Flow control simulation with RTS and CTS
Archiver
Does anyone know how SERIN/SEROUT with flow control can be simulated
with industry standard RTS and CTS signals for RS-232?
I am trying to have a BS2 communicate to another BS2 via MAX3110 (SPI
UART), but find that receiving BS2 is seeing multiple characters for
each transmitted character.
I think I need some sort of hand-shaking to eliminate multiple
reception.
reception.
find it on our web site. Look in:
Downloads >> Nuts & Volts Columns >> Volume #3 >> Article #89
-- Jon Williams
-- Parallax
From: yellowniter [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AXfC9jGA2YXWkWxZ2NVr_WUKTpBetfKKhxmn6nmOnfK8UhY8_GkFGmpsxmgug1TC22xWCzXaxGZkwLajB2A_]yellowniter@y...[/url
Sent: Friday, June 27, 2003 10:04 AM
Subject: [noparse][[/noparse]basicstamps] Flow control simulation with RTS and CTS
reception.
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
I'm not sure if I can use it because I'm using SHIFTIN/SHIFTOUT
commands to send character from first BS2 to MAX3110 (in trasmitter)
and SHIFTIN/SHIFTOUT to receive from another MAX3110 to another BS2.
Since I'm not using SERIN/SEROUT, I cannot use the tradtional SERIN
with flow control.
I want to simulate flow control with extra pins on Stamp.
Can this be done?
--- In basicstamps@yahoogroups.com, "Jon Williams" <jwilliams@p...>
wrote:
> I did an article on flow-control for serial IO in Nuts & Volts.
You can
> -- Jon Williams
> -- Parallax
> From: yellowniter [noparse][[/noparse]mailto:yellowniter@y...]
simulated
(SPI
for
> reception.
Subject
> abuse@p...
levels, as was suggested by Allan in an earlier post.
-- Jon Williams
-- Parallax
From: yellowniter [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=_rHZlVHD6_zrnkWwJYzNcGEbn2k-D8Ds6AKfHBpBt_3v00g13tOJgDegb9RUsM5ZM_xLJL4VYvsrvdI]yellowniter@y...[/url
Sent: Friday, June 27, 2003 11:31 AM
Subject: [noparse][[/noparse]basicstamps] Re: Flow control simulation with RTS and CTS
Mr. William, I quickly scanned that article.
with flow control.
Can this be done?
You can
> -- Jon Williams
> -- Parallax
simulated
(SPI
for
> reception.
Subject
> abuse@p...
abuse@p....
Mr. Lane! (And also thanks to Mr. Tracy Allen and Al Williams.)
However, the only part I was able to glean from Mr. Lane's message
was WriteConfig, WriteData, and ReadData.
Mr. Lane, if you are reading this, could you please advise how
you "bit banged" to ReadConfig?
In addition, does anyone know where I can find good info. (i.e.
protocol) on how hand-shaking is done via RTC and CTS?
wrote:
> You are certainly free to use HIGH and LOW to adjust flow-control
pin
> -- Jon Williams
> -- Parallax
trasmitter)
> with flow control.
> Can this be done?
> You can
> > -- Jon Williams
> > -- Parallax
> simulated
> (SPI
> for
> > reception.
> Subject
> > abuse@p...
Subject
> abuse@p...
There is a distinction between DTE (data terminal equipment, e.g. a
computer) and DCE (data communication equipment, e.g. a modem, or a radio
that can module data onto a carrier). The RTS and CTS signals flow from one
to the other in opposite direction (I forget which is which). Each signal
required one conductor between the equipments, and one pin for each signal
on both. In any event, the equipment that wants to send data (the sender) to
a receiver raises the RTS line saying "I want to transmit data", then waits
until the receiver senses this, becomes ready to receive, then raises CTS to
say "OK, go ahead and send it!". The sender senses the CTS going high, and
then send the data.
Ideally, at any time, the receiver can lower the CTS line to pause the
sender's transmission (this could be because a buffer is full, or it may
take a short time to process the data just received before more data can be
received). The sender should then wait until CTS goes high again. This might
not happen, so the sender should include a timeout so that is the CTS line
does not go high within a specified amount of time, the process will halt.
Once the sender is done sending data, it should drop the RTS line low,
showing the receiver that it's now able to go on doing whatever it needs to
do.
