Garden Project — Parallax Forums
Garden Project
edited 2003-06-03 14:08 in General Discussion
Hello Stampers
I have a project that I would like to try. The basic stamp would
sleep
most
of the time. About every 24 hours it
would wake up, check soil moisture and if appropriate turn on a
watering
system (soaker hose) for a length of
time. Then its back to sleep.
It seems the power to do this would be small. I have a solar panel
(max
output 12v at 125 ma) that I would like
to integrate into this project. I am considering the possibility of
using
capacitors to store the electricity
from the solar panel.
Could someone help with the calculations needed to determine capacitor
size?
Also anyone know of a source of a valve for the water hose?
Fred
    edited 2003-05-29 03:43
    Hey Fred, sorry I can't help you with the capacitor calculations but
    you might want to go to a boating store and buy a 12v solenoid valve
    that they use in the pumping of bilges. The one I found was 42
    bucks, surely you can find one cheaper than that but here is the link.
    http://www.go2marine.com/frameset.jsp?
    servletPath=/g2m/action/GoBPage/id/83009F/hiLiteSku/83009/categoryId/1
    1517/
    Hope that helps a little bit.
    --- In basicstamps@yahoogroups.com, "fpaynefpayne" <fpayne@c...>
    wrote:
    > Hello Stampers
    > sleep
    > most
    > watering
    > (max
    > using
    capacitor
    > size?
    > Thanks,
    > Fred
    edited 2003-05-29 12:34
    Fred, for an inexpensive valve to control water flow, check out the valves
    used in automatic washing machines. They will probably be 120vac valves,
    but you can switch a relay with the stamp and transistor, and control it.
    The valves usually have hose bibs molded in so hook up is easy. Be careful
    with the AC power!
    Jim
    http://www.geocities.com/jimforkin2003/
    From: fpaynefpayne [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=GNIIxXa3FedxB7FS2XEKB5TNgP4T-mhlJYgSvvdMJEWZqJn0JaIL24zV7VGGWRneSA9L7Li-mcKihQ]fpayne@c...[/url
    Sent: Wednesday, May 28, 2003 10:20 PM
    Subject: [noparse][[/noparse]basicstamps] Garden Project
    Hello Stampers
    sleep
    most
    watering
    (max
    using
    size?
    Fred
    edited 2003-05-29 15:12
    Sprinkler system valves are cheap at Home Depot they run on 24 volts with
    low current.
    Maybe a boost supply off your 12 volts up to 24 would solve that problem.
    From: Jim Forkin [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=T3LHsd4-RI93kVWrr-lRTOW6SjjNqJ-SiWNmW3frIik0JCPybT7SNekwr_St7Q3yMzYxKVnfQsA]jjf@p...[/url
    Sent: Thursday, May 29, 2003 7:35 AM
    Subject: RE: [noparse][[/noparse]basicstamps] Garden Project
    with the AC power!
    Jim
    From: fpaynefpayne [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=4v-y2mvDziCU9wNx0ILJySv2Tp9p2GiVTWrFbR2iPuEuBAj3aP3-1WwzdurxuU_ANtcYWNLjKIndKKG7Kw]fpayne@c...[/url
    Hello Stampers
    sleep
    most
    watering
    (max
    using
    size?
    Fred
    edited 2003-05-29 17:39
    Good idea. To clarify, though, sprinkler system values run at 24AC,
    not DC.
    -Dustin
    --- In basicstamps@yahoogroups.com, Sadler Porter
    volts with
    > low current.
    problem.
    > From: Jim Forkin [noparse][[/noparse]mailto:jjf@p...]
    the valves
    valves,
    control it.
    careful
    > with the AC power!
    > Jim
    > From: fpaynefpayne [noparse][[/noparse]mailto:fpayne@c...]
    > Hello Stampers
    > sleep
    > most
    > watering
    > (max
    > using
    capacitor
    > size?
    > Thanks,
    > Fred
    Subject and
    Subject and
    edited 2003-05-29 18:59
    Check out patent# 6,257,264 at www.uspto.gov. It may give you some ideas
    because it describes a solar/supercapacitor/microcontroller irrigation system.
