Nuts & Volts article - High Power H-Bridge
Ever had one of those days?
I'm attempting to build the above circuit (Sept '99 I believe)
I've followed the parts list perfectly, built the circuit, double and
triple checked it. Nothing.
The stamp seems to be doing what it is supposed to, but the 4081 doesn't do
a thing. With a logic probe I can see the stamp trying to PWM the 4081,
but the output side of the 4081 never changes.
I'm not in any rush for a fix, this is just for fun anyway, but I am
quitting for now and going fishing (hear teeth grinding)
Any tips where I can begin to look for my error?
The code compiles (so to speak I guess) fine, the only change I made in the
code besides some debug statements to see where I am is the REVERSE lable
appears to choke pbasic. I don't know if its a reserved word now or what,
but I changed it to GOTHEOTHERWAY and it works fine.
Any suggestions would be appreciated.
-John
-John
and
doesn't do
4081,
am
made in the
lable
or what,
> Thanks,
> -John
keep your tip up and use live bait.
first, make sure you are driving the transistors/darlingtons/mosfets
with enough power.
you should be able to verify the circuit without the stamp.
then check stamp output volts/amps to verfy that it complies with the
final device.
then look at software. if you want to prove the software first,
switch out the driver chips with LED's.
Dave
