BS Menu System
Archiver
Hi all,
Does anyone know of any docs or websites that talk through coding some form of
menu/user input system on a BS2?
I'd like to have some way of the user entering a couple of numeric values using
just a couple of buttons (UP, DOWN, ENTER sort of thing). And rather than
reinvent the toaster, I thought I'd see if anyone had written a nice article on
it at all???
Cheers for any help all
Kev/.
kevp.com
it at all???
Kev/.
kevp.com
with windows, but you can download compilers for free all over the
web). Here's a page that describes using QBasic to talk to the stamp:
http://www.pacifier.com/~mcginty/qbstamp.htm
make sure you change the baud rate code to match the basic stamp
you're using (he used a bs2).
--- In basicstamps@yahoogroups.com, "Kev Pearce \(kevp.com\)"
<email.me@k...> wrote:
> Hi all,
some form of menu/user input system on a BS2?
values using just a couple of buttons (UP, DOWN, ENTER sort of
thing). And rather than reinvent the toaster, I thought I'd see if
anyone had written a nice article on it at all???
> Kev/.
> kevp.com
on the stamp with an LCD and a couple of buttons connected to the stamp, as
a stand alone system, no pc. These values are then used by the stamp to
check thresholds on a number of sensors and alert the user if these user
configureable thresholds are exceeded.
Cheers
Kev/.
Sent: Friday, June 20, 2003 2:16 PM
Subject: [noparse][[/noparse]basicstamps] Re: BS Menu System
> I would use QBasic programming language (compiler should be included
> > Hi all,
> > Kev/.
> > kevp.com
I would look into a graphic display from Parallax which you can
interface to your BASIC Stamp very easily. Follow the link below for
more info:
http://www.parallax.com/detail.asp?product_id=30053
~ed
> QBasic??? Maybe I should be a little clearer, I'm after a menu
system to run
stamp, as
stamp to
user
> Cheers
> Kev/.
> From: "Sam" <hard-on@t...>
included
stamp:
> > > Hi all,
coding
numeric
> > > Kev/.
> > > kevp.com
Subject and
>Cheers
>Kev/.
In psuedo-code, something like this...?
' in0 is "Enter"
' in1 is "UP" increment for each press
' in2 is "DOWN" decrement for each press
For prompt=1 to numberOfPrompts
gosub displayPromptLine1
read currentValueOfParameter, X
Do until enterbutton=1
gosub displayParameterLine2 ' display X on line 2, clearing space.
buttonStates=inA ' three buttons, up, down, enter
buttonsX=buttonStates ^ oldStates & buttonStates ' transition 0-->1
enterButton=buttonsX.bit0
X=X + buttonsX.bit1 - buttonsX.bit2
loop
' continue here when enter is pressed
next ' next parameter, until all are entered
This kind of program tends complicate itself, the more you think
about the niceties! For example, you might want it to
auto-increment if the button is held down for a while. (The BUTTON
command does have autoincrement built in.)
The logic in the above program tests for a 0->1 transition on the
buttons. If there are a lot of parameters, you might want to present
them in a menu first, for the user to choose which one to change.
Some parameters, like time/date setting for example, or text entry,
can require special coding.
-- best regards
Tracy Allen
http://www.emesystems.com
mailto:tracy@e...
interface to set the time, and ten lights representing the digits 0-9. When
it displayed the time, the lights flashed one digit, paused, then the next
digit, etc. You tapped the button one to start the "set" mode. Then, the
lights cycled slowly through the digits, and you simply hit the button on
the correct digit. Four times through for hours and minutes, then set mode
was done and went back to display mode.
It would be a simple matter to make a couple of other buttons act as a down
and up counter, and use 7 segment displays to display the values instead of
single LEDs.
Steve
Sent: Friday, June 20, 2003 1:11 PM
Subject: [noparse][[/noparse]basicstamps] BS Menu System
> Hi all,
using just a couple of buttons (UP, DOWN, ENTER sort of thing). And rather
than reinvent the toaster, I thought I'd see if anyone had written a nice
> Kev/.
> kevp.com
Thanks once again...
Kev/.
Sent: Friday, June 20, 2003 5:36 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: BS Menu System
> >QBasic??? Maybe I should be a little clearer, I'm after a menu system to
run
as
> >Cheers
> >Kev/.
> ' in0 is "Enter"
> loop
> -- best regards
> Tracy Allen
> mailto:tracy@e...
