Generate Object Code. Why?
Hello,
I'm not always the sharpest tool in the shed... [noparse]:)[/noparse]
I'm interested to know exactly what is the purpose of saving
and later loading an object file? Can't seem to find any details
in the included help or pdf files that came with my BOE kit.
I've generated an object file, examined it's contents and compared it
to a tokenized file, seems very similar, but what is it used for?
This object file seems to mean something different then what we
already know about object files in assembly or C code.
Thank you for your help in advance!
Best Regards,
Jules Marchildon
Best Regards,
Jules Marchildon
a stand alone or w/object executable file. I did that, and ran
both of them, -they both asked to load an object file (one I saved
earlier) and comes back with a message box that says...
#012
Checksum Error
Data is corrupt in file "c:\test.obj"
Okay, I see now this is used to download a program without the IDE.
But don't understand the error code? The "Generate object file"
dialog says I was successful!
Here is the simple test code...
'{$STAMP BS2}
Counter VAR BYTE ' Counter for LED blinks
FOR Counter = 1 to 20 'Loop 20 times
PULSOUT 0,50000 'Blink LED on and off for 1/10 second
PAUSE 250 'Pause 1/4 second
NEXT
STOP
others without divulging the source code. The stand-alone executable option
makes it particularly easy for developers to send updates to customers.
We're scheduled to start revising the manual next month ... the creation of
object files will be covered.
-- Jon Williams
-- Parallax
In a message dated 6/3/2003 6:35:10 PM Central Standard Time,
jmarchildon@l... writes:
> Hello,
> Best Regards,
> Jules Marchildon
I'm not sure which version of the BASIC Stamp Editor you are running, but the
problem you reported occurred only in Version 2.0 Beta 1, that I know of.
This was an error caused by recompiling the code in a new version of our
development environment, which has different default preferences for certain
compile-time structures; this was unknown by us at the time. In essence, it
would think it created the object code file/executable properly, however, the
structure of the file was somewhat different, causing a checksum error upon
loading.
This bug has been fixed in Version 2.0 Beta 2. If you find that the new version
still causes the same problem, please let me know.
Thank you.
--Jeff Martin
Engineering Manager
> From: gem2jules [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8BVVkrxFWL8_1Gg9uI1Br8zhdVx4blz6Dgmh0T6BOeb1gYgGdo03j3nXVo-U5E1gc-NUlq6BZ9uy]jmarchildon@l...[/url
> Sent: Tuesday, June 03, 2003 5:19 PM
> Subject: [noparse][[/noparse]basicstamps] Re: Generate Object Code. Why?
> Okay, a little more investigation. I see now you can create
> #012
> Checksum Error
> '{$STAMP BS2}
> NEXT
> STOP
> from the same email address that you subscribed. Text in the
