How to handle a latching valve/relay - mosfet ?
--- In basicstamps@yahoogroups.com, "Jonathan Peakall"
<jpeakall@m...> wrote:
> Hi All,
> What is the best way to use a latching valve or relay? The polarity
to the
> relay/valve must be reversed to open/close the valve.
> Jonathan
> www.madlabs.info
if you are looking for a low power consumption - high power device,
look at something like a MOSFET. the mechanical coil stuff will use
more power and that is the benefit of a latching relay.
The latching relay will change state with a pulse and remain in the
current state, but I think that if you need the power to operate the
solenoid, you will have more then enough to power a MOSFET in
addition to the solenoid.
IF you are talking a piloted air(gas) valve that opens the pressure
and pressure then holds the valve open, that would eleminate the need
for an electircal power source
Dave
> Hi All,
to the
> Jonathan
> www.madlabs.info
Dave
Omron has some low power DPDT relays. The switch portion can handle 0.5
amp at 125 volt AC or 1 amp at 30 volts DC.
Non-latching (G6H-2) can be actuated with 5 volts and 28 milliamps.
Latching single coil (G6HU-2) can be actuated with 5 volts 20 milliamps.
Latching dual coil (G6HK-2) can be actuated with 5 volts 50 milliamps.
Digi-Key has some of the non latching in stock $4 a piece, Digi-Key#:
Z740-ND. They don't appear to have any of the low power single-coil
latching types in stock (Digi-Key#: G6HU-2-DC5-ND). But they do have some
dual coil latching types (Digi-Key#: Z965-ND) $4.85 a piece.
28 milliamps is just under the limit for a Stamp pin and 50 is much more,
but thats what transistors are for right?
I think they are sealed relays. I can't find it in the spec sheet, but I
have some G6H-2 and they look sealed to me. Of course you should get
confirmation from Omron before using them in a hazardous environment.
Chuck Chargin Jr.
> > Hi All,
>to the
> > Jonathan
> > www.madlabs.info
>Dave
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
