external memory for the bs2
I'm currently attempting to do a new project with the BS2 (would I
use anything else =0) ). However I will need some storage space to
store alot of data that the bs2 will not be able to hold. I would
like to have about a minimum of 64kb of non-volitile memory for
storage. I found a tutorial with the xicor eeprom however the
maximum capacity is 32k using the xicor x25640. would I be able to
control 2 at the same time without taking up all my i/o lines? any
help or working links would be appreciated. Thanks all for your time
and help
and help
these to your Stamp (uses just two pins and other I2C devices can share this
bus), you'll get 64K of external storage.
Here's an article from Nuts & Volts that will get you started:
<A
HREF="http://www.parallax.com/Downloads/Documentation/nv/v3/col/NV85-I2C_Fun_For\
_Everyone.pdf">
http://www.parallax.com/Downloads/Documentation/nv/v3/col/NV85-I2C_Fun_For_Every\
one.pdf</A>
Be sure to download [noparse][[/noparse]and read!] the specs for the I2C parts you choose to
interface.
-- Jon Williams
-- Parallax
In a message dated 6/3/2003 7:45:47 PM Central Standard Time,
Chalma_Juice@y... writes:
> and help
Give the Rampack B a look.
http://www.solutions-cubed.com/Products/RAMPackB/rampack_main.htm
You can replace the 8 KB chip it comes with with a DS1230 32KB nonvolatile
SRAM (Jameco#: 114323). If you want 64KB you will need 2 Rampacks. Each
Rampack will need 1 wire to communicate with the stamp.
I have been able to interface a BS2p to a SRAM using I2C IO expanders, but
it is slow. I am trying out some other ideas that I hope will speed it up
though. But for "plug-n-play" with any stamp I don't think you can beat
the Rampack.
Chuck Chargin Jr.
>and help
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
with 4 times as much, 32k bytes in the same 8-pin package. The
access code is practically identical. It takes two chips and at most
5 BS2 lines to access 64 kbytes. SPI memory like this going to be
faster than I2C, unless you have a BS2p, which has the I2C commands
built in.
I use AT45DB041 dataflash, which has 256 kbytes in one 8-pin chip.
It is trickier, though, from the hardware and firmware support angles.
-- Tracy
>and help
