Display SHT1x info on Parallel LCD
In trying to combine the SHT1x.BS2 program with the Basic LCD Demonstration
program (I know the SHT1x.BS2 program was written by Jon Williams, and I believe
the LCD Demo was also written by Jon)
I was trying to arrange it so the LCD would be controlled via pins 0 through 7,
and the SHT1x with pins 0 and 1. Although it is not specifically pointed out in
the syntax manual, anytime a statement with "XXXX CON 0" comes up, it
makes pin 0 an input/output pin. Of course that makes the two programs conflict
with each other. So.....what to do??? Anyone want to give me some advice
(other than "Don't bother me
with this trivial stuff!")
Kindest regards, Chuck Irwin
All you should have to do is designate the LCD cons to different pins, then
hook the SHT up using the pins you specified.
Jonathan
www.madlabs.info
Sent: Wednesday, July 09, 2003 5:01 PM
Subject: [noparse][[/noparse]basicstamps] Display SHT1x info on Parallel LCD
Demonstration program (I know the SHT1x.BS2 program was written by Jon
Williams, and I believe the LCD Demo was also written by Jon)
through 7, and the SHT1x with pins 0 and 1. Although it is not specifically
pointed out in the syntax manual, anytime a statement with "XXXX CON
0" comes up, it makes pin 0 an input/output pin. Of course that makes the
two programs conflict with each other. So.....what to do??? Anyone want to
give me some advice (other than "Don't bother me
I tried that but still had trouble with the LCD Program affecting
the SHT1x program. I rearranged things and put the LCD program on
pins 8-15 and that solved the problem. Now am waiting for the SHT1x
item from Parallax (They are back ordered until 7/15/03). I was
also able to get the temp and humidity displayed on the LCD. Not
elegant, but is working thanks to a bit of code from Jon Williams.
When it is finally working, I will post it here.
--- In basicstamps@yahoogroups.com, "Jonathan Peakall"
<jpeakall@m...> wrote:
> Chuck,
pins, then
> Jonathan
> www.madlabs.info
> From: "chuckirwin43" <chuckirwin43@n...>
Jon
pins 0
specifically
with "XXXX CON
makes the
Anyone want to
Subject and
