Power Supply (newbie) question. — Parallax Forums
edited 2003-07-12 06:02 in General Discussion
The most likely to work in the short term is
to use a separate supply, WITH COMMON DC GROUNDS,
to drive each device.
It's likely the switching transient which is
pulling down VCC enough to reset the BS1. You
can maybe prevent this with a large capacitor
(100 uF) sitting close to the BS1, connected
to its +5 and GND leads. I'm assuming you
have read the 7805 docs, and have proper
capacitors on its input and outputs.
The most robust approach is to have one
supply whose purpose in life is to power
the BS1, and then another supply whose purpose
is to provide power to the motors and
solenoids, switched by the BS1 through
PNP (2n2222) transistors (or a ULN200x darlington
chip).
You definitely want some common ground reference
point for all power supplies used. This is all
low-voltage, TTL control stuff. Disconnected
grounds will give you wildly unpredictable
results.
--- In basicstamps@yahoogroups.com, Robert Rothe <rrothe@m...> wrote:
> I'm working on a BS-1 application to control some motors and
solenoids. I think I have a handle on the control portion of the
project (ie, relays, SSRs, etc). My question is 'how do you power
all this stuff easily?'
> The stamp is currently being run off of a wall-wart power supply
through a 7805. The motors draw a lot of current at bot 5 and 12
volts.
> I also have one solenoid that requires 24v AC 600ma. (which I'm
assuming I can probably run on 12 v DC).
> So, should I:
> a) try and find a wall-wart power supply that can deliver over 1
amp at 12V and just run the 12V through the 7085 for the stamp, too?
> b) Maybe use an old computer power supply since it can source 5 and
12 volts with higher currents? (I've googled this idea and think I
understand the "no-load" considerations)
> c) Use separate sources for each device? (ie, no common ground;
load devices controlled through either relays or SSRs)
> This problem came to light when I tried to run a 1.3v or 9v motor
though a relay controlled by the BS-1. I was trying to pull all the
power from the 7085 (or before the 7805 for the 9v loads) and the
stamp kept reseting when the motor was connected to the Normally Open
relay contact and the relay actived by the stamp. Oddly, it worked
OK on the Normally Closed contact. Lower current loads worked fine
on both, so I'm assuming I was overloading the 7805 or the power
supply. The DC power supply was a 12v 300ma or so radio shack
special. I don't know the exact amp rating on the small hobby motors.
> Any help and advice would be greatly appreciated. Cost is a
serious consideration. I'm new at this, so please type slow and
small :-)
> Rob
> [noparse][[/noparse]Non-text portions of this message have been removed]
    edited 2003-07-10 20:51
    In a message dated 7/10/2003 12:45:15 PM Pacific Daylight Time,
    allan.lane@h... writes:
    > chip).
    NPN (2n2222) - I am sure this was a simple mistake on your part, but for the
    "beginners" a 2n2222 is an NPN device
    > results.
    edited 2003-07-10 21:12
    Doh! Sorry about that.
    > > chip).
    but for the
    > > results.
    edited 2003-07-10 22:32
    --- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
    > > > chip).
    > but for the
    > > > results.
    edited 2003-07-10 22:33
    > > > chip).
    > but for the
    > > > results.
    edited 2003-07-10 23:27
    I'm working on a BS-1 application to control some motors and solenoids. I think
    I have a handle on the control portion of the project (ie, relays, SSRs, etc).
    My question is 'how do you power all this stuff easily?'
    The stamp is currently being run off of a wall-wart power supply through a 7805.
    The motors draw a lot of current at bot 5 and 12 volts.
    I also have one solenoid that requires 24v AC 600ma. (which I'm assuming I can
    So, should I:
    a) try and find a wall-wart power supply that can deliver over 1 amp at 12V and
    b) Maybe use an old computer power supply since it can source 5 and 12 volts
    with higher currents? (I've googled this idea and think I understand the
    c) Use separate sources for each device? (ie, no common ground; load devices
    This problem came to light when I tried to run a 1.3v or 9v motor though a relay
    controlled by the BS-1. I was trying to pull all the power from the 7085 (or
    before the 7805 for the 9v loads) and the stamp kept reseting when the motor was
    connected to the Normally Open relay contact and the relay actived by the stamp.
    Oddly, it worked OK on the Normally Closed contact. Lower current loads worked
    fine on both, so I'm assuming I was overloading the 7805 or the power supply.
