ADC0831 vs. ADC0834 redux
Archiver
I didn't see any response to my inquiry.
Is this a tough question or is this just not very interesting to
others?
Still would like to know.
Lawrence
--- In basicstamps@yahoogroups.com, "altengnw2000"
<altengnw2000@y...> wrote:
> These are the same chip except the ADC0834 has the ability to read
> four separate inputs.
> In the StampWorks manual experiment #27, it shows how to connect an
> ADC0831 and gives a sample program. I have performed this
experiment
> successfully.
> My question is about the ADC0834. It has two new pins: Data In
(DI)
> and SARS Status (SARS) How are these two pins connected to the
Basic
> Stamp?
> How would the ADC0831 program example have to be modified to
> operate this two pins.
> Thanks in advance for any help,
> Lawrence
others?
Lawrence
experiment
> successfully.
(DI)
Basic
> Stamp?
> Lawrence
successive approximation A to D conversion
in real time. Since it only does one
channel, it is very straightforward to
interface -- ie you only need to run a
'SHIFTIN' command to get the data.
The ADC0834 needs to have you send some
data to it, to select the channel to
be converted. I havn't done this,
since the 0831 is so simple to interface,
I havn't had to go to the multi-channel
beast.
Perhaps, nobody has had to go to the
multi-channel beast, which is why you
aren't getting any more answers.
> others?
> Thanks,
> Lawrence
read
an
> experiment
> > successfully.
> (DI)
> Basic
> > Stamp?
> > Lawrence
to convert which is why it has a data in pin.
SARS is the Successive Approximation Ready Signal - you can hook this to
another stamp pin and check its status - if its high the conversion is in
progress, if its low, its ready to read.
You can either watch this pin and read the value when it goes low or, just
wait a few milliseconds and then read (save a pin). It only takes 8 clock
cycles for a conversion which is pretty darned quick in stamp terms.
Sent: Sunday, June 29, 2003 8:12 AM
Subject: [noparse][[/noparse]basicstamps] Re: ADC0831 vs. ADC0834 redux
> The ADC0831 uses the SPI clock to run a
> beast.
> > others?
> > Thanks,
> > Lawrence
> read
> an
> > experiment
> > > successfully.
> > (DI)
> > Basic
> > > Stamp?
> > > Lawrence
What PBASIC command do I send to tell it to read channel 2, for
example?
What does SPI stand for?
Lawrence
--- In basicstamps@yahoogroups.com, pm <pmeloy@s...> wrote:
> The 0834 just uses a normal SPI interface. You have to tell it
which channel
this to
conversion is in
or, just
8 clock
terms.
> From: "Allan Lane" <allan.lane@h...>
> > beast.
to
> > > others?
> > > Thanks,
> > > Lawrence
> > read
connect
> > an
> > > experiment
> > > > successfully.
In
> > > (DI)
the
> > > Basic
> > > > Stamp?
> > > > Lawrence
Subject and
Download the data sheet .PDF. They have a single
PDF for several A to D chips.
'SPI' stands for 'Serial Peripheral Interface'.
Basically, the BS2 SHIFTOUT/SHIFTIN uses this
interface. So, you'd use 'SHIFTOUT' to select
which channel you want, then 'SHIFTIN' to
get the data. See the timing diagram for the
0834 chip in the PDF.
As I said, I havn't done this personally.
> Thank you for responding.
> example?
> Thanks,
> Lawrence
> which channel
> this to
> conversion is in
> or, just
> 8 clock
> terms.
> > > beast.
> to
> > > > others?
> > > > Thanks,
> > > > Lawrence
to
> > > read
> connect
> > > an
> > > > experiment
> > > > > successfully.
Data
> In
> > > > (DI)
> the
> > > > Basic
> > > > > Stamp?
> > > > > Lawrence
> Subject and
Is this an National Semi Conductor Standard or a Parallax standard
or somebody elses?
Is there a spec somewhere?
Lawrence
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> Go to www.National-Semi.com, look for ADC0831.
> > example?
> > Thanks,
> > Lawrence
> > which channel
hook
> > this to
> > conversion is in
low
> > or, just
takes
> > 8 clock
> > terms.
> > > > beast.
interesting
> > to
> > > > > others?
> > > > > Thanks,
> > > > > Lawrence
ability
> to
> > > > read
> > connect
> > > > an
this
> > > > > experiment
> > > > > > successfully.
> Data
> > In
> > > > > (DI)
to
> > the
> > > > > Basic
> > > > > > Stamp?
modified to
> > > > > > Lawrence
the
> > Subject and
>or somebody elses?
>Thanks,
>Lawrence
Lawrence -
I believe the protocol came from Motorola, and is documented fairly well
in "M68HC11 Reference Manual" (among other places). You can order the manual
from Motorola Literature Distribution at 1-800-441-2447 or fax 1-303-675-2150
at no charge.
