EEPROM max write cycle life and variables use
Hello. I'm new to the Basic Stamp world and I'm a little confused
about something. Is it correct that when scratchpad RAM is used
up for variables, that any remaining variables are stored in
EEPROM? If that's the case, and say some of the variables in
EEPROM were counting loops, and one had a process controller
where counts went into the millions, wouldn't the maximum
useful write cycle life of the EEPROM be exceeded quickly? ( I
appreciate that one can optimize code and variable type.) I
understand that the max write cycles for a BS1 or BS2 is 10
million and for a BS2sx is 1 million.
By way of example, say I'm using a BS2sx and I have more than
26 variables. As a thought experiment, if I had a simple loop that
just advanced the count of a variable that ended up in EEPROM,
then at 10,000 instructions per second, and two instructions for
the loop and count, that's about 5,000 loops per second and
1000000/5000=200 so it seems the EEPROM write cycle life (at
least for the involved addresses for that variable would be
exceeded in 200 seconds or less than three and a half minutes!
Could that be true? What am I not getting? If this is true, can
one add external RAM and ask the compiler/editor to place all
variables in RAM? Will the compiler/editor even accept more
than 26 variables? Thanks in advance for any help in clearing up
my confusion on this!
there. There is little danger of *breaking* your EEPROM under normal
programming and operation. As you point out, you can -- albeit deliberately --
exceed
the EEPROM's write-cycles in a big hurry if you want to.
As far as running out of variables ... I must be extremely lucky because in
10 years of BASIC Stamps, I've only run out once; and that was a tremendously
complicated program. This turned out NOT to be a big deal as the program,
though, had two phases of operation and I was able to preserve those I needed in
the EEPROM (was a stock BS2) while the second phase [noparse][[/noparse]a very infrequent process]
ran.
There are a lot of things you can do to conserve variable space:
-- use Bit, Nib, Byte and Word types as required
-- use aliasing to share the same memory location
Assuming you've done this, your next option is to use the Scratchpad RAM as
temporary storage (this is a better choice on any Stamp except the BS2 which
doesn't have any SPRAM). If it's one or two variables, just use PUT and GET as
required to retrieve them. Also keep in mind that the Word modifier now works
with PUT and GET (in the latest release of the PBASIC compiler).
If you want to save all of your variables, here's a quick routine to do it:
Put_All:
PUT SaveAddr, B0
FOR B0 = 1 TO 25
PUT SaveAddr + B0, B0(B0)
NEXT
RETURN
SaveAddr is a constant the determines the starting location of your saved
variables in the SPRAM. To retrieve your variables, reverse the process:
Get_All:
FOR B0 = 25 TO 1
GET SaveAddr + B0, B0(B0)
NEXT
GET SaveAddr, B0
RETURN
Notice that both routines take advantage of the inherent array structure of
the BASIC Stamp's RAM.
While I don't normally advocate the use of internal variable names (in fact,
I actively campaign against it in general programs), this is a case where
using those internal names is useful.
-- Jon Williams
-- Parallax
In a message dated 6/15/2003 2:49:22 PM Central Standard Time,
joseph123wilson@y... writes:
first project; it looks like I'm going to have to, as you say, ALIAS
variables. I assume that there is no formal construct for doing that in
PB; equivalent to the EQUIVALENCE or COMMON statements in FORTRAN.
Otherwise, ya gotta keep a scorecard.
On Sunday, June 15, 2003, at 04:25 PM, jonwms@a... wrote:
> Variables are NOT stored in the EEPROM -- unless YOU specifically put
> them
> deliberately -- exceed
> because in
> tremendously
> program,
> needed in
> process]
> ran.
> RAM as
> which
> and GET as
> now works
> do it:
> Put_All:
> PUT SaveAddr, B0
> FOR B0 = 1 TO 25
> NEXT
> RETURN
> saved
> process:
> Get_All:
> FOR B0 = 25 TO 1
> NEXT
> GET SaveAddr, B0
> RETURN
> structure of
> fact,
> where
> -- Jon Williams
> -- Parallax
> from the same email address that you subscribed. Text in the Subject
> and Body of the message will be ignored.
exceeded? Is it a simple error message? Thanks much.
--- In basicstamps@yahoogroups.com, jonwms@a... wrote:
> Variables are NOT stored in the EEPROM -- unless YOU specifically put them
exceed
in
process]
> ran.
as
> Put_All:
> PUT SaveAddr, B0
> FOR B0 = 1 TO 25
> NEXT
> RETURN
> Get_All:
> FOR B0 = 25 TO 1
> NEXT
> GET SaveAddr, B0
> RETURN
> -- Jon Williams
> -- Parallax
-- Jon Williams
-- Parallax
In a message dated 6/15/2003 10:13:56 PM Central Standard Time,
> Thanks for your reply. How does the editor respond when varable space is
> Yes -- you'll get an "Out of variable space" message.
> -- Jon Williams
> -- Parallax
MyBase VAR WORD ' Assign mem to MyBase
MyOtherBase VAR MyBase ' 'alias' MyOtherBase to point
' to the same memory as MyBase
--- In basicstamps@yahoogroups.com, Mark Marpet <marpetm@s...> wrote:
> You ARE extremely lucky. I am bumping against the variable limits
on my
ALIAS
that in
put
> > them
normal
> > because in
> > tremendously
> > program,
those I
> > needed in
infrequent
> > process]
> > ran.
Scratchpad
> > RAM as
the BS2
> > which
PUT
> > and GET as
modifier
> > now works
to
> > do it:
> > Put_All:
> > PUT SaveAddr, B0
> > FOR B0 = 1 TO 25
> > NEXT
> > RETURN
your
> > saved
> > process:
> > Get_All:
> > FOR B0 = 25 TO 1
> > NEXT
> > GET SaveAddr, B0
> > RETURN
> > structure of
names (in
> > fact,
case
> > where
> > -- Jon Williams
> > -- Parallax
confused
that
Subject
