Sht15 — Parallax Forums
Sht15
edited 2003-06-03 01:43 in General Discussion
I am using a SHT15 sensor with a BS2 setup. My question is how far can I
seperate the sensor from the BS2 bread board?
Kevin
    edited 2003-06-02 23:51
    Hi Kevin,
    I've positioned the SHT15 as much as 2 meters away from the BS2 and
    still had good readings. I've not tried to determine the limit, but
    if I had push it, I'd look at the signal degradation on an
    oscilloscope. The data line has a passive pullup resistor that
    limits the slew rate, so decreasing that resistor value could
    increase the length of wire that could be driven. The SHIFTOUT and
    SHIFTIN commands move bits at a rate of about 16 kilohertz on the
    BS2/BS2e/BS2pe. There could be an issue of noise pickup.
    -- best regards
    Tracy Allen
    http://www.emesystems.com
    mailto:tracy@e...
    >Thanks,
    >Kevin
    edited 2003-06-03 00:23
    Kevin,
    I have put the data output from a SHT11 over 60' feet through a 2 wire plus
    ground shielded cable. The power supply for the SHT is local, and the ground
    wire ties both systems togther. Rock solid, no problems.
    Jonathan
    www.madlabs.info
    Sent: Monday, June 02, 2003 3:21 PM
    Subject: [noparse][[/noparse]basicstamps] SHT15
    > Thanks,
    > Kevin
    Kevin-
    Sensirion, the manufacturer of the SHT 15 makes an identical unit
    called the SHT75 , identical except it is installed on the end of a
    four-pin plug. I'm fooling around with the SHT11 sensor, but in the
    real world, I'm gonna use an SHT15, hung off the end of a cable.
    -M^2
    > can I
    > Thanks,
    > Kevin
    > and Body of the message will be ignored.
