Sensor SHT1X usage
I am interested in using the Basic Stamp II to use with the Sensiron
SHT1X Temp/Humidity Sensor. The program by Jon Williams, dated 28
Sep 2002 looks perfect, EXCEPT, I would like to be able to use the
sensor/Basic Stamp II with an LCD Module rather than DEBUG to a PC.
I am just starting with programming and really need some help to
make these Temp/Humidity readings go to the LCD AND also to DEBUG so
I can be sure everything is correct. Has anyone ever done this? If
so, would you be willing to help me out!?
Kindest regards, Chuck Irwin
combo. Once you'd figured that out, adding in the SHT11 will be a breeze.
The parallax website has examples of LCD keypad interfacing, check the
downloads->documentation section.
Sent: Saturday, July 05, 2003 8:47 AM
Subject: [noparse][[/noparse]basicstamps] Sensor SHT1X usage
Very simple. If you haven't used LCDs before, I would recommend a serial
LCD, they are much easier to use. I have some code kicking around on another
machine that uses the SHT and a serial LCD. I'll look around, send me your
e-mail addy and I'll send you the code.
Jonathan
www.madlabs.info
LCD_Demo and that works.....my problem is how to combine that code with the
SHT1x code. I will check it again to insure I have not missed anything.
Thanks very much for your help and attention!
Kindest regards,
Chuck Irwin
p.s. This code is kind of like learning Greek for me!
Sent: Saturday, July 05, 2003 14:23 PM
Subject: Re: [noparse][[/noparse]basicstamps] Sensor SHT1X usage
> You might want to experiment with LCD seperately first, maybe a keypad/LCD
> From: "no2k_4" <chuckirwin43@n...>
and
I have not used LCD's before, but did pick one up from BGMicro which uses
the Hitachi HD44780 Controller. I found some code listed under "Experiment
#11: A Basic LCD Demonstration" on Parallax web site. I got that to work
just fine! My problem is trying to combine that code with the SHT1X code.
I am just learning this Basic Stamp II and I think I am way over my head.
I have attached the two programs I have downloaded from the Parallax site,
but I can't seem to figure out how to take the info from the SHT1X program
and feed it to the LCD Display program.
Thanks very much for your help!
Kindest regards,
Chuck Irwin
Sent: Saturday, July 05, 2003 14:46 PM
> Chuck,
another
> Jonathan
> www.madlabs.info
and
using a BS2p/BS2pe, you will have to send just one character at a time.
Get familiar with the DIG operator -- this will come in handy. Also
remember that you have to send ASCII codes to the display. Adding 48
("0") to a digit value will convert that digit to its ASCII code.
-- Jon Williams
-- Parallax
From: chuckirwin43 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=cswaMbLOBTL48MOHp96GI700q1DOXnpYSSIFIEsKNz7MRDJamhYYfGbYzGSwgW28E_VWSdbU61_aBdEGLDPtxg]chuckirwin43@n...[/url
Sent: Saturday, July 05, 2003 4:04 PM
Thanks very much! I have checked and did download some code which is an
the SHT1x code. I will check it again to insure I have not missed
anything. Thanks very much for your help and attention! Kindest regards,
Chuck Irwin p.s. This code is kind of like learning Greek for me!
> keypad/LCD combo. Once you'd figured that out, adding in the SHT11
> will be a breeze.
> > so, would you be willing to help me out!? Kindest regards, Chuck
> > Irwin
> > Subject
and
> and
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
do is change each and every DEBUG command to a SEROUT command.
(actually, COPY all the DEBUGs, PASTE them just below the DEBUGs, and
then change DEBUG to SEROUT on every other DEBUG. That way everything
will appear on the terminal and the LCD. When everything is cool, trash
the DEBUG statements. I had to screw around with SEROUT parameters a
bit, but that simply involved wasting an hour. Each LCD has it's own
command codes (I think), so you would have to use the same LCD that I
used to share my code. That said, I am using a MAtrix Orbital VFD2041
(way-cool blue display), and would be glad to share my code if you
thought it would help.
wherever you see a DEBUG command line in the SHT code, plug in a SEROUT
command that starts with the LCD example code SEROUT but substitutes
the variables from the DEBUT. Sorta' like mix and match. Believe me,
screw around with it, you'll find that you don't need to know Greek
(Geek?) to program Greek (Geek?).
> an
> with the
> anything.
> Kindest regards,
> Chuck Irwin
> From: "pm" <pmeloy@s...>
>> keypad/LCD
>> breeze.
> and
>> and
can you post it?
Sent: Saturday, July 05, 2003 10:45 PM
> I have done it using a serial LCD module. Essentially, what you need to
Here's the code. Be warned, that I ripped all of this out of a much
larger program so to focus on the T&RH stuff; it does indeed run, but
there are probably lots of loose ends (unused constants, etc.) Also,
the LCD code is specific to the Matrix Orbital LCD (VFD2041) that I
used, or at least, specific to Matriz Orbital LCDs. All that said, this
will probably give you an idea of what to do. Most of this code was
ripped off the Parallax web site (thank you very much Parallax). Get a
copy of the LCD display manual and see how you can rip my code off,
change it as little as possible, and make it do what you want it to do.
