shiftin/shiftout interfaces
Hey Everyone,
I posted something similar to this last week but I guess nobody
knows an answer or just missed it. I was hoping that someone would
have some advice this time because it seems like this problem could
occur with many types of shiftin/shiftout interfaces. I've connected
a playstation2 controller to my basic stamp2sx. I've wired up all the
pins correctly, and I'm supplying regulated +5V from a power source
seperate from the basic stamp (grounds of the basic stamp and
controller are connected though). I changed the pin #s in the code
below (program1 from playstation.zip from nuts and volts:
http://www.nutsvolts.com/toc_Pages/TOC_Related_Info/Playstation.htm)
to fit my hook ups. When I run the code though, I get the same data
whether the controller is powered or not, just 255s and 1s varying
with all 0s occasionally. Also my stamp seems to get pretty hot
whenever I'm testing the interface. any ideas of what the problem
might be? Thanks a lot! I appreciate it! Code below:
' I/O Assignment and TRIS:
clk con 7
att con 9
dat con 5
cmd con 6
' Variables:
index var byte
char var byte
'this code simply reads in the commands from the playstation
controller joysticks and buttons
'and displays them via debug.
main:
low att '
select the PSX controller
shiftout cmd,clk, LSBFIRST,[noparse][[/noparse]$01,$42] ' send "get ready"
and "send data"
shiftin dat, clk, 3, [noparse][[/noparse]char] ' read then discard
this byte, it
'starts up the controller
'shiftin dat, clk, 3, [noparse][[/noparse]char]
shiftin dat, clk, 3, [noparse][[/noparse]char] ' 1st "digital" byte -
left switches
debug cr,"Buttons:
",cr
debug bin char, " " ' debug
window binary format
shiftin dat, clk, 3, [noparse][[/noparse]char] ' 2nd "digital" byte -
right switches
'the above block shifted in the on/off (111011011) status of all the
switches
debug cr, "Right joy:
L/R "
shiftin dat, clk, 3, [noparse][[/noparse]char] ' right joystick
left / right
debug dec char, " " ' debug
window decimal format
U/D "
shiftin dat, clk, 3, [noparse][[/noparse]char] ' right joystick up /
down
debug cr, "Left joy:
L/R "
shiftin dat, clk, 3, [noparse][[/noparse]char] ' left joystick
left / right
U/D "
shiftin dat, clk, 3, [noparse][[/noparse]char] ' left joystick up /
down
debug dec char, CR ' debug
window dec format and return
pause 1000
'the block above gets decimal values representing analog X/Y joystick
positions
high att
'stops transmissions
goto main
clk con 7
att con 9
dat con 5
cmd con 6
' Variables:
index var byte
char var byte
main:
low att '
and "send data"
this byte, it
left switches
debug cr,"Buttons:
",cr
right switches
switches
L/R "
left / right
U/D "
down
L/R "
left / right
U/D "
down
pause 1000
positions
high att
goto main
read_PS2 'A trade off was made between software and hardware.
' ' It is desirable to use the SHIFTIN and SHIFTOUT cammands
' ' without additional pauses. To do this, the clock signal
' ' must be inverted. A transistor or other sutable inverter
' ' is required for this code.
It sounds like driver contention -- ie you're trying to
drive the line while someone else tries to drive the
line. You should have a 220 ohm resistor in series with
your data and clock pins to prevent damage in these
circumstances.
--- In basicstamps@yahoogroups.com, "Sam" <hard-on@t...> wrote:
> Hey Everyone,
connected
the
> clk con 7
> att con 9
> dat con 5
> cmd con 6
> ' Variables:
> index var byte
> char var byte
> main:
> low att '
> and "send data"
> this byte, it
> left switches
> debug cr,"Buttons:
",cr
> right switches
the
> switches
L/R "
> left / right
U/D "
> down
L/R "
> left / right
U/D "
> down
> pause 1000
joystick
> positions
> high att
> goto main
file... I didn't get that issue of nuts and volts, did anyone else
read that article and have any advice? Do I need inversion for the
program1 code too?
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> Did you miss the line in the "Program 2.bs2" that says:
signal
inverter
> circumstances.
> > Hey Everyone,
would
could
> connected
> the
source
code
data
varying
> > clk con 7
> > att con 9
> > dat con 5
> > cmd con 6
> > ' Variables:
> > index var byte
> > char var byte
> > main:
> > low att '
> > and "send data"
> > this byte, it
> > left switches
> > debug cr,"Buttons:
",cr
> > right switches
> the
> > switches
L/R "
> > left / right
U/D "
> > down
L/R "
> > left / right
U/D "
> > down
> > pause 1000
> joystick
> > positions
> > high att
> > goto main
data line to be pulled up. I will put my version of the schematic in
the files folder for those that didn't get the magazine. I've included
series resistors to protect the BASIC Stamp from a possible failure of
the PSX controller.
