using analog circuit to create a constant signal from a pulse..
i have a pulsing signal (a horn that goes beep-beep-beep). it pulses
at 12V. i have a siren which i want to connect to it which requires
a constant 12V. right now as it is hooked up, the siren simply
pulses along with the horn. is there anyway (i'm thinking with
capacitors) to give myself a 12V constant?
a 74HC123. It is a dual oneshot. Just set your RC values for the
oneshot so that it will give you a constant output as long as it is
being triggered by the pulses. Once the pulses stop the oneshot will
stay high for as long as what you set the time constant to be by the
RC values you selected.
Jason
pulses
requires
