ULN2803 confusion — Parallax Forums
ULN2803 confusion
edited 2003-06-30 21:32 in General Discussion
In the basic stamp appnotes there is a trainset controller setup using a
ULN2803. It shows Pin 10 of the 2803 going to ground. My understanding of the
clamp diodes is that your could connect pin 10 to the +12v, not ground - to
short out the reverse voltage caused by noisy components de-energizing.
Since this is powering rails, I'd imagine there'd be no reverse voltage... Is
that why its grounded instead of going to +12?
http://www.parallax.com/Downloads/Documentation/bs/mod/BASIC_Stamp_1_App_Notes_V\
1-9.pdf
Page 179
    There is an even simpler explanation: the figure has an error, as
    previously acknowledged by Paralllax reps. ULN2803 pin 10 should go
    to +12V, not gnd.
    Steve
    > using a ULN2803. It shows Pin 10 of the 2803 going to ground. My
    > understanding of the clamp diodes is that your could connect pin 10
    > to the +12v, not ground - to short out the reverse voltage caused by