    Also, you might need to use latching valves (I think they are described in the
    patent also). These open and close with pulses of power, and thus are more
    appropriate for your application because they don't require continuous current.
    d...
    > not DC.
    > -Dustin
    > volts with
    > > low current.
    > problem.
    > > Wrom: HDMNNSKVFVWRKJVZCMHVIBGDADRZFS
    > the valves
    > valves,
    > control it.
    > careful
    > > with the AC power!
    > > Jim
    > > Wrom: QHYUCDDJBLVLMHAALPTCXLYRWTQTIPWIG
    > > Hello Stampers
    > > sleep
    > > most
    > > watering
    > > (max
    > > using
    > capacitor
    > > size?
    > > Thanks,
    > > Fred
    > Subject and
    > Subject and
    edited 2003-05-29 19:48
    Oops. Your right. That would mean, (according to other posts I've seen) you
    may be able to run them on a lower DC voltage (15-18)
    I would say some testing is in order. But much safer than switching 120vc
    From: dirt939 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8UFac4FmoLHEyDbrUSaFY6NKeu5Jn_ZF3kTNBW-c3tt0RUIbfsT9pfI5rgnY8Inou4DZl13nxM3wJR_tsQ]stamp@d...[/url
    Sent: Thursday, May 29, 2003 12:40 PM
    Subject: [noparse][[/noparse]basicstamps] Re: Garden Project
    not DC.
    -Dustin
    volts with
    > low current.
    problem.
    the valves
    valves,
    control it.
    careful
    > with the AC power!
    > Jim
    > Hello Stampers
    > sleep
    > most
    > watering
    > (max
    > using
    capacitor
    > size?
    > Thanks,
    > Fred
    Subject and
    Subject and
    edited 2003-05-29 20:25
    a little surfing and i foune several sights that use
    these watter sprinkler valves for air cannons needles
    to say they will open with two nine volt batterys so
    control with a stamp should,nt be a problem
    > (15-18)
    > From: dirt939 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=K_tuW2N730quYVk7PmaVTl1FZlCCz6fc8SOcZJiuT7cF96pgbDPCv9FDk2qhbA7ifO0rjKmdoaXAu6lvZdbk03c]stamp@d...[/url
    > values run at 24AC,
    > not DC.
    > -Dustin
    > they run on 24
    > volts with
    > > low current.
    > would solve that
    > problem.
    > flow, check out
    > the valves
    > probably be 120vac
    > valves,
    > transistor, and
    > control it.
    > hook up is easy. Be
    > careful
    > > with the AC power!
    > > Jim
    > > Hello Stampers
    > basic stamp would
    > > sleep
    > > most
    > > watering
    > have a solar panel
    > > (max
    > the possibility of
    > > using
    > determine
    > capacitor
    > > size?
    > water hose?
    > > Thanks,
    > > Fred
    > Text in the
    > Subject and
    > Text in the
    > Subject and
    > removed]
    > removed]
    > Text in the Subject and Body of the message will be
    > ignored.
    __________________________________
    Do you Yahoo!?
    Yahoo! Calendar - Free online calendar with sync to Outlook(TM).
    http://calendar.yahoo.com
    edited 2003-06-01 19:07
    Thanks to everyone who answered my questions about the Garden watering project.
    I got a lot of good ideas on where to get valves etc. Also as someone suggested
    the project can easily be done
    with power from the house rather than the solar collector.
    I was interested in the solar aspect because someone gave me the challenge to do
    it with
    Capacitors and a solar collector. He also gave me the solar collector (12v at
    125 ma max).
    No one had any opinions on the capacitor size. Here is what I think. I bet
    this will get some responses!
    A coulomb is a large quantity of electrons.
    An amp is one coulomb per sec moving past a point in a conductor.
    Capacitance in farads = charge/volt = Coulomb/volt
    One time constant = R*C R(in ohms) C(in farads)
    After 5 time constants the capacitor is considered charged.
    i.e. 1 meg ohm * 1 micro farad = 1000000 ohms * .000001 farads = 1 sec
    It would take 5 seconds to charge a cap through a 1 meg ohm resistor
    The charge ( or discharge) curve is nonlinear. The cap will charge or discharge
    63% in the first time constant.