One note: Because of the way the PSX controller samples the data line,
it will cause Bit7 of the last data byte (which is the up/down axis of
the left analog joystick) to be set if you use SHIFTIN. If you manually
shift the data into the Stamp (as I will show you how in my N&V column
-- so stay tuned) you can deal with this and get the full range of the
left joystick. Manually shifting is much slower than SHIFTIN, so that's
something you have to account for. If you're not using the Analog PSX
controllers, this is a non-issue and SHIFTIN works perfectly.
-- Jon Williams
-- Parallax
From: Sam [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZbhqOxYJ5Hbc9iBTjoSpPDrHJF4jm0dCOHYYrZiQisR4TfrTHRZHll4qYXKaGtvuFqMWeK9zCdvPmS7t]hard-on@t...[/url
Sent: Monday, July 07, 2003 12:04 PM
Subject: [noparse][[/noparse]basicstamps] Re: shiftin/shiftout interfaces
it didn't mention that inversion was necessary in the program1
program1 code too?
signal
inverter
> circumstances.
> > Hey Everyone,
would
could
> connected
> the
source
code
data
varying
> > clk con 7
> > att con 9
> > dat con 5
> > cmd con 6
> > ' Variables:
> > index var byte
> > char var byte
> > main:
> > low att '
> > and "send data"
> > this byte, it
> > left switches
> > debug cr,"Buttons:
",cr
> > right switches
> the
> > switches
L/R "
> > left / right
U/D "
> > down
L/R "
> > left / right
U/D "
> > down
> > pause 1000
> joystick
> > positions
> > high att
> > goto main
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
way of doing it in your schematic when you post it? thanks
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> Yes, the PSX requires an inverted clock signal; it also requires the
in
included
of
> the PSX controller.
line,
of
manually
column
the
that's
PSX
> -- Jon Williams
> -- Parallax
> From: Sam [noparse][[/noparse]mailto:hard-on@t...]
> program1 code too?
> signal
> inverter
> > circumstances.
> > > Hey Everyone,
nobody
> would
> could
> > connected
all
> > the
> source
> code
> data
> varying
problem
> > > clk con 7
> > > att con 9
> > > dat con 5
> > > cmd con 6
> > > ' Variables:
> > > index var byte
> > > char var byte
> > > main:
> > > low att '
> > > and "send data"
> > > this byte, it
> > > left switches
> > > debug cr,"Buttons:
",cr
> > > right switches
> > the
> > > switches
L/R "
> > > left / right
U/D "
> > > down
L/R "
> > > left / right
U/D "
> > > down
> > > pause 1000
> > joystick
> > > positions
> > > high att
> > > goto main
Subject
> abuse@p...
resistors that you can pick-up from Radio Shack. About the only thing
you can't find is the PSX socket (I didn't want to hack my joystick). I
cut a socket from an inexpensive PSX extender cable.
There are a couple of useful web sites on PSX interfacing:
http://laurent.saintmarcel.free.fr/psx/
http://www.geocities.co.jp/Playtown/2004/psx/ps_eng.txt
-- Jon Williams
-- Parallax
From: Sam [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=GTjiDH_DvwOG2Zlq2eGrg769DoJy4d1nFHZ-TJ3QyjVtxbxb6HkVpAfEIWRHfOc8q98mXpgCnQbFYw]hard-on@t...[/url
Sent: Monday, July 07, 2003 3:11 PM
do I have to buy a logic inverter chip? or will you describe another
in
included
of
> the PSX controller.
line,
of
manually
column
the
that's
PSX
> -- Jon Williams
> -- Parallax
> program1 code too?
> signal
> inverter
> > It sounds like driver contention -- ie you're trying to drive the
> > line while someone else tries to drive the line. You should have a
> > 220 ohm resistor in series with your data and clock pins to prevent
> > damage in these circumstances.
> > > Hey Everyone,
nobody
> would
> could
> > connected
all
> > the
> source
> code
> data
> varying
problem
> > > clk con 7
> > > att con 9
> > > dat con 5
> > > cmd con 6
> > > ' Variables:
> > > index var byte
> > > char var byte
> > > controller joysticks and buttons 'and displays them via debug.
> > > main:
> > > low att '
> > > and "send data"
> > > this byte, it
> > > left switches
> > > debug cr,"Buttons:
",cr
> > > right switches
> > the
> > > switches
L/R "
> > > left / right
U/D "
> > > down
L/R "
> > > left / right
U/D "
> > > down
> > > pause 1000
> > joystick
> > > positions
> > > high att
> > > goto main
Subject
> abuse@p...
abuse@p....
assuming you deliberately didn't hook up the ack line). I no longer
have the value fluctuation that I mentioned before (readings of 255/1
and 0 over the data line). Now it's only and always 0 values for
button presses and for the joysticks. Whatever I press doesn't do
anything. Using a logic probe, I can see that the clock is indeed
inverted (high with low pulses), and on the data and command and att
lines, I detect pulses everytime that the bs2sx is taking a reading
from the controller (I have a 'pause 500' after collecting each full
string of data, including all button presses). I'm using a wall-wart
to power the controller now (was using a 9V battery before), thinking
that the current might have been too low, but that didn't change
anything; there is a 5V regulator between the wall-wart and the
controller. I'm using an 'obsolete' 2n222A npn transister instead of
the one you mentioned because I owned one already. Any suggestions?
