IR link between BS2p and external programming PC
Hi
I am planning to build a IR link to replace the serial link (Sout &
Sin connections)between the BasicStamp (BS2p) and the external PC.
I saw the application "IrDA with the BASIC Stamp & the MAX3100" by
Tracy Allen. Can this circuit be used to connect the RS232 pins
Sout/Sin of BasicStamp rather than the TTL i/o pins of the stamp and
use only one of hte I/o pins for the SCLK.
( I will use electrical wires to load the program and only need the
IR link while running the program to monitor the progress and input
data)
Can this circuit be used at a distance of 2-3 foot?
What is the approximate current draw of this circuit?
Also, I found the following comment by Tracy Allen in reply to an
earlier post:
"Many PCs have an IRDA serial infrared port built in. You can use
that with the Stamp, if you provide the Stamp with an IrDA interface.
Here is one using the MAX3100:
http://www.emesys.com/BS2IrDA.htm
Another option might be the RS232<->IR chips from Rentron, or the new
IRbuddy from Parallax. Those modules use high frequency modulation
to achieve much greater range than is possible with IrDA."
I checked the Rentron website and found IR links based on 38KHzor
40KHz modulation and has a longer range, but has a low data rate of
2400 baud only. Does anyone know if the circuits given in RENTRON
website,(e.g. using AIRBYTE ASIC)can be made to operate at higher
baud, say 9600? Has anyone in this group used their AIRBYTE IC? I
noticed they sell the transceiver module not the individual IC? Do
anyone of you know if it is available elsewhere?
data)
earlier post:
I have used it as a general purpose UART -- it's
a very nice chip.
However -- it is designed to interface with the
Stamp as an 'SPI' interface. It wants 4 pins --
DataIn, DataOut, Clock, and ChipSelect. On the
good side, you can re-use the DataOut, DataIn, and
Clock lines with another SPI device, as long
as you don't select both SPI devices at the same
time. You certainly can not talk to the chip
from the Stamp with a 232 protocol.
I've also used the IRBuddy. It has VERY low
'baud rate' (100 Bits/Sec?) -- basically it
acts as a send/receive TV Remote control --
you can send and receive
Phillips RC-5 codes (button presses) between the
two modules, but with good range.
For range: IRDA was designed for short ranges
(<= 10 feet).
--- In basicstamps@yahoogroups.com, "mohammedrasiq"
<mohammedrasiq@y...> wrote:
> Hi
and
> data)
> earlier post:
interface.
new
IR detector modules. While these are great for reducing ambient
interference, they also limit speeds.
The Air-Byte IR transceiver & TX-IR serial communications IC can
handle faster data rates, but you'll have a hard time finding 38-40KHz
IR detector modules that can handle better than 2400 reliably.
If you want high-speed IR, you'll need to look into Tracy's IRDA project.
If you want killer distance with excellent noise rejection, then our TX-IR
IC or Air-Byte with a simple IR detector module like the TSOP-1140 or
1138 will do the trick.
If you're looking for remote IR Stamp programming, wireless IR robot
control + communications, then look into the SI-Pro IR wireless
systems.
-Bruce
tech@r...
http://www.rentron.com
Sent: Tuesday, June 03, 2003 2:56 PM
Subject: [noparse][[/noparse]basicstamps] IR link between BS2p and external programming PC
> Hi
> data)
> earlier post:
MAX3100 requires the SHIFTIN and SHIFTOUT instructions that are only
possible on the TTL i/o pin.
IrDA can work at 2-3 feet in normal room lighting, but it takes some
care. You will need to drive the transmitting IR LED or even
multiple LEDs with a lots of current via a transistor (not directly
from a stamp pin) And you will need to use an amplifier like the
Burr-Brown OPT101 that is suggested in the application note. It may
need an infrared filter over the receiver, if there is much ambient
light, and a collimator, and even an adaptive baseline amplifier to
compensate for the quasi-static ambient level.
The modules from Rentron or Parallax at 2400 baud will work at those
distances and much more indoors with great ease, because of their
high frequency modulation scheme.
I think all infrared schemes have big trouble in bright sunlight.
-- Tracy
>Hi
>data)
>earlier post:
>Subject and Body of the message will be ignored.
information.
--- In basicstamps@yahoogroups.com, Tracy Allen <tracy@e...> wrote:
> No, you cannot use the p16 RS232 pins with the MAX3100 circuit.
The
only
some
may
those
> -- Tracy
> >Hi
and
> >data)
> >earlier post:
interface.
new
I agree that i did not find any 38-40KHz IR detector modules for high
speeds greater than 3000 or 4000.
But I did find a IR detector operating upto 20000 baud. This is the
Vishay's TSOP7000 but needs a carrier at 455KHz. Is it possible or
not to program the TX-IR or make a version of AIRBYTE that can
generate a carrier of 455KHz? Is that a limitation of the PIC based
on which Tx-IR or AIRBYTE design is based or is it simply not yet
done, but could be done?
Mohammed
--- In basicstamps@yahoogroups.com, <tech@r...> wrote:
> The speed limitations are due to the max data rates of off the shelf
40KHz
project.
our TX-IR
> systems.
> Regards,
> -Bruce
> tech@r...
> From: "mohammedrasiq" <mohammedrasiq@y...>
programming PC
> > Hi
by
and
the
input
> > data)
> > earlier post:
interface.
new
modulation
of
Do
>Subject: [noparse][[/noparse]basicstamps] Re: IR link between BS2p and external programming PC
> Thanks Bruce for your comments.
> Thanks
> Mohammed
It's definitely possible - just not something we have available at present. We
are working on a higher speed IR link, but contact me off list for details.
-Bruce
tech@r...