Steve
Sent: Friday, June 27, 2003 7:08 PM
> Yes, I did use what Mr. Allan Lane suggested. Thank you very much
> pin
> > -- Jon Williams
> > -- Parallax
> trasmitter)
> > with flow control.
> > Can this be done?
> > You can
> > > -- Jon Williams
> > > -- Parallax
> > simulated
> > (SPI
> > for
> > > reception.
> > Subject
> > > abuse@p...
> Subject
> > abuse@p...
the write data command, and a CTS pin that is read in as part of the
read data command. The chip also has an IRQ pin that can be
activated in response to a number of conditions, including the
arrival of data into the receive fifo. That could be used to signal
the arrival of data to the Stamp so that it could service the UART.
Also, the current status of the receive buffer (empty or not) appears
on the data line out from the chip as soon as you bring chip select
low, so you don't even have to clock the chip to retrieve that bit of
information. This article: <http://www.emesystems.com/BS2IrDA>
includes control of RTS and read of the CTS line--in the circuit
shown, CTS is connected to a pushbutton, not to another Stamp, and
RTS controls an LED. I don't see much need to read the CONFIG
register. I think in most BASIC Stamp apps, you will write to it and
that's that.
To read the CONFIG it is true you would have to bit bang the first
two bits of the command (01), but the remaining 14 bits could be
retrieved with a shiftin. It is not necessary to bit-bang the read
data command, because the command is 00, so all you have to do is
leave the Din line low while you execute SHIFTIN.
The UART itself does not do any automatic handshaking or flow control
using its RTC/ETS lines. That is up to your program.
How RTC and CTS are used for flow control depends enormously on how
your system is set up. Master-slave, peer to peer etc. Here
scenarios that might be of interest to you.
<http://www.emesystems.com/BS2rs232.htm>.
You mentioned "multiple reception". I don't know what you mean by that.
-- regards
Tracy Allen
mailto:tracy@e...
>pin
>> -- Jon Williams
>> -- Parallax
>trasmitter)
>> with flow control.
>> Can this be done?
>> You can
>> > -- Jon Williams
>> > -- Parallax
>> simulated
> > (SPI
>> for
> > > reception.
What I mean by "multiple reception" is this:
First BS2 gets data typed in from PC (using SERIN 16) and then sends
data (ASCII character) to 1st MAX3110 which sends it to 2nd MAX3110.
Then data goes to 2nd BS2. The 2nd BS2 is hooked to parallel LCD (2
rows of 16 characters each).
The 2nd BS2 is supposed to receive the data, then display it on the
LCD.
What ends up happening is that when I type a character on PC, it
shows up 32 times on LCD (i.e. fills it up. If it was 4 rows, it
might even fill all 4 rows.)
I suspect that RX buffer in 2nd MAX3110 is not being cleared after it
is read. Thus 2nd BS2 keeps reading the same character.
The program for 2nd BS2 is set up to (pseudo code):
Readbuffer:
Read RX buffer from MAX3110 (using Mr. Allan Lane's suggestion)
Display on LCD
Increment cursor to next position on LCD
Goto Readbuffer
I need a way of determining if the RX buffer is truly "new data", or
old data. I think the code is reading the RX buffer many many times,
and filling the LCD screen.
I hope someone can help out.
--- In basicstamps@yahoogroups.com, Tracy Allen <tracy@e...> wrote:
> The UART itself has RTS pins that are set high/low or read as part
of
the
signal
appears
of
and
> that's that.
control
that.
> -- regards
> Tracy Allen
> mailto:tracy@e...
> >pin
> >> -- Jon Williams
> >> -- Parallax
CTS
> >trasmitter)
BS2.
SERIN
> >> with flow control.
> >> Can this be done?
<jwilliams@p...>
> >> You can
> >> > -- Jon Williams
> >> > -- Parallax
> >> simulated
MAX3110
> > > (SPI
characters
> >> for
> > > > reception.
getting by without it.
What I need to know is how to use CTS/RTS and/or IRQ to read RX
buffer data only once. Time saving isn't critical, so I'd prefer to
stay away from using IRQ.
Is there an easy way to use CTS/RTS in a master sender & slave
receiver format? Or if IRQ is the "best" way, does anyone have some
simple pseucode code for that?
of
the
signal
appears
of
and
> that's that.
control
that.
