Visual Basic interface Stamps
Hello all I have been doing extensive research on a VB interface to stamp I am
building a simple Driving simulator with 6 inputs need to take it into vb and
convert it using text1.text I was wondering do I need as max 232 to do this and
A link to some sample code it seems that to the best of my knowledge there is
not much documentation for the VB interface I have ordered books on VB and rs
232 but it only gives info on modem apps
I recently used a bs2 to dial a pager system and output an alpha message that
was kool.
very simple but need help with where to purchase VB interface to stamp or pic
anything any help would be appreciated. thanks jim HAPPY STAMPING.
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
was kool.
Do you Yahoo!?
standard MAX-232 inverter, and the code uses flow control so the Stamp
can control when data flows back and forth. You can find the article
(in PDF form) on the Parallax web site.
Downloads >> Nuts & Volts Columns >> Volume 3 >> Column 89 : Data
Exchange with Visual BASIC
I used Al Williams' RS-I to make connections convenient.
-- Jon Williams
-- Parallax
From: frog28043 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rnQxpzu771Gf1xvWSt8N_KA33GZDeNnD-G2vq71efekVb-wZsRwYIXWYXbl_GUwZNOn_sL5SMb8E4Qw]frog28043@y...[/url
Sent: Monday, July 07, 2003 9:33 PM
Subject: [noparse][[/noparse]basicstamps] Visual Basic interface Stamps
stamp I am building a simple Driving simulator with 6 inputs need to
take it into vb and convert it using text1.text I was wondering do I
need as max 232 to do this and A link to some sample code it seems that
to the best of my knowledge there is not much documentation for the VB
interface I have ordered books on VB and rs 232 but it only gives info
on modem apps I recently used a bs2 to dial a pager system and output an
alpha message that was kool.
or pic anything any help would be appreciated. thanks jim HAPPY
STAMPING.
Do you Yahoo!?
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
on the Stamp Board Of Education -- the
BS2 has an on-chip pseudo-232 driver.
On the stamp, send data as:
MyData VAR BYTE
I9600 CON 240 + 16384
SEROUT P16, I9600, [noparse][[/noparse]MyData]
that to the best of my knowledge there is not much documentation for
the VB interface I have ordered books on VB and rs 232 but it only
stamp or pic anything any help would be appreciated. thanks jim
HAPPY STAMPING.
> Do you Yahoo!?
turns out that it was my fault I was using a development board and I need to
disc the programming pin in order for it to communicate with the vb rs232 line
my fault went back to the serial programs and they worked I feel stupid!!!!!!!!!
to spend that much time you see on a terminal program I can see the port and
input dont know why but can when using vb if the program pin is left connected
can't will need to research this one probably very simple answer. thanks for all
your help guys.
Allan Lane <allan.lane@h...> wrote:You should be able to use the
built-in DB9
MyData VAR BYTE
HAPPY STAMPING.
> Do you Yahoo!?
from the same email address that you subscribed. Text in the Subject and Body of
Do you Yahoo!?
turned 'off' in VB. This signal is used by the
BS2 as a 'RESET' when it goes 'active'. 'active'
is the default way VB brings it up.
If you say: MSCOMM.DTREnable = FALSE before you
do MSCOMM.PortOpen = TRUE, then the DTR line will
not reset the Stamp, and you can run your program.
OR:
Simple Tx Use:
Comm.CommPort = 1 ' Using 'COM1' port
Comm.DTREnable = FALSE
Comm.PortOpen = TRUE ' Opens port.
Buffer = CHR$(Value)
Comm.Output = Buffer
> Thanks for all the input I loaded a know good program and still
no luck it turns out that it was my fault I was using a development
board and I need to disc the programming pin in order for it to
communicate with the vb rs232 line my fault went back to the serial
programs and they worked I feel stupid!!!!!!!!! to spend that much
time you see on a terminal program I can see the port and input dont
thanks for all your help guys.
built-in DB9
> MyData VAR BYTE
to
to
I
for
> HAPPY STAMPING.
> > Do you Yahoo!?
Subject and Body of the message will be ignored.
> Do you Yahoo!?
removing the pin connect thanks.
Allan Lane <allan.lane@h...> wrote:Yes, very simple answer. The DTR
signal must be
OR:
Simple Tx Use:
> Allan Lane wrote:You should be able to use the
built-in DB9
> MyData VAR BYTE
to
to
I
for
> HAPPY STAMPING.
> > Do you Yahoo!?
> Do you Yahoo!?
Do you Yahoo!?
