor
I'm trying to track down the article, all you need is a plastic sight
gauge to put the 2 foil strips on. That was one of the great features
of the design. I can't rmember if it was in the PIC section or the
Basic Stamp section, I know the article was before Jan 1997. I had the
article and used it for 2 different projects where I was working once
in the fall of 1997, and the other in 1998. My copy of it got lost
when a storage unitwnere I had a lot of reference material stored
developed a leaky roof.
Bill HIgdon
--- In basicstamps@yahoogroups.com, "rondoc69" <rdoctors@c...> wrote:
> HI IN a NUts and VOLts article on STAMPS there was a very neat
> external depth sensing system. You need a plastic tank as it used the
> capacitance change between the water and an external aluminum strip on
> the outside.
> rondoc
> amps@yahoogroups.com, "Jonathan Peakall" <jpeakall@m...> wrote:
> > Hi all,
> > A friend of mine wants to build a Stamp controller for his nifty
> home-made
> > water filtration system. The tank he has is 7 feet deep, and we
> would like
> > to be able to determine the water level within a foot or so. I am
> thinking
> > of a air type sensor with a tube from top to bottom of the tank. Any
> > recommendations? 0-5V output, or perhaps a resistive type.
> > Thanks!
> > Jonathan
> > www.madlabs.info
Bill HIgdon
> the outside.
> rondoc
> > Hi all,
> home-made
> would like
> thinking
> > Thanks!
> > Jonathan
> > www.madlabs.info
Hmm, sounds like it would work. I'll look into the N&V article, and please
let me know if you find it.
Jonathan
www.madlabs.info
Sent: Friday, July 11, 2003 1:20 AM
Subject: [noparse][[/noparse]basicstamps] Re: Pressure sensor for water tank/should be level
sensor
> Bill HIgdon
> > the outside.
> > rondoc
> > > Hi all,
> > home-made
> > would like
> > thinking
> > > Thanks!
> > > Jonathan
> > > www.madlabs.info