Bruce Bates
project I did two years ago. If I remember right the 0834 had some
limitations other than 4 vs. 8 inputs, I don't remember what though.
Peter Anderson has some info at
http://www.phanderson.com/printer/0838/0838.html
Not about the stamp interface but it got me started last time.
Also a google search for "adc0838 basic stamp" will find a number of
project people have done with it, along with code. If that's not
enough let me know I can dig up some of my old references on the
project.
>others?
>Thanks,
>Lawrence
>experiment
>> successfully.
>(DI)
>Basic
>> Stamp?
>> Lawrence
>Subject and Body of the message will be ignored.
manual for ADC0838 describes when interfacing the ADC0838 to BS2p for
measuring 8 analog single ended channels. Can someone explain why I
see what I see?
Let me explain.
The manual for ADC0838 says the controlling bits is a 5 bit sequence:
C4 C3 C2 C1 C0 (where C4 is always 1, C3 is 1 for single ended
measurement).
Since there are eight channels, channel number can be described by a
three bits. C2 is the LSB (rightmost bit)of the channel number, C1 is
the MSB (leftbit) of the channel number, C0 is the middle bit of the
channel. Say, I use a byte called MUXBYTE for this control, then
Channel Number MUXBYTE
0 (%000) 24 (%11000)
1 (%001) 28 (%11100)
2 (%010) 25 (%11001)
3 (%011) 29 (%11101)
4 (%100) 26 (%11010)
5 (%101) 30 (%11110)
6 (%110) 27 (%11011)
7 (%111) 31 (%11111)
THe PBASIC code I use is somewhat like below:
CS cib 0 ' Chip select pin of ADC to BS2p I/O pin 0
ADCIn con 1 ' DI pin of ADC to BS2p I/O pin 1
ADCOUT con 3 ' DO pin of ADC to BS2p I/O pin 3
CLK con 2 ' CLK pin of ADC to BS2p I/O pin 2
MUXBYTE var BYTE
Channel var BYTE
ADCVAL var BYTE
DIRA = %0111
HIGH CS
FOR Channel = 0 to 7
LOW CS
MUXBYTE = %11000 | ((Channel & %001) << 2) | ((Channel & %110) >> 1)
SHIFTIN ADCIN,CLK, MSBFIRST,[noparse][[/noparse]MUXBYTE\5]
SHIFTOUT ADCOUT,CLK,MSBPOST,[noparse][[/noparse]ADCVal\9]
DEBUG Dec Channel," ",Dec ADCVal
HIGH CS
NEXT
END
However, I find that if I use the above values, the channels that
are actually read are different, namely:
Channel Number MUXBYTE Channel actually read
0 (%000) 24 (%11000) 0 (%000)
1 (%001) 28 (%11100) 2 (%010)
2 (%010) 25 (%11001) 4 (%100)
3 (%011) 29 (%11101) 6 (%110)
4 (%100) 26 (%11010) 1 (%001)
5 (%101) 30 (%11110) 3 (%011)
6 (%110) 27 (%11011) 5 (%101)
7 (%111) 31 (%11111) 7 (%111)
This makes me think the control sequence is actually
C4 C3 C2 C1 C0 actually represents
C4 - always 1
C3 - always 1 for single ended measurement
C2 - Middle bit of channel
C1 - LSB of channel (rightmost bit)
C0 - MSB of channel (leftmost bit)
So, if I compute the MUXBYTE as follows
MUXBYTE = %11000 | ((Channel & %100) >> 2) | ((Channel & %011) << 1)
I find that the correct channels are read.
Any idea why I see this?
Thanks a lot
Mohammed
--- In basicstamps@yahoogroups.com, Mike Davey <mdavey@n...> wrote:
> I've never used the 0834 before but have used the ADC0838 in a
though.
of
> project.
> Mike
> >others?
> >Thanks,
> >Lawrence
read
connect an
> >experiment
> >> successfully.
> >(DI)
> >Basic
> >> Stamp?
> >> Lawrence
The MUXBYTE logic as in the program seems to match the ADC0838 data
sheet. However, (maybe this is a typo), a SHIFTOUT ... [noparse][[/noparse]MUXBYTE] to
send the command needs to come before the SHIFTIN ...[noparse][[/noparse]ADCVal] to
read the data. The result of the program as written would be weird.
-- Tracy
>MUXBYTE var BYTE
>Channel var BYTE
>ADCVAL var BYTE
>DIRA = %0111
>HIGH CS
> LOW CS
> HIGH CS
>NEXT
>END
program (I retyped it and made a mistake).