Good luck, Mark
'{$STAMP BS2p}
' I/O Definitions, Temp/RH
ShtData CON 1 ' bi-directional data
Clock CON 0
' Constants, Temp/RH
ShtTemp CON %00011 ' read temperature
ShtHumi CON %00101 ' read humidity
ShtStatW CON %00110 ' status register
write
ShtStatR CON %00111 ' status register read
ShtReset CON %11110 ' soft reset (wait 11
ms after)
Ack CON 0
NoAck CON 1
No CON 0
Yes CON 1
MoveTo CON 2 ' for DEBUG control
ClrRt CON 11 ' clear DEBUG line to
right
DegSym CON 186 ' degrees symbol for
DEBUG
' Variables, Temp/RH
ioByte VAR Byte ' data from/to SHT1x
ackBit VAR Bit ' ack/nak from/to
SHT1x
toDelay VAR Byte ' timeout delay timer
timeOut VAR Bit ' timeout status
soT VAR Word ' temp counts from
SHT1x
tC VAR Word ' temp - celcius
tF VAR Word ' temp - fahrenheit
soRH VAR Word ' humidity counts
from SHT1x
rhLin VAR Word ' humidity; linearized
rhTrue VAR Word ' humidity; temp
compensated
status VAR Byte ' SHT1x status byte
'Total 122 bits
' Initialization, Temp/RH
InitializeTempRH:
GOSUB SHT_Connection_Reset ' reset device
connection
PAUSE 250 ' let DEBUG window open
' Initialization, LCD
SEROUT 15, 240, [noparse][[/noparse]254, 84] 'turns off cursor (254=>send command to LCD)
SEROUT 15, 240, [noparse][[/noparse]254, 88] 'clears screen
SEROUT 15, 240, [noparse][[/noparse]254, 67] 'auto line wrap on
SEROUT 15, 240, [noparse][[/noparse]254, 71, 1,2] ' Places the data on Row 2 of the LCD
' for a 1-line LCD, change
[noparse][[/noparse]254,71,1,2] to
' [noparse][[/noparse]254,71,1,1]
SEROUT 15, 240, [noparse][[/noparse]"Tmp: F RH: %"]
' Program Code
Sensor_Demo:
GOSUB SHT_Measure_Temp
DEBUG MoveTo, 0, 3
DEBUG "tF...... "
DEBUG DEC (tF / 10), ".", DEC1 tF, DegSym, ClrRt, CR
GOSUB SHT_Measure_Humidity
DEBUG "rhLin... "
DEBUG DEC (rhLin / 10), ".", DEC1 rhLin, "%", ClrRt, CR, CR
Heater_On:
DEBUG "SHT1x heater on", CR
status = %00000100 ' heater bit = On
GOSUB SHT_Write_Status
DEBUG "Waiting 2 seconds", CR
PAUSE 2000
Heater_Off:
DEBUG "SHT1x heater off", CR, CR
status = %00000000 ' heater bit = Off
DEBUG "tF...... "
DEBUG "rhLin... "
PAUSE 5000
Main1:
DEBUG CLS
DEBUG "SHT1x Demo", CR
DEBUG "
", CR
LoopDeLoop:
Main2:
SEROUT 15, 240, [noparse][[/noparse]254, 71, 6,2, DEC tF / 10, ".", DEC1 tF]
' **** See note above about displaying data on line 2 of the LCD
SEROUT 15, 240, [noparse][[/noparse]254, 71, 16,2, DEC rhTrue / 10, ".", DEC1 rhTrue]
PAUSE 1000 ' minimum delay between T/RH readings
GOTO LoopDeLoop
' Subroutines, Temp/RH
' connection reset: 9 clock cyles with ShtData high, then start sequence
SHT_Connection_Reset:
SHIFTOUT ShtData, Clock, LSBFIRST, [noparse][[/noparse]$FFF\9]
' generates SHT1x "start" sequence
' _____ _____
' ShtData |_______|
' ___ ___
' Clock ___| |___| |___
SHT_Start:
INPUT ShtData ' let pull-up take line
high
LOW Clock
HIGH Clock
LOW ShtData
LOW Clock
HIGH Clock
INPUT ShtData
LOW Clock
RETURN
' measure temperature
' -- celcius = soT * 0.01 - 40
' -- fahrenheit = soT * 0.018 - 40
SHT_Measure_Temp:
GOSUB SHT_Start ' alert device
ioByte = ShtTemp ' temperature command
GOSUB SHT_Write_Byte ' send command
GOSUB SHT_Wait ' wait until
measurement done
ackBit = Ack ' another read follows
GOSUB SHT_Read_Byte ' get MSB
soT.HIGHBYTE = ioByte
ackBit = NoAck ' last read
GOSUB SHT_Read_Byte ' get LSB
soT.LOWBYTE = ioByte
' Note: Conversion factors are multiplied by 10 to return the
' temperature values in tenths of degrees
tC = soT / 10 - 400 ' convert to tenths C
tF = soT ** 11796 - 400 ' convert to tenths F
RETURN
' measure humidity
SHT_Measure_Humidity:
ioByte = ShtHumi ' humidity command
measurement done
soRH.HIGHBYTE = ioByte
soRH.LOWBYTE = ioByte
' linearize humidity
' rhLin = (soRH * 0.0405) - (soRH^2 * 0.0000028) - 4
' for the BASIC Stamp:
' rhLin = (soRH * 0.0405) - (soRH * 0.004 * soRH * 0.0007) - 4
' Conversion factors are multiplied by 10 and then rounded to
' return tenths
rhLin = (soRH ** 26542)
rhLin = rhLin - ((soRH ** 3468) * (soRH ** 3468) + 50 / 100)
rhLin = rhLin - 40
' temperature compensated humidity
' rhTrue = (tC - 25) * (soRH * 0.00008 + 0.01) + rhLin
' Conversion factors are multiplied by 100 to improve accuracy and
then
' rounded off.
