Delorme Tripmate Connections/Code?
I have in my possession a Delorme Tripmate GPS, with the serial 9
pin connector. Does anyone know the pinout for the device. I would
like to connect this GPS to a BS2P and read the $GPRMC code from it,
similar to Jon Williams setup in a earlier Nuts and Volts article.
I going to try to hack the code Jon wrote for his GPS and get it to
work with the Delorme, I searched thru the past posts on this
Delorme monster but have yet to find some simple code to read in the
$GPRMC string... can anyone help?? Thanks in advance... Rob
Rob -
The information found in the following two links ought to get you started:
<http://wes.johnston.net/aprs/tripmate.htm>
<http://www.shotton.com/gps/tripmate_cable.html>
Bruce Bates
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
sight to get get it going
--- Bruce Bates <bvbates@u...> wrote:
> with the serial 9
> device. I would
> Volts article.
> GPS and get it to
> posts on this
> code to read in the
> advance... Rob
> Rob -
> Regards,
> Bruce Bates
> Text in the Subject and Body of the message will be
> ignored.
__________________________________
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
http://sbc.yahoo.com
