Shaking Relays
Hi everyone,
I've made a program to read in 3 switch values and the status of the
switches determines how the output pins must be.
PIN 0=switch 1
PIN 1=switch 2
PIN 2=switch 3
PIN 4=output 1
PIN 5=output 2
PIN 6=output 3
I programmed my BS2P-24 as following:
low 4
low 5
low 6
main:
inA=outB
goto main
I use a ULN-2003A to amp. the voltage also the current. With this voltage I
control 3 relays. The problem is that the relays start to shake when I
download the program into my controller. I guess that the command brings the
outputs very short on a 0 status even when my input voltage is 5V. Does
anybody have an idea to solve my program so the relays won't shake anymore.
Kindly regards,
Tim
PIN 0=switch 1
PIN 1=switch 2
PIN 2=switch 3
PIN 4=output 1
PIN 5=output 2
PIN 6=output 3
low 4
low 5
low 6
main:
inA=outB
goto main
Kindly regards,
Tim
is what's causing your relays to chatter until you make relay control pins
outputs and low. What you can do to prevent the chatter is connect 10K
pull-down
resistors to the relay-control pins. These will hold the inputs to the
ULN2003 low until your Stamp program makes a change to a pin's output state.
-- Jon Williams
-- Parallax
In a message dated 6/17/2003 8:55:17 AM Central Standard Time,
peter.christiaen@s... writes:
> Hi everyone,
> PIN 0=switch 1
> PIN 1=switch 2
> PIN 2=switch 3
> PIN 4=output 1
> PIN 5=output 2
> PIN 6=output 3
> low 4
> low 5
> low 6
> main:
> inA=outB
> goto main
> Kindly regards,
> Tim
problem once when I tried to operate four relays at the same time. When I
operated them sequentially there was no problem. When I tried to turn them on at
the same time they would all chatter ( turn off and on very quickly). The
problem was fixed by going to a more powerful power supply, one that was capable
of running the Stamp & relays & LED without dropping its voltage. I hope that
helps. Larry
From: TLD-NV [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=mGobMPxXtTTxJvLjX2fMAY_mTcbkXc_RzU2ndDROUCIVdM13nEUdHkFSdM1eAed7S54yKfTf80BSUbQwjhqLIP3WMQ]peter.christiaen@s...[/url
Sent: Tuesday, June 17, 2003 8:52 AM
Subject: [noparse][[/noparse]basicstamps] Shaking Relays
Hi everyone,
PIN 0=switch 1
PIN 1=switch 2
PIN 2=switch 3
PIN 4=output 1
PIN 5=output 2
PIN 6=output 3
low 4
low 5
low 6
main:
inA=outB
goto main
Kindly regards,
Tim
from the same email address that you subscribed. Text in the Subject and Body
