60 basic stamps connected (to one PC)
How can I read the data storage and real time data
from a basic stamp (from a total of 60 stamps serially
connected)
using only one PC.
I read that serially, is that possible to
connect:
pin0 from stamp 1 to
the pin1 of satmp2,
pin0 from stamp 2 to pin1 to stamp3....
pin0 from stamp 59 to pin1 from stamp60
and finally pin0 from stamp 1 to pin1 from
stamp0.
But if all of this is right what about
the amount of variables "w" (word variables)
I read that there is a limit of 12.
How can read the data from stamp
number 34 (for example)
Thanks, Joe
__________________________________
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
http://sbc.yahoo.com
connected)
using only one PC.
connect:
the pin1 of satmp2,
stamp0.
Thanks, Joe
Do you Yahoo!?
Stamps
http://www.engr.udayton.edu/faculty/jloomis/ece445/stamp/nv_mag/st_ap28.pdf
This is the page I got it from it has a bunch of other projects
This is a great book on serial communications with the stamp
http://www.lvr.com/spc.htm
Sent: Monday, June 23, 2003 4:16 PM
Subject: [noparse][[/noparse]basicstamps] 60 basic stamps connected (to one PC)
> connected)
> using only one PC.
> connect:
> the pin1 of satmp2,
> stamp0.
> Thanks, Joe
> Do you Yahoo!?
driven network. Have the PC send out a 'query'
message, which ALL Stamps receive. Have each
BS2 have a unique 'address' (fixed byte) which
both the PC and the BS2 knows about.
The 'query' message should include the address
byte of the desired BS2. The 'other' BS2's
should read the message and ignore it. The
addressed BS2 can then send a response message.
This takes one byte of address space in each
BS2 -- which is easily doable. You should also
have a time-out and retry on the PC side, in
case the desired BS2 is busy, and misses the
message, and so does not respond.
> connected)
> using only one PC.
> connect:
> the pin1 of satmp2,
> stamp0.
> Thanks, Joe
> Do you Yahoo!?
Do you know if there ara some information and
examples about
it, at Parallax docs. ?
Thanks: Joe
--- Allan Lane <allan.lane@h...> wrote:
> You can use a relatively in-expensive RS-485
> serially
> > connected)
> > using only one PC.
> > connect:
> > the pin1 of satmp2,
> > stamp0.
> > Thanks, Joe
> > Do you Yahoo!?
> Text in the Subject and Body of the message will be
> ignored.
Do you Yahoo!?
Look for the '75176' appkit project.
I don't think Parallax sells the appkit itself
anymore, but this PDF has some good information.
Note a minimal '485 network requires 3 wires --
A, B, and Gnd. It requires some terminating
resistor at both ends of the network. It also
requires a pull-up on A and a pull-down on B
to get a guaranteed 'idle' state when no
drivers are driving.
It's good for 4,000 feet at 19,200 baud,
though. Do a search on 'RS485' to get more
info from other posts.
> Thanks Allan:
> examples about
> Thanks: Joe
> > serially
> > > connected)
> > > using only one PC.
> > > connect:
> > > the pin1 of satmp2,
> > > stamp0.
> > > Thanks, Joe
> > > Do you Yahoo!?
> > ignored.
> Do you Yahoo!?
http://www.melabs.com/resources/links.htm
I found the AppNote 1057, 'bullet-proofing
RS485' to be the most useful. The
'Safe Mode' of 750 ohm pullup from A to
VCC, 750 ohm pull-down from B to Gnd, and
130 ohm from A to B to be very useful.
> Thanks Allan:
> examples about
> Thanks: Joe
> > serially
> > > connected)
> > > using only one PC.
> > > connect:
> > > the pin1 of satmp2,
> > > stamp0.
> > > Thanks, Joe
> > > Do you Yahoo!?
> > ignored.
> Do you Yahoo!?