rhTrue = ((tC / 10 - 25) * (soRH ** 524 + 1) + (rhLin * 10)) + 5 / 10
RETURN
' sends "status"
SHT_Write_Status:
ioByte = ShtStatW ' write to status reg
command
ioByte = status
RETURN
' returns "status"
SHT_Read_Status:
command
GOSUB SHT_Read_Byte ' send command
ackBit = NoAck ' only one byte to read
GOSUB SHT_Read_Byte
RETURN
' sends "ioByte"
' returns "ackBit"
SHT_Write_Byte:
SHIFTOUT ShtData, Clock, MSBFIRST, [noparse][[/noparse]ioByte] ' send byte
SHIFTIN ShtData, Clock, LSBPRE, [noparse][[/noparse]ackBit\1] ' get ack bit
RETURN
' returns "ioByte"
' sends "ackBit"
SHT_Read_Byte:
SHIFTIN ShtData, Clock, MSBPRE, [noparse][[/noparse]ioByte] ' get byte
SHIFTOUT ShtData, Clock, LSBFIRST, [noparse][[/noparse]ackBit\1] ' send ack bit
INPUT ShtData ' release data line
RETURN
' wait for device to finish measurement (pulls data line low)
' -- timeout after ~1/4 second
SHT_Wait:
INPUT ShtData ' data line is input
FOR toDelay = 1 TO 250 ' give ~1/4 second to
finish
timeOut = INS.LOWBIT(ShtData) ' scan data line
IF (timeOut = No) THEN SHT_Wait_Done ' if low, we're done
PAUSE 1
NEXT
SHT_Wait_Done:
RETURN
' reset SHT1x with soft reset
SHT_Soft_Reset:
GOSUB SHT_Connection_Reset ' reset the connection
ioByte = ShtReset ' reset command
ackBit = NoAck ' only one byte to send
GOSUB SHT_Write_Byte ' send it
PAUSE 11 ' wait at least 11 ms
On Saturday, July 5, 2003, at 11:17 PM, Mike Mocenter wrote:
> mark,
> can you post it?
> From: "Mark Marpet" <marpetm@s...>
>> to
>> trash
>> and
Sent: Sunday, July 06, 2003 1:27 PM
> Mike-
> Good luck, Mark
> '{$STAMP BS2p}
> Clock CON 0
> write
> ms after)
> Ack CON 0
> NoAck CON 1
> No CON 0
> Yes CON 1
> right
> DEBUG
> SHT1x
> SHT1x
> from SHT1x
> compensated
> 'Total 122 bits
> InitializeTempRH:
> connection
> ' Program Code
> Sensor_Demo:
> DEBUG MoveTo, 0, 3
> DEBUG "tF...... "
> DEBUG "rhLin... "
> Heater_On:
> PAUSE 2000
> Heater_Off:
> DEBUG "tF...... "
> DEBUG "rhLin... "
> PAUSE 5000
> Main1:
> DEBUG CLS
> DEBUG "
", CR
> LoopDeLoop:
> Main2:
> GOTO LoopDeLoop
> ' _____ _____
> ' ShtData |_______|
> ' ___ ___
> SHT_Start:
> high
> LOW Clock
> HIGH Clock
> LOW ShtData
> LOW Clock
> HIGH Clock
> INPUT ShtData
> LOW Clock
> RETURN
> SHT_Measure_Temp:
> measurement done
> RETURN
> ' measure humidity
> measurement done
> ' return tenths
> rhLin = rhLin - 40
> then
> ' rounded off.
> RETURN
> ' sends "status"
> SHT_Write_Status:
> command
> ioByte = status
> RETURN
> ' returns "status"
> SHT_Read_Status:
> command
> GOSUB SHT_Read_Byte
> RETURN
> ' sends "ioByte"
> ' returns "ackBit"
> SHT_Write_Byte:
> RETURN
> ' returns "ioByte"
> ' sends "ackBit"
> SHT_Read_Byte:
> RETURN
> SHT_Wait:
> finish
> PAUSE 1
> NEXT
> SHT_Wait_Done:
> RETURN
> SHT_Soft_Reset:
> > mark,
> > can you post it?
> >> to
> >> trash
> >> and
