visuall c++ with stamp — Parallax Forums
edited 2003-06-06 19:08 in General Discussion
IS there any way I can use visual c++ with basic stamp.
thanks
    > thanks
    Depends on what you want to do. If you want to write an application
    that talks to the Stamp through the serial port, yes you can do that.
    If you want to write your basic stamp code in VC++ and use that IDE to
    download it to the Stamp, well, you can probably do that too, but that
    seems like quite a project. If you want to create a Linux kernel in
    order to run Star Office on a Basic Stamp, then no - I'm pretty sure
    you can't do that.
    Neil
