Servo to PWM Conversion via BS
I'm trying to us an R/C transmitter to control a small robot, but instead of
servos, I'm using dc brush-motors. My problem is motor control.
I have an R/C receiver, and an H-Bridge driver, but I need a servo-to-pwm
interface. I'd like to use a stamp, but would feel better following an
existing example. If anyone can point me in the right direction, I would
appreciate it.
Joe
appreciate it.
Joe
If I understand you correctly your program would need to read a pulse
input and generate a PWM output. Without extra hardware you can't do
both of these at the same time. This might be OK depending on your
application. So the idea would be to do the following:
Top:
PULSIN... ' read RC input
' convert input to a range from 0 to 255 (0 to 100%)
PWM... ' output PWM
Goto top
You could use a PAK-VII (http://www.al-williams.com/pak7.htm) to read
the R/C continuously. However, it would probably be a better idea to use
a PAK-V (http://www.al-williams.com/pak5.htm) to generate PWM all the
time and let the Stamp read the pulses. This way the PWM doesn't "droop"
while you are reading the input. Parallax just came out a with a
hardware PWM device that is -- as far as I can tell -- somewhat similar
so there are other options, as well.
Hope that gives you some direction.
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
> From: Joe McCartin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8KyqtTwtUwTLBK_wx8gBjvc9BgOfgPkk4NN_FsiSQIAaOFkGgHfkGloyy5xpFNk0LTQY3xwut76oHQ]joe@j...[/url
> Sent: Monday, June 30, 2003 8:35 PM
> Subject: [noparse][[/noparse]basicstamps] Servo to PWM Conversion via BS
> Hi,
> but instead of servos, I'm using dc brush-motors. My problem
> is motor control.
> servo-to-pwm interface. I'd like to use a stamp, but would
> feel better following an existing example. If anyone can
> point me in the right direction, I would appreciate it.
> Thanks,
> Joe
> from the same email address that you subscribed. Text in the