    The DC power supply was a 12v 300ma or so radio shack special. I don't know the
    Any help and advice would be greatly appreciated. Cost is a serious
    consideration. I'm new at this, so please type slow and small :-)
    Rob
    edited 2003-07-11 01:37
    I knew what you meant, thanks. I'm still a little confused about the need
    for a common ground among power supplies that are isolated via a mechanical
    or solid state relay. Just to be clear, all the TTL stuff will be on a
    single supply.
    (sorry for the blank posts)
    Rob
    Sent: Thursday, July 10, 2003 2:32 PM
    Subject: [noparse][[/noparse]basicstamps] Re: Power Supply (newbie) question.
    > > > > chip).
    > > but for the
    > > > > results.
    edited 2003-07-11 03:11
    I'm not clear on some information here
    You mentioned a 24vac 600mA solenoid but didn't give any information about
    the relay thats resetting your stamp. What are its requirements? What are
    you switching it with (transistor, photorelay, ULN2x03?
    The stamp pins can only source a small amount of power (an led for example).
    If you're going directly to a relay pin then resetting the stamp is not only
    inevitable, its a godsend - t should burn the poor thing out!
    If not, what's between the stamp and the relay?
    Also, whats the stats on the motor? I have here a ST35 2v unipolar stepper
    motor that requires 60mA per winding. Right beside it is an AEG SO21 5v
    bipolar stepper that requires 625mA per winding. Even though the ST35 is
    over twice the voltage, my 300mA 12v wall wart drives it, my MCU. 4 leds and
    a ULN2803 with power to burn. The 5V motor would burn it out in no time.
    In other words, details man, details [noparse]:)[/noparse]
    Sent: Thursday, July 10, 2003 3:27 PM
    Subject: [noparse][[/noparse]basicstamps] Power Supply (newbie) question.
    think I have a handle on the control portion of the project (ie, relays,
    SSRs, etc). My question is 'how do you power all this stuff easily?'
    7805. The motors draw a lot of current at bot 5 and 12 volts.
    > So, should I:
    volts with higher currents? (I've googled this idea and think I understand
    relay controlled by the BS-1. I was trying to pull all the power from the
    7085 (or before the 7805 for the 9v loads) and the stamp kept reseting when
    the motor was connected to the Normally Open relay contact and the relay
    actived by the stamp. Oddly, it worked OK on the Normally Closed contact.
    Lower current loads worked fine on both, so I'm assuming I was overloading
    the 7805 or the power supply. The DC power supply was a 12v 300ma or so
    radio shack special. I don't know the exact amp rating on the small hobby
    motors.
    > Rob
    edited 2003-07-11 03:20
    I think he meant common ground for all the logic devices, not the motors
    etc. "ground" on a wall wart isn't ground - its the AC Neutral line. AC
    neutral isn't ground either, its midpoint between two phases of an AC wave.
    While normally pretty close to zero volt potential to "earth" ground, its
    almost never exactly zero.
    There should be a movement to eradicate the word "ground" from electronics.
    We should all have to call it "neutral" or be flogged!
    Well ok, maybe not flogged - but definately have the M&M sorter steal all
    the reds from any packs we buy.
    Sent: Thursday, July 10, 2003 5:37 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Re: Power Supply (newbie) question.
    mechanical
    > single supply.
    > Rob
    edited 2003-07-11 03:21
    Oops, thats 12V, not 2V...
    edited 2003-07-11 15:18
    From: pm [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Tf8_qS9AR335X0UBykeMyGOTk4o54ftceuArv_QWX_36jjj8wzyAQCvatlnd04xB7wKhoWin]pmeloy@s...[/url
    Sent: Thursday, July 10, 2003 7:12 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Power Supply (newbie) question.
    about the relay thats resetting your stamp. What are its requirements?
    What are you switching it with (transistor, photorelay, ULN2x03?
    example). If you're going directly to a relay pin then resetting the
    stamp is not only inevitable, its a godsend - t should burn the poor
    thing out!
    stepper motor that requires 60mA per winding. Right beside it is an AEG
    SO21 5v bipolar stepper that requires 625mA per winding. Even though the
    ST35 is over twice the voltage, my 300mA 12v wall wart drives it, my
    MCU. 4 leds and a ULN2803 with power to burn. The 5V motor would burn it
    out in no time.
