SMT soldering was stamp for 3 trolling motors, which motor controller
The class lab provide Metcal soldering stations. That's basically a regular
soldering iron with a very good temperature control system and a large
variety of tips made for each type of package. Generally we just used the
very fine round tip and heated one lead at a time. You can find these on
E-Bay for fair prices.
I have purchased a hot air system for myself. This is really the way to go,
but you either need to have a business justification or a really cool toy
budget. A refurbished system set me back over $2500. These systems let you
produce solder joints that look like they came out of a reflow oven. They
also greatly increase your opportunity to remove/replace without overcooking
either the component or the PCB. Drool at: www.zephyrtronics.com. Most of
the major soldering station companies make competitive products.
Its possible to make functional soldering joints using a standard, fine
tipped soldering iron. This just gives you less room for error and you
won't get that smooth commercial appearance.
I've been soldering as a hobbyist for over thirty years -- starting with
vacuum tubes. I was amazed at how much I learned in class. I encourage
everyone to explore their community college catalog for electronics
technology classes. I've been very pleasantly surprised by the high quality
of the instructors in the classes I have been taking for the last few years.
I've been hooked so hard that I've started taking "real" engineering classes
working toward an ME/EE.
-- Al Margolis, founder
www.hobbyengineering.com
The WEB's newest source for robotics supplies and information
From: Mark Marpet [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=z_dACP8WmzUQATNa7s_1GhrLiBR6rEo14BLO7v3KcyZP-N1TbKfp3G0_O2ZtjOfeCJg_xw4_6dzsS7qw-g]marpetm@s...[/url
Sent: Thursday, May 29, 2003 4:11 PM
Subject: Re: [noparse][[/noparse]basicstamps] stamp for 3 trolling motors, which motor
controller
Al-
I'm curious as to what soldering iron (assuming that you use an iron)
you use to solder surface mount stuff?
-Mark
On Thursday, May 29, 2003, at 05:56 PM, Al Margolis((TX)) wrote:
> I know what you mean about the magnifying glass. I now do all my
> soldering
> (and half of everything else) under a magnifying lamp I picked up at
> Lowe's
> for about 30 bucks. I specifically hunted for one that uses an
> incandescent
> lamp because the flickering of florescent light is starting to bug me.
> I just finished a semester long class in soldering (including surface
> mounts) at the local community college. Some of the kids laughed when
> I
> brought in my magnifying lamp, but I managed to make better
> connections than
> most of the "kids".
> Don't give up!
> From: Bill Katakis [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=f14KV5C0XM99Lc_KBneYFY25qANIkdfjggVabt7ADvEl0OaLjOaMh-fP-Yye-UcUmL9cJEeF1UEb7KA]bkatakis@a...[/url
> Sent: Thursday, May 29, 2003 12:50 PM
> controller
> Ok so I can get a wire wrap kit for the breadboard and a stronger
> magnifying
> glass for soldering and perhaps a good soldering person for the field
> version. I checked out the motor controller and I couldn't see
> anything
> about reversing the motors which we would need to do. Is there an
> inexpensive shareware or freeware program for making circuit boards
> and what
> kit would you use to make the boards. The diverse electronics motor
> controller is at http://divelec.tripod.com/mc/mc7_specs.html it
> includes
> sample software for the bs2. It uses fets so you have to be careful
> with
> static. It's fully reversible and worked well on one trolling motor
> before
> I accidentally popped a ground lead off of the keyboard chip and it
> died.
> Price is $80 12-36vdc motor supply and uses ttl level voltage to ,,
> enable,
> forward, reverse, and has a pwm input which I ran Al Williams pak 5
> to. If
> I could conquer the physical part of this, I know it would be a great
> little
> underwater robot. Anyone up to a collaboration? Thanks for your
> input by
> the way, it's great that people are willing to offer good advice.
> Bill
> Cure Cancer and Smallpox with your computer.
> It runs as a screen-saver Sponsored by Intel:
> http://members.ud.com/download/gold/
> From: "Mark Hillier" <Mark@H...>
> To: <basicstamps@yahoogroups.com>
> Sent: Thursday, May 29, 2003 2:37 PM
> controller
>>> Hi,
>>> I'm trying to use al Williams pak5 for pwm to control 3 trolling
>>> motors
> from a bs2,,, I found a motor controller at diverse electronics, it
> uses 3
> stamp lines per motor, so nine lines, plus a pwm line for each motor
> from
> the pak5a. I'm using the pak
>> 6
>>> so I can use an AT keyboard to give commands to the first stamp
>>> which
> talks to the motor control stamp.
>>> Has anyone else address large dc motors,, what controllers did you
>>> use?
>>> I tried this once before a few years ago and burnt up a couple of
>>> chips
> with a bad ground. Now I'm trying again with the help of a friend
> who
> also can't solder worth a darn (we are old). Anyone have any
> suggestions
> for a good kit for making connec
>> t
>>> ions on breadboard between stamps and other i.c.'s I don't want to
> solder if I can help it, even with a magnifier it's an exercise
> in,,,,,,,,
> the random spewing of solder.
>>> I was able to get the pak 5 and 6 working ok, as I have saved my
> programs from before, but wonder if there is a list of items that
> would make
> it easy to do just about any connection required on a large breadboard,
> between the stamps and the other i.c.s
>>> Is there a good kit, or list of items that might be helpful?
>> Breadboards and the like are great for prototypes but when it
>> comes to using your design in the field, what were advantages in
>> the lab quiclky become disadvantages: wires come lose, contacts
>> corrode, vibrations cause problems etc.
>> Wire-wrap is a possibility but you need good eyesight and excellent
>> manual dexterity for it yo be anything less than a nightmare.
>> Personally, I've spent a LOT of time tracing broken wires in
>> wirewrap designs....
>> I hate to say it, but solder is a necessary evil when it comes to
>> electronics. Perhaps you can recruit some help ?
>> Mark Hillier, VE6HVW
>> President, HVW Technologies Inc.
>> Canadian Distributors of Parallax Products and other Neat Stuff
>> Tel: (403)-730-8603 Fax: (403)-730-8903
>> http://www.HVWTech.com
>> ** New Breadboard Voltage Regulator (BVR) -A plugable +5 Volt
>> power supply !
>> To UNSUBSCRIBE, just send mail to:
>> basicstamps-unsubscribe@yahoogroups.com
>> from the same email address that you subscribed. Text in the Subject
>> and
> Body of the message will be ignored.
>> Your use of Yahoo! Groups is subject to
>> http://docs.yahoo.com/info/terms/
> and
> and Body of the message will be ignored.
controller
Al-
-Mark
> soldering
> Lowe's
> incandescent
> I
> connections than
> most of the "kids".
> Don't give up!
> controller
> magnifying
> anything
> and what
> includes
> with
> before
> died.
> enable,
> to. If
> little
> input by
> Bill
> controller
>>> Hi,
>>> motors
> uses 3
> from
>> 6
>>> which
>>> use?
>>> chips
> who
> suggestions
>> t
> in,,,,,,,,
> would make
>> power supply !
>> and
> and
