1-button/1-wire memory: sample code
All-
Is anyone out there in StampLand familiar with sample code for reading and
writing
to 1-button IC memory? I'm especially interested in sample code for Add-Only
memory, but anything will surely help.
-Mark
writing
-Mark
> reading and writing to 1-button IC memory? I'm especially
> interested in sample code for Add-Only memory...
Mark-
The following BS2p routines for the DS1985 16Kbit add-only EPROM
iButton ought to get you started.
Steve
'{$STAMP BS2p}
' DS1985 16 KBit Add Only iButton
' - for simplicity, SKIP ROM used throughout
' Universal 1-Wire ROM commands
READ_ROM CON $33
SKIP_ROM CON $CC
MATCH_ROM CON $55
SEARCH_ROM CON $F0
SEARCH_FUNC CON $EC
' I/O pin constants
BUS CON 15 ' 1-Wire bus
PROG_PULSE CON 14 ' programming pulse (active low--pullup!)
' OWIN, OWOUT constants
RESET_NONE CON 0
RESET_PRE CON 1
RESET_POST CON 2
RESET_BOTH CON 3
' conventional variables
memory_address VAR WORD
in_byte VAR BYTE(10)
i VAR BYTE
j VAR BYTE
' read ROM-based identifier...
' 1-Wire transactions summary:
' ---> [noparse][[/noparse]reset]
' ---> READ ROM
' <--- 8 Serial # identifier bytes
OWOUT BUS,RESET_PRE,[noparse][[/noparse]READ_ROM] ' send READ ROM
OWIN BUS,RESET_PRE,[noparse][[/noparse]STR in_byte\8] ' read 8-byte serial identifier
DEBUG CR,"Serial # "
FOR i = 7 TO 0 ' display identifier high order
DEBUG HEX2 in_byte(i) ' byte first
NEXT
' read and display last four bytes of memory...
' ---> SKIP ROM
' ---> READ MEMORY command
' ---> 2-byte memory address
' <--- 4 data bytes
' <--- 2 CRC bytes
memory_address = $7FC
OWOUT
BUS,RESET_PRE,[noparse][[/noparse]SKIP_ROM,$F0,memory_address.LOWBYTE,memory_address.HIGHBYTE]
OWIN BUS,RESET_NONE,[noparse][[/noparse]STR in_byte\6]
DEBUG CR,"DS1985 memory: "
FOR i = 0 TO 3 ' retrieve bytes read
DEBUG HEX2 in_byte(i)," "
NEXT
' do extended memory (EPROM) read...
' ---> SKIP ROM
' ---> EXTENDED MEMORY READ command
' <--- 1 address redirection byte
' <--- 2 CRC bytes
' <--- 32 data bytes
' <--- 2 more CRC bytes
memory_address = $7E0
OWOUT
BUS,RESET_PRE,[noparse][[/noparse]SKIP_ROM,$A5,memory_address.LOWBYTE,memory_address.HIGHBYTE]
OWIN BUS,RESET_NONE,[noparse][[/noparse]STR in_byte\3] ' get redirection and CRC bytes
DEBUG CR,"Redirection byte: ",HEX2 in_byte
DEBUG CR,"Extended memory data: "
FOR i = 0 TO 31
OWIN BUS,RESET_NONE,[noparse][[/noparse]in_byte]
DEBUG HEX2 in_byte," "
NEXT
' write $F8 to extended memory (EPROM) location $7FF:
' ---> SKIP ROM
' ---> EXTENDED MEMORY WRITE command
' ---> 1 data byte = $F8
' <--- 2 CRC bytes
' [noparse][[/noparse]12 volt programming pulse]
' <--- 1 data byte
memory_address = $7FF
OWOUT
BUS,RESET_PRE,[noparse][[/noparse]SKIP_ROM,$0F,memory_address.LOWBYTE,memory_address.HIGHBYTE,$F8]
PULSOUT PROG_PULSE,600 ' 480 usec / 0.8
DEBUG CR,"Readback of write: ",HEX2 in_byte
STOP