    Another 63% of what is left during the next time constant.
    So if you start out with a cap charged to 12 volts by the solar panel in one
    time constant it will discharge to
    only 4.4 volts. It (the stamp) better have it’s business done before then.
    One possibility:
    Lets say the stamp wakes and draws 100 ma for one minute.
    R= V/I = 12V/.1 A = 120 ohms
    The stamp and other circuitry looks like 120 ohms through which the capacitor is
    discharging.
    One Time Constant = R*C
    C = T/R = 60 sec/ 120 ohms = .5 farads
    In my day this size cap was not practical. I have heard 1 farad caps are now
    possible.
    Anyone know of a source of 1 farad caps at a least 12v or more. Don’t search
    just point me in the right
    direction.
    Fred
    edited 2003-06-01 19:54
    >project.
    >suggested the project can easily be done
    >to do it with
    >(12v at 125 ma max).
    >bet this will get some responses!
    > resistor
    >discharge 63% in the first time constant.
    >one time constant it will discharge to
    >only 4.4 volts. It (the stamp) better have it's business done before then.
    >One possibility:
    >capacitor is discharging.
    >now possible.
    >Anyone know of a source of 1 farad caps at a least 12v or more. Don't
    >search just point me in the right
    >direction.
    >Thanks
    >Fred
    Hi Fred -
    As far as I've seen, the highest rated Super-Capacitors have a voltage
    rating of
    4 to 5 volts. Some are even less than that. That will be the limitation.
    Bruce
    edited 2003-06-01 20:07
    You can buy 1F or 0.5F 12V capacitors from Best Buy or anywhere else
    that sells car audio supplies. They will run you about $80-$120.
    Incedently, you made a mistake in your calculations. You assumed
    (probably justifiably) that the basicstamp will draw current at a
    constant rate and then used this rate to estimate its "resistance."
    However, a resistor discharging a capacitor does not draw current at
    a constant rate. As the voltage across the capacitor drops, so does
    the voltage across the resistor -- using V=iR we can see that the
    current through the resistor is falling off linarly. Here's what you
    should have done:
    The basic stamp will draw 100mA for sixty seconds.
    An Ampre is a Coulumb/sec so you need to use 60s * 100mA = 60s *
    100mC/s = 6 C of charge.
    Afterwards you still need 5 volts on your capacitor. Using the
    following formula:
    C = q1/V1 = q2/V2
    (q2+6C)/12v = q2/5V
    q2 = 4.3C
    Thus C = q2/V2 = 4.3C/5V = .85F
    So you should really get a 1 Farad capacitor. And that assumes that
    your basic stamp doesn't draw any current while it's resting.
    watering project.
    someone suggested the project can easily be done
    challenge to do it with
    collector (12v at 125 ma max).
    think. I bet this will get some responses!
    1 sec
    ohm resistor
    or discharge 63% in the first time constant.
    panel in one time constant it will discharge to
    before then.
    > One possibility:
    caps are now possible.
    Don't search just point me in the right
    > direction.
    > Thanks
    > Fred
    edited 2003-06-01 20:26
    Just gang 'em up in a series/parallel configuration. I have a 12V (actually
    15V) bank as a backup on a project.
    Jonathan
    www.madlabs.info
    > rating of
    > Bruce
    edited 2003-06-01 20:32
    www.allelectronics.com under 'super' capacitors. $1.00 each, if you buy 10
    or more only 85 cents each. I use these in combination with a solar engine
    to power little robots.
    Ryan
    > search just point me in the right direction.
    edited 2003-06-01 22:44
    Most solar stuff that runs motors or valves uses storage batteries. Caps
    would work fine to run a processor, but anything more would be a real
    headache. Besides, most cheap, large value caps will not hold a charge a
    long time compared to the supercaps.
