Very small pump or equivilent for caustic chemicals - types of pumps
Periastaltic pumps are the types of pumps, but also are called
metering pumps or dosing pumps.
E-bay metering pumps range from
1 hp/3phase, 16 gal/hr at 325 PSI for $799.00 could be overkill
unless your chlorene problem is really really really bad.
to a dual fluid pump that is selling for 3 rolls of 37 cent stamps.
E-bay # # 2538773376
I guess once you get the proper name for the use, you'll get better
results.
Dave
--- In basicstamps@yahoogroups.com, "Mike Dillon" <laxboy687@e...>
wrote:
> Hi I work at a pool as a lifeguard and we use these peristaltic
pumps
> for the exact job you want to accomplish. There is no way that the
pumps
> we have cost a 100$ because they Smile. But if it gets the job done
then
> stick with it right? Anyway check pool stores, because ours is
pretty
> small I don't know the exact specs but it doesn't pump all that much
> because it is constantly running and trying to keep up with the
demand.
> -Mike
> From: Jim Forkin [noparse][[/noparse]mailto:jjf@p...]
> Sent: Thursday, June 12, 2003 3:07 PM
> Subject: RE: [noparse][[/noparse]basicstamps] Very small pump or equivilent for caustic
> chemicals
> A precision fixed-flow peristaltic pump #43045K31, $99.69 at
> McMaster-Carr http://www.mcmaster.com
> jim
> http://www.geocities.com/jimforkin2003/
> From: Bill Boyer [noparse][[/noparse]mailto:daweasel@s...]
> Sent: Thursday, June 12, 2003 2:43 PM
> Subject: Re: [noparse][[/noparse]basicstamps] Very small pump or equivilent for caustic
> chemicals
> So make one. Not a major deal. I'll bet I can cobble something
together
> from the hardware store that will do the job for under $15, not
> including a motor.
> > These 'roller pumps' would be an excellent choice. Also called
> > paristaltic pumps.
> > Being medical/lab type pumps makes 'em expensive - but check for
> > surplus on eBay f'rinstance
> from the same email address that you subscribed. Text in the
Subject
> and
> Body of the message will be ignored.
Subject
> and Body of the message will be ignored.
results.
Dave
pumps
pumps
then
pretty
demand.
> -Mike
> chemicals
> jim
> chemicals
together
> including a motor.
> > paristaltic pumps.
Subject
> and
Subject