The code I'm using was posted in my post several messages up from
here.
in
included
of
> the PSX controller.
line,
of
manually
column
the
that's
PSX
> -- Jon Williams
> -- Parallax
> program1 code too?
> signal
> inverter
> > circumstances.
> > > Hey Everyone,
nobody
> would
> could
> > connected
all
> > the
> source
> code
> data
> varying
problem
> > > clk con 7
> > > att con 9
> > > dat con 5
> > > cmd con 6
> > > ' Variables:
> > > index var byte
> > > char var byte
> > > main:
> > > low att '
> > > and "send data"
> > > this byte, it
> > > left switches
> > > debug cr,"Buttons:
",cr
> > > right switches
> > the
> > > switches
L/R "
> > > left / right
U/D "
> > > down
L/R "
> > > left / right
U/D "
> > > down
> > > pause 1000
> > joystick
> > > positions
> > > high att
> > > goto main
Subject
> abuse@p...
know that the circuit does work as I've used it with a Sony controller,
as well as a Radio Shack clone. And any NPN will do; it's not critical.
The Ack signal from the controller is very short and is only used by the
PlayStation to detect the presence of a controller on the port. We can
use the datastream to do this and save a pin.
My only suggestion would be to double-check your interface and
connections to the Stamp. And I've used the code you posted -- it's
messy, but does work with a properly-functioning interface.
-- Jon Williams
-- Parallax
From: Sam [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=XVrUsS_7TuDJUDYsFw0Qq3r7FnfrO00tvR14vkdyRSj3vz1KTbZamu1u2jw2Em6j7u5-ILiZHmubUrv3wLA]hard-on@t...[/url
Sent: Monday, July 07, 2003 6:08 PM
I hooked up everything as shown in your diagram (in which I'm
here.
in
included
of
> the PSX controller.
line,
of
manually
column
the
that's
PSX
> -- Jon Williams
> -- Parallax
> program1 code too?
> signal
> inverter
> > > Hey Everyone,
nobody
> would
> could
> > connected
all
> > the
> source
> code
> data
> varying
problem
> > > clk con 7
> > > att con 9
> > > dat con 5
> > > cmd con 6
> > > ' Variables:
> > > index var byte
> > > char var byte
> > > main:
> > > low att '
> > > and "send data"
> > > this byte, it
> > > left switches
> > > debug cr,"Buttons:
",cr
> > > right switches
> > the
> > > switches
L/R "
> > > left / right
U/D "
> > > down
L/R "
> > > left / right
U/D "
> > > down
> > > pause 1000
> > joystick
> > > positions
> > > high att
> > > goto main
Subject
> abuse@p...
abuse@p....
clock and data lines switched when hooked up to the bs2sx pins, and
also, used a real sony controller, instead of the 'cypher games'
controller I was testing with before. the cypher games controller did
not work with the circuit and code. I think the cypher games
controller has a higher current draw or something, it's analog led
would not turn on when the button was pressed, while the sony
controller led would. I'm confused because the joysticks on the sony
controller were working nicely, giving different values depending on
their position, but I wasn't using an analog to digital converter at
all... I'm assuming these values are just innacurate random numbers
that arise when the stamp tries to analyze analog voltages as
digital, so I'm going to put an adc on the data line to try to fix
this. Thank you very much for your patience and help!
wrote:
> If you're sure your circuit is good, you may have a bad
controller. I
controller,
critical.
by the
can
> -- Jon Williams
> -- Parallax
255/1
att
full
wart
thinking
of
> here.
the
> in
> included
failure
> of
> > the PSX controller.
> line,
axis
> of
> manually
> column
> the
> that's
> PSX
> > -- Jon Williams
> > -- Parallax
else
the
> > program1 code too?
> > signal
> > inverter
the
have a
prevent
> > > > Hey Everyone,
> nobody
> > would
> > could
> > > connected
> all
> > > the
> > source
> > code
> > data
> > varying
hot
> problem
> > > > clk con 7
> > > > att con 9
> > > > dat con 5
> > > > cmd con 6
> > > > ' Variables:
> > > > index var byte
> > > > char var byte
> > > > main:
> > > > low att
ready"
> > > > and "send data"
discard
> > > > this byte, it
> > > > left switches
> > > > debug cr,"Buttons:
",cr
debug
> > > > right switches
debug
all
> > > the
> > > > switches
L/R "
joystick
> > > > left / right
debug
U/D "
joystick up /
> > > > down
debug
L/R "
joystick
> > > > left / right
debug
U/D "
joystick up /
> > > > down
debug
> > > > pause 1000
> > > joystick
> > > > positions
> > > > high att
> > > > goto main
> Subject
> > abuse@p...
Subject
> abuse@p...
