Subroutines that go to other bs2sx pages
Archiver
If I have a subroutine on memory page 1 that runs a second page that
then comes back to the first page with some flag that puts execution
right back into the subroutine, will the subroutine return bring me back
to the right place on page 1?
E.g., let's say page 1 looks like
Return_pointer var nib
If return_pointer =3 then rp100
Loopstart:
command...
command...
gosub memory_routine
command...
Goto loopstart
Memory_routine:
Command
Command
Return_pointer = 3
Run 2
Rp100:
Return_pointer = 0
return
Page 2 does something and then runs page 1.
I guess I'm really wondering if transferring program control out of the
subroutine and to another page and then coming back into the subroutine
will confuse its stack. Or, hopefully, in the above example will
control leave the subroutine memory_routine at the "return" command and
go to the command right after the "gosub memory_routine" command?
bob
Loopstart:
command...
command...
command...
Goto loopstart
Memory_routine:
Command
Command
Return_pointer = 3
Run 2
Rp100:
Return_pointer = 0
return
bob
certain scratchpad RAM location which contains the program slot
number of the currently running program) and thus compromise the
GOSUB/RETURN stack. After all it should - to my opinion - be ok to
run a program from da different memory slot from within a subroutine.
Regards
Adrian
to another program however the rest of the RAM is as you described it.
You can however work around this, as shown by an example in Scott Edwards
book;
This is the program in slot 0
' PROGRAM: example3_pgm0
'{$STAMP BS2SX, Example3_pgm1}
toLabel VAR Nib
retLabel VAR Nib
msg1_ CON 1
msg2_ CON 2
msg3_ CON 3
r1_ CON 1
r2_ CON 2
r3_ CON 3
PAUSE 1000
BRANCH retLabel,[noparse][[/noparse]start,r1,r2,r3]
start:
TOLABel= msg3_ ' "Gosub" message 3
RETLabel= r1_ ' ..then "Return" to r1
RUN 1 ' Do it (hop to program 1).
R1:
TOLabel= msg2_ ' "Gosub" message 3
retLabel= r2_ ' ..then "Return" to r1
R2:
toLabel= msg1_ ' "Gosub" message 3
retLabel= r3_ ' ..then "Return" to r1
r3:
DEBUG CR,"Done."
This is the program in slot 1
' PROGRAM: example3_pgm1
toLabel VAR Nib
retLabel VAR Nib
msg1_ CON 1
msg2_ CON 2
msg3_ CON 3
r1_ CON 1
r2_ CON 2
r3_ CON 3
BRANCH toLabel,[noparse][[/noparse]null,msg1,msg2,msg3]
null:
RUN 0
msg1:
DEBUG "Moe",CR
RUN 0
msg2:
DEBUG "Larry",CR
RUN 0
msg3:
DEBUG "Curly",CR
RUN 0
I havent actually run it, but it's straight from the book.
Regards
Rohan
From: Adrian Schneider [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=oogaB3V8bB8WA5Fkd4j1-OwK_XVkhP9o_kaEJ6V_v9X1pZlI47DJx-S8Vdi7P30-px1mjhlauADKctA6OyxW16JRWRnmGv4]adrian.schneider@t...[/url
Sent: Monday, 23 June 2003 7:38 PM
Subject: [noparse][[/noparse]basicstamps] Re: Subroutines that go to other bs2sx pages
As far as I know the RUN command does not alter RAM (except for a
Regards
Adrian
http://www.emesystems.com/BS2SX.htm#Crossbank
always a good source for all kinds of stamp questions that never
should be missed.
Regards
Adrian
command clears the return stack. Also it clears the for-next logic,
so you can't do crossbank calls from within a for-next loop. I
haven't tried it yet with most of the new PBASIC 2.5 control
structures, like DO xxx ...LOOP. It depends on how those were
implemented in the basic PBASIC.
I would recommend sticking to a simple branch structure at the top
program level. That does not look hard at all in your example
program. If you have to enter that routine from several places in
your main program, then you can put a crossbank return label at each
of the possible return points in the main program,preset that return
label in a variable and GOTO your Memory_routine.
-- Tracy
>Loopstart:
> command...
> command...
> command...
>Goto loopstart
>Memory_routine:
>Command
>Command
>Return_pointer = 3
>Run 2
>Rp100:
>Return_pointer = 0
>return
>Thanks
>bob