The statements should have read
SHIFTOUT ADCIn,CLK,MSBFIRST,[noparse][[/noparse]MUXBYTE\5]
SHIFTIN ADCOUT,CLK,MSBPOST,[noparse][[/noparse]ADCRes\9]
I am giving more details here. (Sorry for the long post). I
appreciate your explanation for the results that I observe. I think
it may have something to do with how the SHIFTIn statement works or
something to do with the ADC0838 behaviour.
After submitting the previous post, I found that:
using the correct control bits (as specifed in the ADC0838
datasheet), that is,
1)
and not using the "\9" in the SHIFTIN statement gave the voltages of
the channels correctly (case 2). If I use the "\9" modifier then the
channel ordering is mixed up as I stated in the original post (case
1).
However, if I use the following control sequence bits as computed by
MUXBYTE= %11000 | ((Channel & %100) >> 2) | ((Channel & %011) << 1)
and use the SHIFTIN statment with the "\9" modifier (case 3), I get
the right results. If I do not use the "\9" modifier in the SHIFTIN
statement while using this MUXBYTE (case 4), then I get wrong
ordering of channel results. And this wrongly ordered result is NOT
the same as the wrongly ordered results which I get using the correct
MUXBYTE (as specified in the manual for ADC0838) but using the "\9"
modifier in the SHIFTIN statement.
In all the cases (channels 0 and 7) are read correctly , only the
channels in between are mixed up.
I have seven 1.2K resistor connected between +5 and GND. Channel 0 is
connected to +5 V, Channel 7 is connected to GND and the channels 1
to 6 are connected at terminals in between the 1.2K so that I should
get (5V,4.286,3.571,2.857,2.143,1.429,0.714,0 volts) on the channels
0 to 7 respectively.
Let me post below my actual BS2p code (which is modified from a BS2
code I found at
http://people.msoe.edu/~barnicks/courses/cs400/19967/aqua/dsgnrpt-
web/mic.htm) and the results I get in each case.
Case 1
CS CON 0 ' Chip select is I/O pin 0.
ADCIn CON 1 ' Data input to ADC is I/O pin 1.
ADCOut CON 3 ' Data output from ADC is I/O pin 3.
CLK CON 2 ' Clock is I/O pin 2.
ADCRes VAR Byte ' A-to-D result: one byte.
ADCVol VAR Word
Channel VAR Byte ' Number of the channel we want to measure
MUXBYTE VAR Byte ' Sequence of bits for initialization
DIRA = %0111 ' Set direction bits properly
HIGH CS
DEBUG "
",CR
DEBUG " Channel ; MUXBYTE ; ADCResult ;
Voltage*100" ,CR
DEBUG "
",CR
FOR Channel = 0 TO 7 ' Go through all the channels
LOW CS ' Chip select active low.
1)
' MUXBYTE= %11000 | ((Channel & %100) >> 2) | ((Channel & %011) <<
1)
' SHIFTIN ADCOut,CLK,MSBPOST,[noparse][[/noparse]ADCRes]
SHIFTIN ADCOut,CLK,MSBPOST,[noparse][[/noparse]ADCRes\9]
HIGH CS ' Chip select inactive
ADCVol = (ADCRes*100)*/5
DEBUG DEC CHANNEL," (%",BIN3 Channel,") ; ",DEC MUXBYTE, "
(%",BIN MUXBYTE,") ; "
DEBUG DEC3 ADCRes," (%",BIN8 ADCRes,") ; ",DEC3 ADCVol,"
(%",BIN8 ADCVol,") " , CR
NEXT ' Go to next channel
DEBUG "
",CR
END
Below are the results from the debug window for case 1
Channel ; MUXBYTE ; ADCResult ; Voltage*100
0 (%000) ; 24 (%11000) ; 255 (%11111111) ; 498 (%11110010)
1 (%001) ; 28 (%11100) ; 183 (%10110111) ; 357 (%01100101)
2 (%010) ; 25 (%11001) ; 111 (%01101111) ; 216 (%11011000)
3 (%011) ; 29 (%11101) ; 036 (%00100100) ; 070 (%01000110)
4 (%100) ; 26 (%11010) ; 220 (%11011100) ; 429 (%10101101)
5 (%101) ; 30 (%11110) ; 147 (%10010011) ; 287 (%00011111)
6 (%110) ; 27 (%11011) ; 072 (%01001000) ; 140 (%10001100)
7 (%111) ; 31 (%11111) ; 000 (%00000000) ; 000 (%00000000)
Case 2:
Program statements (only the relevant statements):
1)
1)
