Storing a lookup table in EEPROM and looking it up!
I would like to store a lookup table in the BS2 EEPROM, which is easy to do.
I want to find the index of a value in the table which is nearest to a vlue
in a variable. What is a good algorithm to use with the BS2?
For example, if the table looks like this:
Index, Value
0, 0
1, 1
2, 2
3, 5
4, 10
5, 20
6, 100
A variable "x" contains the number 8. Looking that up, the algorithm should
return an index of 4, since 10 is the nearest number.
Thanks!
Steve
Index, Value
0, 0
1, 1
2, 2
3, 5
4, 10
5, 20
6, 100
Thanks!
Steve
If the list is short, like the example with 7 entries, then a
straight numeration would work...
'{$PBASIC 2.5}
' enter with variable X
do until Y>X
read idx,Y
idx=idx+1
loop
' come here with Y>X, idx the index of Y
' the previous value in the table is less than X
' if you want the one that is closest in absolute value, need to do more..
if idx>1 then
read idx-1,Z
if X-Z<Y-X then Y=Z
endif
' come here with the Y= value closest to X.
A short list like that can also easily be handled by a lookdown/lookup command:
lookdown X,>[noparse][[/noparse]0,1,2,5,10,20,100],idx
lookup idx, [noparse][[/noparse]0,1,2,5,10,20,100],Y
but for long tables that eats up a lot of memory, and it cannot be
used for tables that change at run time.
If the table of values is much longer, then a binary search in a DATA
table is the most efficient. You start in the middle of the table and
zero in on your value with a series of greater/less than decisions.
Say the table has 1024 entries, then you get your value with 10
decisions.
-- Tracy
>Index, Value
>0, 0
>1, 1
>2, 2
>3, 5
>4, 10
>5, 20
>6, 100
>Thanks!
>Steve