    > solenoids. I
    > through a
    > assuming I
    > So, should I:
    > at
    > though a
    the 7085 (or before the 7805 for the 9v loads) and the stamp kept
    reseting when the motor was connected to the Normally Open relay contact
    and the relay actived by the stamp. Oddly, it worked OK on the Normally
    Closed contact. Lower current loads worked fine on both, so I'm assuming
    I was overloading the 7805 or the power supply. The DC power supply was
    a 12v 300ma or so radio shack special. I don't know the exact amp
    > Rob
    > and
    edited 2003-07-11 19:02
    Each mechanical relay is driven by the stamp through a transistor
    with a protecting diode as described in a few of the stamp app
    notes. In my tests, the relay is a radio shack SPDT 5V coil which
    can drive up to an amp at 120V. (base of transister goes to a stamp
    pin with an inline resistor; collector connected to the diode and
    the relay; other end of the relay/diode connected to the 7805
    regulated output, emitter to ground)
    The stamp is powered through the same wall-wart via a 7805 (with caps
    in place).
    Evenutally, I'll really be driving 12V geared DC motors (ie,
    windsheild wiper motors) and air/water solenoid valves. Some of the
    solenoids are 120V AC, so basically these are driven directly from a
    house line through a mechanical or solid state relay. The DC
    solenoids, however, will probably overwhelm most consumer wall-warts.
    So, I'd like to continue powering the stamp circuits and the coil
    side of the relays with a single, say, 12V supply. What would you
    all recommend to drive the DC loads?
    information about
    What are
    example).
    not only
    stepper
    SO21 5v
    ST35 is
    leds and
    time.
    > From: "Robert Rothe" <rrothe@m...>
    solenoids. I
    relays,
    easily?'
    through a
    assuming I
    > > So, should I:
    amp at
    and 12
    understand
    load
    though a
    from the
    reseting when
    relay
    contact.
    overloading
    or so
    small hobby
    > motors.
    serious
    > > Rob
    Subject and
    edited 2003-07-11 20:41
    Ah ok, you've got the important stuff down pat.
    One piece of information you keep neglecting to include, what is the
    coil-side current requirement of these relays? There will be two current
    ratings for a relay, one for the contacts (the motor side) and one for the
    coil.
    As an example, I have some JE1-DC12V relays here. The contacts are rated for
    120VAC @ 5Amps. The coil is 12v and requires 33mA to to hold open. I'm
    pretty rusty on DC coil characteristics, but I also believe that the initial
    current to switch the contacts is a fair bit higher than that required to
    keep them switched. Can't find that mentioned on my datasheet though.
    Anyway, no reason why you can't power all the DC stuff from a single wall
    wart. Just add up all your power requirements (include ALL the coils,
    whether or not you'll be switching them all at the same time) and choose a
    wall wart that has at least 25% more supply than you need. I've seen 12VDC
    2A bricks kicking around in the local electronics shops. If your current
    requirements are higher than you can find, nothing wrong with seperating the
    logic power from motor power.
    Sent: Friday, July 11, 2003 11:02 AM
    > in place).
    edited 2003-07-12 02:50
    This is great info, thanks.
    As for the coil currents, I can't find the data sheet on the 5v relay, but a
    12v model I have (and plan to use) says the "nominal" coil current is 30ma
    (with 400 ohm +/- 10% resistance). The drive side of the relay is rated at
    10A at 120VAC/24VDC. The relay's leads are a bit skimpy (PC style), but
    I'll work through that.
    I'll definately look around for a 12V 2amp supply. An old PC power supply
    surely fits this bill, too. But it is good to know I can separate them if
    needed.
    Thanks again for the info!
    Rob
    PS. Know of any place to scavenge some solid state relays? Are they used
    in any consumer quality items? They're pretty pricey new...
    Sent: Friday, July 11, 2003 12:41 PM
    > coil.
    for
    initial
    the
    > From: "rrothe64" <rrothe@m...>
    > > in place).
    Whats the model # of the 5v relay? I find google is pretty good for locating
    datasheets. just type the model number and "datasheet". dashes are usually a
    killer though, so if its DC5V-SOMETHING , try it with the dash, with a space
    instead of a dash, then with no space or dash.
    Seaching for the manufacturer helps quite often too [noparse]:)[/noparse]
    Sent: Friday, July 11, 2003 6:50 PM
    a
    at
    > needed.
    > Rob
    > From: "pm" <pmeloy@s...>
    the
    > > coil.
    > for
    > initial
    to
    wall
    a
    12VDC
    > the
    > > > in place).
    and
