PS2 interface code I''m using
'* Title: Playstation interface
'* Filename: Program 1
'* Date: 28 Mar 02
' I/O Assignment and TRIS:
clk con 7
att con 9
dat con 5
cmd con 6
' Variables:
index var byte
char var byte
'this code simply reads in the commands from the playstation
controller joysticks and buttons
'and displays them via debug.
main:
low att ' select the PSX controller
shiftout cmd,clk, LSBFIRST,[noparse][[/noparse]$01,$42] ' send "get ready"
and "send data"
shiftin dat, clk, 3, [noparse][[/noparse]char]' read then discard this byte, it
'starts up the controller
'shiftin dat, clk, 3, [noparse][[/noparse]char]
shiftin dat, clk, 3, [noparse][[/noparse]char] ' 1st "digital" byte - left
switches
debug cr,"Buttons:
",cr
debug bin char, " " ' debug window binary format
shiftin dat, clk, 3, [noparse][[/noparse]char] ' 2nd "digital" byte - right
switches
'the above block shifted in the on/off (111011011) status of all the
switches
debug cr, "Right joy:
L/R "
shiftin dat, clk, 3, [noparse][[/noparse]char] ' right joystick left / right
debug dec char, " " ' debug window decimal format
U/D "
shiftin dat, clk, 3, [noparse][[/noparse]char] ' right joystick up / down
debug cr, "Left joy:
L/R "
shiftin dat, clk, 3, [noparse][[/noparse]char] ' left joystick left / right
U/D "
shiftin dat, clk, 3, [noparse][[/noparse]char] ' left joystick up / down
debug dec char, CR ' debug window dec format and return
pause 1000
'the block above gets decimal values representing analog X/Y joystick
positions
high att
'stops transmissions
goto main
'* Date: 28 Mar 02
clk con 7
att con 9
dat con 5
cmd con 6
' Variables:
index var byte
char var byte
main:
and "send data"
switches
debug cr,"Buttons:
",cr
switches
switches
L/R "
U/D "
L/R "
U/D "
pause 1000
positions
high att
goto main