' SHIFTIN ADCOut,CLK,MSBPOST,[noparse][[/noparse]ADCRes\9]
Resulst for case 2:
1 (%001) ; 28 (%11100) ; 219 (%11011011) ; 427 (%10101011)
2 (%010) ; 25 (%11001) ; 183 (%10110111) ; 357 (%01100101)
3 (%011) ; 29 (%11101) ; 146 (%10010010) ; 285 (%00011101)
4 (%100) ; 26 (%11010) ; 110 (%01101110) ; 214 (%11010110)
5 (%101) ; 30 (%11110) ; 073 (%01001001) ; 142 (%10001110)
6 (%110) ; 27 (%11011) ; 036 (%00100100) ; 070 (%01000110)
Case 3:
' MUXBYTE = %11000 | ((Channel & %001) << 2) | ((Channel & %110)
>> 1)
Results for case 3:
1 (%001) ; 26 (%11010) ; 220 (%11011100) ; 429 (%10101101)
2 (%010) ; 28 (%11100) ; 183 (%10110111) ; 357 (%01100101)
3 (%011) ; 30 (%11110) ; 147 (%10010011) ; 287 (%00011111)
4 (%100) ; 25 (%11001) ; 111 (%01101111) ; 216 (%11011000)
5 (%101) ; 27 (%11011) ; 072 (%01001000) ; 140 (%10001100)
6 (%110) ; 29 (%11101) ; 036 (%00100100) ; 070 (%01000110)
Case 4:
Results for case 4:
1 (%001) ; 26 (%11010) ; 110 (%01101110) ; 214 (%11010110)
2 (%010) ; 28 (%11100) ; 219 (%11011011) ; 427 (%10101011)
3 (%011) ; 30 (%11110) ; 073 (%01001001) ; 142 (%10001110)
4 (%100) ; 25 (%11001) ; 183 (%10110111) ; 357 (%01100101)
5 (%101) ; 27 (%11011) ; 036 (%00100100) ; 070 (%01000110)
6 (%110) ; 29 (%11101) ; 146 (%10010010) ; 285 (%00011101)
--- In basicstamps@yahoogroups.com, Tracy Allen <tracy@e...> wrote:
> Hi Mohammed,
to
> -- Tracy
> >MUXBYTE var BYTE
> >Channel var BYTE
> >ADCVAL var BYTE
> >DIRA = %0111
> >HIGH CS
> > LOW CS
1)
> > HIGH CS
> >NEXT
> >END
using the correct MUXBYTE and using
SHIFTIN ADCOUT,CLK,MSBPRE,[noparse][[/noparse]ADCRes\9]
results in correct acquisition of channel voltages. but
SHIFTIN ADCOUT,CLK,MSBPRE,[noparse][[/noparse]ADCRes]
gives incorrect result.
Now I understand all the results I have obtained.
ADC0838 gives out a leading 0 followed by the MSB and the next 7 bits
of the data and the LSB continues to be available (as I have SE* held
high always) until CS* is made high. Also,The leading zero is
available before the clock pulse. (So, the bit stream available out
of ADCs DO pin is [noparse][[/noparse]0 A7 A6 A5 A4 A3 A2 A1 A0 A0]
Case 1:
So, using
results in stamp reading the 9 bits beginning with A7
i.e. [noparse][[/noparse]A7 A6 A5 A4 A3 A2 A1 A0 A0]
Since ADCRes is a byte sized, the MSB A7 is lost resulting in
ADCRes = [noparse][[/noparse]A6 A5 A4 A3 A2 A1 A0 A0] which is wrong
(I confirmed this by defining ADCRes as a WORD and using the above
SHIFTIN statement. THen rightshifted the ADCRes by 1 bit to get the
right answer).
Case 2:
When using
SHIFTIN ADCOUT,CLK,MSBPOST,[noparse][[/noparse]ADCRes]
results in stamp reading the 8 bits beginning with A7
i.e. [noparse][[/noparse]A7 A6 A5 A4 A3 A2 A1 A0] which is also stored as is in
ADCRes, giving the correct result.
Using the wrong MUX word and using the ADCRes\9 in the SHIFTIN as in
case 1 gave the correct result by sheer coincidence for my circuitry,
I think.
Tracy, Is my reasoning right?
Mohammed
--- In basicstamps@yahoogroups.com, "mohammedrasiq"
<mohammedrasiq@y...> wrote:
> Thanks Tracy. I am sorry there was a typo. I did not copy from the
> 1)
of
the
> 1).
correct
is
should
channels
> code I found at
> Case 1
> ADCVol VAR Word
> HIGH CS
> DEBUG "
> ",CR
> Voltage*100" ,CR
> DEBUG "
> ",CR
> 1)
> 1)
> DEBUG "
> ",CR
> END
> Case 2:
> 1)
> 1)
> Resulst for case 2:
> Case 3:
> >> 1)
1)
> Results for case 3:
> Case 4:
> Results for case 4:
> > Hi Mohammed,
data
> to
weird.
> > -- Tracy
> > >MUXBYTE var BYTE
> > >Channel var BYTE
> > >ADCVAL var BYTE
> > >DIRA = %0111
> > >HIGH CS
> > > LOW CS
> 1)
> > > HIGH CS
> > >NEXT
> > >END