> -- regards
> Tracy Allen
> mailto:tracy@e...
> >pin
> >> -- Jon Williams
> >> -- Parallax
CTS
> >trasmitter)
BS2.
SERIN
> >> with flow control.
> >> Can this be done?
<jwilliams@p...>
> >> You can
> >> > -- Jon Williams
> >> > -- Parallax
> >> simulated
MAX3110
> > > (SPI
characters
> >> for
> > > > reception.
1. You can read the incoming CTS state on 'ReadData'.
2. You can set the outgoing RTS state on 'WriteData'.
3. I don't think the MAX3110 does 'automatic' hardware
handshaking, where it automatically sets CTS low when
the 8-byte FIFO is full.
4. You CAN use the MAX3110 '232 drivers' to make a
TTL level RTS and CTS, tie these to BS2 pins, and
directly read and write them in your code.
--- In basicstamps@yahoogroups.com, "yellowniter" <yellowniter@y...>
trasmitter)
> with flow control.
> Can this be done?
> You can
> > -- Jon Williams
> > -- Parallax
> simulated
> (SPI
> for
> > reception.
> Subject
> > abuse@p...
T_Out and T_In. You start with the
Clock line LOW, ChipSelect HIGH,
T_Out set to $4000, which is the
'ReadConfig' command. T_In set to
0, to be filled during the routine.
You Drop the ChipSelect line. This makes
the DataIn line from the 3110 valid.
Repeat16Times:
You read DataIn line as T_In.Bit0
You then read the top bit of T_Out.
If its a 0, you output a 0 on DataOut,
if its a 1, you output a 1 on DataOut.
You then pulse the Clock line High, then
Low. This clocks out your first bit to
the 3110, and makes the DataIn line valid
for the next DataIn bit.
You shift T_In up one bit, then read the
DataIn state into T_In.Bit0.
Shift T_Out up one bit.
Repeat the above 16 times. What you've done
is clock out T_Out to the 3110, and clocked
the 16-bit word from the 3110 into T_In.
Then, raise '/ChipSelect' to deselect the
3110.
I call this 'bit-banging' because for each
bit in and out, you are explicitly
controlling the state of data and clock
pins.
If the top bit of the 16-bit word read from the
3110 is '0', then no data was read from the 3110.
This '0' means the Rx FIFO is empty, and the
word just read should be tossed.
wrote:
> Thank you Mr. Allen. I will study the materials you suggested.
sends
MAX3110.
(2
> LCD.
it
> Readbuffer:
> Display on LCD
> Goto Readbuffer
times,
part
> of
> the
> signal
UART.
> appears
select
bit
> of
and
> and
> > that's that.
first
read
> control
how
by
> that.
> > -- regards
> > Tracy Allen
> > mailto:tracy@e...
much
message
<jwilliams@p...>
control
> > >pin
> > >> -- Jon Williams
> > >> -- Parallax
and
> CTS
> > >trasmitter)
another
> BS2.
> SERIN
> > >> with flow control.
> > >> Can this be done?
> <jwilliams@p...>
Volts.
> > >> You can
#89
> > >> > -- Jon Williams
> > >> > -- Parallax
CTS
> > >> simulated
> MAX3110
> > > > (SPI
> characters
> > >> for
multiple
> > > > > reception.
>LCD.
>Readbuffer:
>Display on LCD
>Goto Readbuffer
Change to some other pin than Pin 16.
I think this is it. I will try your suggestion of monitoring bit15
(MSB) of read data. If bit15=0, then then ignore data on bit0-7.
If bit15=1, then use data on bit0-7.
Someone else suggested that I don't use pin 16 of BS2 to receive data
from PC keyboard. Why not? If I use SERIN 16, Baudmode, [noparse][[/noparse]char], is
there some side-effect?
I'm simply using pin16 to get data that is typed in from PC's
keyboard (and save a Stamp pin).
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> Yes.
<yellowniter@y...>
> sends
> MAX3110.
> (2
the
> > LCD.
after
> it
> > Readbuffer:
> > Display on LCD
> > Goto Readbuffer
> or
> times,
> part
> > of
of
> > the
> > signal
> UART.
> > appears
> select
> bit
> > of
circuit
> and
it
> > and
> > > that's that.
> first
be
> read
is
> > control
> how
> by
> > that.
