SPI with SHIFTIN/SHIFTOUT?
I need to simulate Motorola's SPI for communication between Basic
Stamp 2 and MAX3111 (SPI UART).
Does anyone know if it is possible to communicate with a SPI device
using Shiftin/Shiftout (or any other BS2 commands)?
MAX3111 send out 16 bit data while expecting to receive 16 bit data
simultaneously.
simultaneously.
same time with either of those functions. It is possible in PBASIC code
though -- I just did this for use with the Sony PlayStation game
controller. Your code may look something like this:
Shift_IO16:
LOW CS
FOR idx = 15 TO 0
DOut = outWord.LOWBIT(idx)
HIGH SClk
inWord.LOWBIT(idx) = DIn
LOW SClk
NEXT
HIGH CS
RETURN
Please understand that I wrote this very quickly after a *brief* look at
the spec sheet -- please confirm my logic and test before using it.
Also note that this code will run significantly slower that SHIFTOUT and
SHIFTIN, but does give you full-duplex capability.
-- Jon Williams
-- Parallax
From: yellowniter [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-aIQ37tVjnBszfugeg-7T-0Ln0tZ5e1Qw5s5kXzdK8Oew2aPiXX6iP7BT0XMb7cvVVvUtZ_hPbqSvCsDXp6uyA]yellowniter@y...[/url
Sent: Thursday, June 26, 2003 8:59 AM
Subject: [noparse][[/noparse]basicstamps] SPI with SHIFTIN/SHIFTOUT?
simultaneously.
Your use of Yahoo! Groups is subject to
This message has been scanned by WebShield. Please report SPAM to
abuse@p....
I wrote a library to interface the SPI Max3110.
(the 3111 is a 3.3 volt part -- is that what you
want?)
There are 4 major commands you need to implement.
1. WriteConfig -- you can safely ignore the bits
coming back, so can write this with 'SHIFTOUT'.
2. ReadConfig -- You need the return values, so
you'll have to implement this one in 'bit-bang'
mode.
3. WriteData -- can ignore the return, use
SHIFOUT:
T1 = (P1_3100Var | $8000) & $BFFF ' Clear bit 14/0
LOW P1_3100_SEL
SHIFTOUT P1_3100_DO, P1_3100_CLK, MSBFIRST, [noparse][[/noparse]T1\16]
HIGH P1_3100_SEL
RETURN
(note P1_3100Var was set with the data out value first)
4. ReadData -- Set DataOut (Chip's 'DIN') LOW. This
tells the chip we're doing a 'readdata'. We can then
use 'SHIFTIN' to get the data.
P1_3100_ReadData: ' P1_3100_DO MUST be low during this...
T1 = $0000 ' Clear ALL Bits
LOW P1_3100_Sel ' Select it. FIRST RxBit becomes VALID
SHIFTIN P1_3100_DI, P1_3100_CLK, MSBPRE, [noparse][[/noparse]T1\16] ' on /CS drop, DI
becomes Valid.
' DI ONLY valid when Clock LOW.
HIGH P1_3100_SEL ' Deselect chip...
P1_3100Var = T1
RETURN
In 'bit-bang' mode, you'll write a subroutine to properly
raise and lower the 'clock' line, and write the 'DataOut'
and read the 'DataIn' lines as appropriate.
I originally wrote my library using a 'ShiftOut' subroutine,
which sent one 16-bit word while reading in the other
16-bit word. Then I found I only had to do that for
'ReadConfig'. Using SHIFTIN/SHIFTOUT for read-data and
write-data speeds things up a lot (16 KBits/Sec on BS2,
more on BS2sx).
--- In basicstamps@yahoogroups.com, "yellowniter" <yellowniter@y...>
> simultaneously.
http://www.wd5gnr.com/suart.htm
This is for a 3110 which should be about the same.
Al Williams
AWC
* 8 channels of PWM
http://www.al-williams.com/awce/pak5.htm
> From: yellowniter [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=OxrQPq0z4UX6pdVI-fiNCumCLVNzJjGYkC0y2sBSIcfS9meDB3horLof1SGRYL8o4qC0aXq142IfblCCAe8]yellowniter@y...[/url
> simultaneously.
http://www.emesystems.com/BS2IrDA.htm
While the article focuses on the IrDA capability, the code is the
same for hardwired except for a configuration change.
-- Tracy
>simultaneously.
