Conductive paint?
Various TV / VCR spare parts places carry kits to refurbish remote control
keypads.
> Do any of you electron heads know of a "conductive paint" that could be
used
> to make the rubber surface of a touch pad conductive again?
> In the mean time I will attempt to glue a small piece of Aluminum foil to
the
> pad, and hopefully it will not "stick up" to the point of making contact
with
> the grid all the time.....
keypads.
used
the
with
In the mean time I will attempt to glue a small piece of Aluminum foil to the
pad, and hopefully it will not "stick up" to the point of making contact with
defroster at the autoparts store. I think it is pricey and it comes
in tiny bottles.
Dave
--- In basicstamps@yahoogroups.com, smartdim@a... wrote:
> thanks daweasal
Liquid solder. Never used it, but others on the list report fixing PCBs with
it.
I got this ver fine brass mesh from Electronic Goldmine. It has a conductive
adhesive on it. I use it to put togther broken solar panels without
soldering. Works great for that, and I bet it would work nicely for a button
too.
Jonathan
www.madlabs.info
Sent: Friday, May 30, 2003 5:59 PM
Subject: [noparse][[/noparse]basicstamps] Conductive paint?
used
the
with
davemucha@j... writes:
> on the emergency side, you can buy paint for the rear window
> in tiny bottles.
Why didn't I think of that, I work in the automotive industry....duhh
> In a message dated 5/30/2003 6:47:21 PM Pacific Daylight Time,
comes
> > in tiny bottles.
industry....duhh
you just asked to make us look good, that's all! : )
element? Sounds like it could have some neato uses depending on the
characteristic of it.
Jonathan
www.madlabs.info
Sent: Friday, May 30, 2003 6:59 PM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Conductive paint?
> > in tiny bottles.
jpeakall@m... writes:
> How resistive is it, say ohms per inch? Is it used for repairing the heater
> Jonathan
Good question.....don't know the resistivity. I think we have the repair kit
at my work, I will try to paint a sloth of known width and legnth and
approximate thickness, then measure it. Yes it is used to repair the heating
element.
It is not too uncommon for one of the grid line to develop a crack or
break......besides the repair kit the alternatives are do without that section
working
or replace the rear glass.
resistors in a Marx generator. Must have some cool use!
Jonathan
www.madlabs.info
Sent: Friday, May 30, 2003 8:02 PM
> In a message dated 5/30/2003 7:50:43 PM Pacific Daylight Time,
heater
> > Jonathan
kit
heating element.
section working
It is called caikote and is a brush on conductive
coating. The Pro Gold is great stuff too, use
it all the time on connectors.
http://shopping.netledger.com/app/site/site.nl/site.ACCT113328/mode.items/sc.2/c\
ategory.72/.f
Andy
Sent: Saturday, May 31, 2003 00:59
used
the
with
