"through hole" socket termination definition
Archiver
hey everyone,
I'm trying to buy a ZIF (zero insertion force) socket from
digikey.com, but it says that the socket has "through hole"
terminations. What does that mean (I know what a DIP and wire wrap
termination is like)? Could I plug the zif into a wire wrap socket or
breadboard? Thanks!
breadboard? Thanks!
That means the socket is meant to be soldered into a PC Board. It will not
fit into a socket.
Im not sure what you need, if you want one to insert into an IC Socket.
Digikey has a very good technical department. If you call or e-mail them they
will help you get what you want. I have used that department many times.
Alan Bradford
Plasma Technologies
> hey everyone,
> breadboard? Thanks!
> Body of the message will be ignored.
circuit board as opposed to a surface mount design.
jim
http://www.geocities.com/jimforkin2003/
From: Sam [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=maRcDiED-xwzqDgu_mvq44QYM_mEyHR8dglD9n023INj5nW2O3LwGDLaRuj21CmdAQOfaIKjSc7iqyQdirM]hard-on@t...[/url
Sent: Monday, June 23, 2003 9:54 AM
Subject: [noparse][[/noparse]basicstamps] "through hole" socket termination definition
hey everyone,
breadboard? Thanks!
> hey everyone,
> breadboard? Thanks!
A mechanical description would be that the part has legs that can be
inserted thru holes drilled in the PC board. these are typical of
the capapillar chips we are so used to.
ZIF type of sockets can be used for repitious work like programming
lots of chips.
since the ZIF sockets are often thur-hole and also often on 0.6"
centers, you may want to get a 0.3" to 0.6" adapter. this kinda
looks awkward, but you can put in a socket, the adapter, then the ZIF
socket so that you can then use the mini chips.
Dave
0.600" spacing chips. Most commercial programmers use these sockets.
> or
> > breadboard? Thanks!
> lots of chips.
> Dave
