Memsic 2125 angle sensor math
All-
I'm using a 2125 angle sensor and would like to display the angle of a surface
to the
nearest tenth of a degree. There are two issues as I understand the problem:
(1) the capacitors and resistor that spec the bandwidth need to be installed in
the
circuit (This is a no-brainer.);
(2) the algorithm that transforms the duty-cycle reading from the 2125 needs to
be
tweaked to allow the additional accuracy. My first thought, and I may have to go
this
route if all else fails, was to use a look-up table, but the amount of memory
that
would be wasted on this is staggering (and boy, I'm really short of memory). The
CORDIC algorithm, at least, that's what I understand the thing to be, is
something I
am totally unfamiliar with, my numeric analysis course took place BC (before
computers), and after looking at the thing for a while, I realized I was
clueless as to
what's going on.
Is anybody out there at all familiar enough with the algorithm (the source code
is
below) to understand how to tweak the accuracy to the tenth of a degree? I think
it's
more than just going out to another integer-equivalent of a decimal point. It's
the
arccosine routine that is the problem, I think, but I really don't know WHAT is
going
on in this code.
Read_Tilt:
GOSUB Read_G_Force
' restrict displacement to unit circle (0.0 - 1.0)
disp = ABS xmG / 10 MAX 100 ' x displacement
GOSUB Arcsine
xTilt = angle * (-2 * xmG.bit15 + 1) ' fix sign
disp = ABS ymG / 10 MAX 100 ' y displacement
GOSUB Arcsine
yTilt = angle * (-2 * ymG.bit15 + 1) ' fix sign
RETURN
Read_G_Force:
PULSIN Xin, HiPulse, xRaw ' read pulse output
xmG = ((xRaw / 5) - 500) * 8 ' convert to 1/1000 g
PULSIN Yin, HiPulse, yRaw
ymG = ((yRaw / 5) - 500) * 8
RETURN
' Trig routines courtesy Tracy Allen, PhD. (www.emesystems.com)
Arccosine:
disp = disp */ 983 / 3 ' normalize input to 127
angle = 63 - (disp / 2) ' approximate angle
DO ' find angle
IF (COS angle <= disp) THEN EXIT
angle = angle + 1
LOOP
angle = angle */ 360 ' convert brads to degrees
RETURN
Arcsine:
GOSUB Arccosine
angle = 90 - angle
RETURN
to the
the
be
this
that
something I
clueless as to
what's going on.
is
it's
the
going
on in this code.
Read_Tilt:
GOSUB Read_G_Force
GOSUB Arcsine
GOSUB Arcsine
RETURN
Read_G_Force:
RETURN
Arccosine:
DO ' find angle
angle = angle + 1
LOOP
RETURN
Arcsine:
GOSUB Arccosine
angle = 90 - angle
RETURN
cosine functions, but not the inverses. (At the time I did not know
that the Stamp _does_ have an undocumented arctangent function.) The
algorithm simply iterates on COS or SIN until it finds the angle
corresponding angle. The algorithm is not very intelligent (not not
even binary search), but it does make a first linear approximation
before it starts on the search. The first line "disp = disp */ 983 /
3", in the program listing you have, is a normalization step, to
scale the values the Memsic puts out down to the range of +/- 127.
Note that the Stamp trig functions are only good to 8 bits around the
whole circle. The circle is divided into 256 angular segments,
called "brads" (binary radians). And the sine and cosine is mapped
into the interval -127 to +127, to represent the scale from -1 to +1.
(See the Stamp manual, or <http://www.emesystems.com/BS2math3.htm>)
Having the Stamp's ATN funciton, you could use ATN
(X/SQR(16129-(X*X))), where X is the value from the Memsic, without
any iteration. {for trig, if the sine of an angle is X, then the
tangent of that angle is X/SQR(1-X^2)}. That is just a thought. I
haven't used the formula for anything. Since 1 is represented as
127, 1^2 has to be 127^2 =16129.
I've not used the memsic 2125 myself, but I would guess that the
range of angles that it measures is relatively narrow. Is that
right? Let's say that it is 90 degrees. In Stampese, that is only
64 units of angle, or not even one degree of resolution. But you are
asking for 0.1 degree. If the range of angles is small, there might
be a better power series approximation. Or lookup with
*interpolation* in a relatively small (not staggering!) table might
do the trick. As you noted, CORDIC is also a possibility.
-- best regards
Tracy Allen
mailto:tracy@e...
>All-
>of a surface to the
>installed in the
>2125 needs to be
>may have to go this
>of memory that
>memory). The
>be, is something I
>was clueless as to
>what's going on.
>source code is
>degree? I think it's
>point. It's the
>know WHAT is going
>on in this code.
>Read_Tilt:
> GOSUB Read_G_Force
> GOSUB Arcsine
> GOSUB Arcsine
> RETURN
>Read_G_Force:
> RETURN
>Arccosine:
> DO ' find angle
> angle = angle + 1
> LOOP
> RETURN
>Arcsine:
> GOSUB Arccosine
> angle = 90 - angle
> RETURN
>from the same email address that you subscribed. Text in the
>Subject and Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Thanks very much. I think I'm gonna scratch my head on this one. If I
figure out anything better, I'll post it to the group.
-Mark
On Saturday, June 14, 2003, at 08:42 PM, Tracy Allen wrote:
> The algorithm is really very simple. The Stamp has built in sine and
> -- best regards
> Tracy Allen
> mailto:tracy@e...
>> All-
>> of a surface to the
>> problem:
>> installed in the
>> 2125 needs to be
>> may have to go this
>> of memory that
>> memory). The
>> be, is something I
>> (before
>> was clueless as to
>> what's going on.
>> source code is
>> point. It's the
>> know WHAT is going
>> on in this code.
>> Read_Tilt:
>> GOSUB Read_G_Force
>> GOSUB Arcsine
>> GOSUB Arcsine
>> RETURN
>> Read_G_Force:
>> RETURN
>> Arccosine:
>> 127
>> DO ' find angle
>> angle = angle + 1
>> LOOP
>> degrees
>> RETURN
>> Arcsine:
>> GOSUB Arccosine
>> angle = 90 - angle
>> RETURN
> from the same email address that you subscribed. Text in the Subject
