Networking
What is the Best way to hook up two or more stamps, and/or stamps to
other microcontrollers. I have hear about all the stuff of burning
out pins using serial commands... Basically, I want a stamp to be
dedicated to User I/O IE LCD, Key Board, Indicator lights and other
push buttons... The other Stamp will be dedicated to sensor
inputs...And then I will have a third Master Micro...Not sure which
yet.
Anyhow...Electronically, what is the best way to hook these up.
Eric
yet.
Eric
There are so many different
configurations you could use to hook up
stamps, AND a stamp is single-threaded,
so it has to wait for a connection.
AND, a stamp pin can sink or source
24 mA, which is quite a lot really,
and if you have two drivers contending
on the same line without some resistance
in between, you do burn out pins.
A simple 220 ohm resistor in series
with the pin is enough to prevent this.
AND, you probably want stamp A to
initiate comm with Stamp B, and then
allow Stamp B to initiate comm with
Stamp A (also known as multiple
masters)
If it was me, and I had two stamps
really close together (within 1 foot)
I would use P12 and P13 (and a ground
wire) to hook them
up. I'd put a 220 ohm resistor in
series on each stamp, to limit
contention current to something
non-destructive. Then I would
designate one of them the
master and one the slave.
I would have the master periodically
do a SEROUT, with flag pin and a
timeout, to see if the slave had
any data for me. I'd have the
slave periodically doing SERIN,
with flag pin and timeout, to
look for data from the Master.
That's what I'd do, but the Stamp
is a very flexible beast, which
gives you lots of other options.
to
other
> yet.
> Thanks,
> Eric
i have 6 stamps hooked up like this and have never had a problem in the 2
years the stamps
have been yakking amongst themselves.
ian
To: basicstamps@yahoogroups.com <basicstamps@yahoogroups.com>
Date: Sunday, June 29, 2003 4:03 AM
Subject: [noparse][[/noparse]basicstamps] Networking
>yet.
>Thanks,
>Eric
>from the same email address that you subscribed. Text in the Subject and
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
baud modes. The 220 ohm series resistor can
still be nice during development to save you
from inadvertent shorts -- but you are
absolutely right, if all nodes are properly
'open baud moded', this works nicely.
Have you used the 'flow pin' control with
this? I'm curious if the 'FPin' also
floats, and needs an external resistor
in 'open baud' modes.
--- In basicstamps@yahoogroups.com, "Ian Lawson" <irlawson@i...>
wrote:
> have a look at page 304 of the v2 stamp manual.
the 2
> years the stamps
> ian
> From: Eric <ESailer07@c...>
to
other
> >yet.
> >Thanks,
> >Eric
Subject and
i did allow for this in the circuit design
but have never implemented it as it doesn't
seem to be needed in my application.
it seems you don't need a resistor on the fpin
line just make sure they are all inputs.
regards ian
Date: Sunday, June 29, 2003 10:09 AM
Subject: [noparse][[/noparse]basicstamps] Re: Networking
>Excellent! I had forgotten about the 'open'
>the 2
>> years the stamps
>> ian
>to
>other
>> >yet.
>> >Thanks,
>> >Eric
>Subject and
