deciding on an oscilloscope — Parallax Forums
edited 2003-06-17 16:59 in General Discussion
hey everyone,
could someone give me some advice on buying an oscilloscope? I
would like to know what features may be present/missing from
different price ranges/models and which features are important (for
instance, multiple traces, etc)... I would like to use it in
debugging digital and analog projects in which basic stamps/PICMicros
are used. I will probably want to stay under a $250 price. Thank you
for any help you could give!!
    edited 2003-06-13 22:38
    Sam <hard-on@t...> wrote:
    hey everyone,
    the optiscope hooked up to your computer looks like the best bet. it'll handle
    one shot readings and a lot more. Circuit Specialists has it for $169.00,
    www.web-tronics.com.
    from the same email address that you subscribed. Text in the Subject and Body of
    the message will be ignored.
    Do you Yahoo!?
    Free online calendar with sync to Outlook(TM).
    edited 2003-06-13 23:08
    If you want to debug digital stuff, you can't go wrong with a digital scope,
    but they're vary expensive, as are analog scopes, but less so. You might be
    able to find a used one (I have a Tektronix 2 channel, 100 MHz scope that I
    bought used for $35! I'm also in the Navy, and we have a calibration lab
    that I was able to use a favor to get it re-calibrated.
    If you want a cheap handheld (pretty useful), look at
    www.allelectronics.com. I bought one there for only $160! It doesn't
    interface to a computer, but it does have a hold feature, as well as a slow
    speed scrolling trace. It's advertized as a 50 MHz scope, but the low
    resolution seems to cause problems at higher frequencies. It comes with a
    good probe, though, switchable from 1x to 10x with a calibration adjustment.
    It's not the best thing in the world, but for $160 and portability, it's
    great!
    Steve
    Sent: Friday, June 13, 2003 10:49 PM
    Subject: [noparse][[/noparse]basicstamps] deciding on an oscilloscope
    > hey everyone,
    edited 2003-06-14 15:22
    When I was looking at a scope, I was looking for speed as one item,
    seems the PC/soundcard scope was slow.
    and the other feature I really wanted was digital storage.
    figure your main needs and that should narrow the search quite a bit.
    Dave
    > hey everyone,
    stamps/PICMicros
    you
    it'll handle one shot readings and a lot more. Circuit Specialists
    has it for $169.00, www.web-tronics.com.
    Subject and Body of the message will be ignored.
    > Do you Yahoo!?
    edited 2003-06-14 16:13
    Optascope seems to work fine when it works. Two annoying things:
    1. very erratic to trigger I have not learned yet how to trigger
    realiably.
    2. Input impedance is low, the probes loads the measuring circuits.
    In the industry, the standard Input impedance is about 1Megohms.
    edited 2003-06-14 16:15
    If you check eBay, you can find deals on 2-channel HP and Tektronics
    digital scopes -- these are super for working on Stamp stuff. However,
    they can be complicated to operate and not cheap to fix. You can
    probably find some deals on analog scopes too, although you need to
    shoot for 20 mHz or better. If you want new, there are some $250-300
    scopes out there that will work reasonably well for the hobbyist.
    In any case, if you haven't used a scope before it would be wise to take
    a class or get a book on instruments and measurements so you at least
    know how to use it properly and not tear it up.
    > realiably.
    edited 2003-06-14 16:43
    TEXTRONIX
    edited 2003-06-14 20:17
    I have the same problem. Also, it isn't very good for finding resonant
    frequencis. It is good for watching serial communications though. I have a
    Tek 465M that I got cheap on e-bay. Great for lots of stuff, and has the mil
    spec self calibration feature, good if you have no easy way to check like
    me. Tough too. Has survived Tesla coils, all sorts of nonsense.
    Jonathan
    www.madlabs.info
    Sent: Saturday, June 14, 2003 8:13 AM
    Subject: Re: [noparse][[/noparse]basicstamps] deciding on an oscilloscope
    > realiably.
    edited 2003-06-15 13:52
    Well,
    $250 US is just under $500 NZ.
    I recently bought a scope for $430 NZ.
    For that price, you can expect a single trace 10MHz Scope, or a
    Portable Hand Held Scope ("Velleman" brand - what I opted for
    in the end).
    For a lot of things, that will suit me fine, but I will be looking at
    spending double that amount of money to get a dual trace
    20MHz Scope in the future.
    The portable Scope also works when your switch board goes up
    in flames... :-) (as mine has just done - got to it before the
    house was in danger). Am with out power until the Electrician
    comes back in the morning, thank God for battieries, and laptops
    with back up dail in connection... :-)
    Cheers,
    Ben.
    Windy Wellington, New Zealand.
    --- In basicstamps@yahoogroups.com, "Sam" <hard-on@t...>
    wrote:
    > hey everyone,
    oscilloscope? I
    important (for
    stamps/PICMicros
    you
    edited 2003-06-15 16:01
    Beats me. You should be able to snag an LG 20 mHz dual-trace scope for
    $250-300 US and one with an added signal generator for about $100 more.
    They are pretty decent and they come with a couple of x10 probes. Seems
    to me that stuff ought to be cheap there as you can throw a rock and
    almost hit the factory.
    > in the end).
    > Cheers,
    > Ben.
    > wrote:
    > > hey everyone,
    > oscilloscope? I
    > important (for
    > stamps/PICMicros
    > you
    edited 2003-06-16 05:15
    Ah yes, we have many factorys that we can throw rocks at, :-) , but
    none of them make Scopes.
    The cheapest 20MHz dual trace I can get in NZ via Dick Smith or
    Jaycar, is around $830 NZ (~$415 US). Comes with the probes,
    too.
    Dual 40MHz, is about $1200 NZ.
    But, still, I'm very pleased with my Velleman HPS10.
    --- In basicstamps@yahoogroups.com, Bill Boyer
    about $100 more.
    probes. Seems
    and
    a
    for
    > > in the end).
    up
    Electrician
    laptops
    > > Cheers,
    > > Ben.
    <hard-on@t...>
    > > wrote:
    > > > hey everyone,
    > > oscilloscope? I
    from
    > > important (for
    > > stamps/PICMicros
    Thank
    > > you
    the Subject and Body of the message will be ignored.
    edited 2003-06-16 05:16
    too.
    about $100 more.
    probes. Seems
    and
    a
    for
    > > in the end).
    up
    Electrician
    laptops
    > > Cheers,
    > > Ben.
    <hard-on@t...>
    > > wrote:
    > > > hey everyone,
    > > oscilloscope? I
    from
    > > important (for
    > > stamps/PICMicros
    Thank
    > > you
    If you want the most scope for your money try Circuit Specialists
    (web-tronics.com)
    They have a dual channel 60 Mhz scope for less than $400. So far I have not
    seen anyone able to beat this deal!