> > > -- regards
> > > Tracy Allen
> > > mailto:tracy@e...
> much
Williams.)
> message
> <jwilliams@p...>
> control
> > > >pin
> > > >> -- Jon Williams
> > > >> -- Parallax
> and
> > CTS
SHIFTIN/SHIFTOUT
> > > >trasmitter)
> another
> > BS2.
tradtional
> > SERIN
> > > >> with flow control.
> > > >> Can this be done?
> > <jwilliams@p...>
> Volts.
> > > >> You can
Article
> #89
> > > >> > -- Jon Williams
> > > >> > -- Parallax
and
> CTS
> > > >> simulated
> > MAX3110
> > > > > (SPI
> > characters
> > > >> for
> multiple
> > > > > > reception.
>Thank you Mr. Lane.
Characters are echoed using the Sin/Sout port (Port 16). This is by design.
Bruce Bates
>At 08:07 PM 6/27/03 +0000, yellowniter wrote:
> >Thank you Mr. Lane.
>Bruce Bates
Sorry ! I thought the Debug Port was being used in the MAX31xx configuration.
What is it that you're trying to accomplish using the two MAX chips ?
Bruce Bates
I simply monitor bit15 of ReadData and discard it if it is 0, and use
it if it is 1.
I don't even need to worry about CTS or RTS...although it would be
nice to know how it is supposed to work for future project.
Mr. Lane, how does the MAX3110 "know" if bit15 should be set to 1 or
0 by MAX3110? i.e. How does it know that "RX buffer was already
read, so next time a ReadData is performed, bit15 should be set to
0", or "RX buffer is not yet read, thus next bit15 should be set to 1
on next ReadData"? I've read the MAX data sheet, but could not find
good info. on behavior of bit15.
Bruce, I'm using pin16 just as a convenient way to test my
hardware/software.
Final project will not be getting input from PC keyboard of course.
wrote:
> Yes.
<yellowniter@y...>
> sends
> MAX3110.
> (2
the
> > LCD.
after
> it
> > Readbuffer:
> > Display on LCD
> > Goto Readbuffer
> or
> times,
> part
> > of
of
> > the
> > signal
> UART.
> > appears
> select
> bit
> > of
circuit
> and
it
> > and
> > > that's that.
> first
be
> read
is
> > control
> how
> by
> > that.
> > > -- regards
> > > Tracy Allen
> > > mailto:tracy@e...
> much
Williams.)
> message
> <jwilliams@p...>
> control
> > > >pin
> > > >> -- Jon Williams
> > > >> -- Parallax
> and
> > CTS
SHIFTIN/SHIFTOUT
> > > >trasmitter)
> another
> > BS2.
tradtional
> > SERIN
> > > >> with flow control.
> > > >> Can this be done?
> > <jwilliams@p...>
> Volts.
> > > >> You can
Article
> #89
> > > >> > -- Jon Williams
> > > >> > -- Parallax
and
> CTS
> > > >> simulated
> > MAX3110
> > > > > (SPI
> > characters
> > > >> for
> multiple
> > > > > > reception.
good way to get data from the PC.
Note you could interface the keyboard directly,
which is not what you are doing currently,
I assume -- but some people have done this,
in which case you can't use SERIN, but there
must be some other interface to the PC
keyboard...
I hope my hints helped. In retrospect, it
doesn't seem like you need 'true' handshaking,
you only needed that factoid about the top
bit.
wrote:
> Thank you Mr. Lane.
data
is
> wrote:
> > Yes.
They say:
"R = 1, Data is available to be read or is being
read from the receive register or FIFO"
"R = 0, Receive register and FIOF are empty".
It's only implied (and I verified this in my
own code) that if that bit is 0, then you
did a read when no data was available, and
the data byte returned is not valid. You've
now shown that it just returns the last byte
read each time you do that.
Usual UARTS have a bit which you can check
to determine if data is ready. On the 3110,
the same read which would find if it was
ready could just as well get the byte, and
save time. So the 3110 ONLY sets this bit
if you are doing a 'new read' of data it
has already received for you. It only
sets this bit (and gives you the byte)
if it had a byte ready before you started
your read.
wrote:
> Mr. Lane, this works! Thank you for your insights!
use
> it if it is 1.
1
find
> hardware/software.
> wrote:
> > Yes.
> <yellowniter@y...>
