Memsic Accelerometer and tilt sensor
Hey,
I've been reading this thread and wondering if Memsic accelerometer used in the
"tilt" scheme is fast enough for a two wheeled robot like the nBot at this
website.
http://www.geology.smu.edu/~dpa-www/robo/nbot/
Dave Cousins
Date: Tue, 17 Jun 2003 21:08:49 -0400
Subject: Re: Mounting a Memsic accelerometer
I've been following this thread; I am also using Memsic accelerometers.
Just to make sure that I am clear about what you are referring to, have
you been using the Series ED stamped DIP socket? If you have, how do
you get the supply voltages to pins 4 and 8?
On Tuesday, June 17, 2003, at 11:56 AM, azeasi@a... wrote:
> Actually the device does fit into a standard (low cost) 6 pin (or 8
> pin) IC
> socket. The 6 pin sockets are typically used for optoisolators and of
> course
> the 8 pin more readily available. You can't use the "machined" type IC
> socket so
> they must be the "solder tab" type of socket. If you really want to
> use an in
> line socket strip, that is also available. The sockets (and socket
> strips) I
> am using for the Memsic devices are from a company called OST (On Shore
> Technology) on-shore.com.
> You may want to trim the leads on the memsic device to make it sit all
> the
> way down into the socket.
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
website.
Dave Cousins
> pin) IC
> course
> socket so
> use an in
> strips) I
> the
Do you Yahoo!?