    10
    engine
    edited 2003-06-02 00:31
    Hi Fred,
    I have never done this with a cap, but you have to think of the power
    consumed by the solenoid. If you leave it energized all the time the water is to
    be
    on, then the charge will not last very long. If you use a pulse type solenoid
    (I think I saw someone suggest this), you have to worry about not having enough
    of a charge to shut the water off again. What will happen when the water runs
    all day, and through the solar drought that happens every day? Will it just
    be a few soggy tomato plants, will you need to get a second mortgage to pay the
    water bill, or will people call you looking for Noah?
    If you use the solar approach then you may need a backup power supply to
    prevent any H2O distress.
    Alan Bradford
    Plasma Technologies
    edited 2003-06-02 05:47
    Hello,
    I found the following link a while ago:
    http://www.lls.se/~mux/micro/pdf/bs1apps.pdf
    This PDF has a ton of BS1 circuits. Including a solar powered BS1 on page 147.
    Wow, no that I look at it again, it looks like this PDF is a portion of the
    Parallax Basic Stamp Manual 1.2.
    Chuck Chargin Jr.
    >project.
    >to do it with
    > resistor
    >One possibility:
    >now possible.
    >direction.
    >Thanks
    >Fred
    edited 2003-06-02 08:31
    Hi Fred,
    Just curious... any particular reason you want to use a capacitor instead of
    a battery? I realize you were given a challenge, and I understand the solar
    part of it (I have a couple 75W panels here). The capacitor part of it
    seems like a round peg in a square hole, though... A battery could store
    much more energy and would be less expensive.
    Rather than a solenoid, how about a valve operated by a small motor and gear
    train. It would only require power during the short time it was opening or
    closing. You could mount switches or a position sensor to confirm that the
    valve mechanism was truly moving to the fully open and fully closed
    positions. The extra energy stored by the battery would be useful to sound
    an alarm in the event that the valve did not close properly when commanded
    to do so.
    Randy
    www.glitchbuster.com
    Sent: Sunday, June 01, 2003 11:07 AM
    project.
    to do it with
    resistor
    then.
    > One possibility:
    now possible.
    > direction.
    > Thanks
    > Fred
    edited 2003-06-02 15:16
    One thing you must consider when using the 'supercaps' is that you must
    control the current when charging them. Excess current on charge can cause
    internal damage and some of the caps must also be limited on discharge. A
    short will burn out some of them because the internal resistance is so low.
    Jim
    From: Rodent [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nJE9hWJoDLvjMNcafwFBeCBStrm-b6ovBoErfRUHaUTDfX3xOjGEvVKVn-ZyDoEeyFxaNbyN2aYVDaO22TQ]daweasel@s...[/url
    Sent: Sunday, June 01, 2003 5:44 PM
    Subject: Re: [noparse][[/noparse]basicstamps] Garden Project
    10
    engine
    edited 2003-06-02 18:30
    Randy
    You are right it is more practical to charge a battery or just use electricity
    from the house. Do you have any
    tips on charging a battery with the solar panel and a source for the battery?
    There are some cheap portable drill
    batteries at the local hardware store. I was thinking of hacking one of them.
    As I think about this Garden Project I think everyone needs a "House stamp"
    around to take care of business.
    Water the garden, check indoor and outdoor temperature, check for water in the
    basement (my sump pump has failed
    twice in about 5 years), control x-10 devices, etc, etc.
    Thanks for all the help.
    Fred
    Randy Jones wrote:
    > Hi Fred,
    > to do so.
    > Randy
    > From: "fred payne" <fpayne@c...>
    > project.
    > to do it with
    > resistor
    > then.
    > > One possibility:
    > now possible.
    > > direction.
    > > Thanks
    > > Fred
    edited 2003-06-02 23:20
    you might checkout one of the jump start units they
    are based on 12 gel cell battery and all ready have
    charge controler all you have to do is feed it 12 to
    15v a few hunder milliamps to charge it good luck
    --- fred payne <fpayne@c...> wrote:
    > Randy
    > battery or just use electricity from the house. Do
    > you have any
    > a source for the battery? There are some cheap
    > portable drill
    > everyone needs a "House stamp" around to take care
    > of business.
    > temperature, check for water in the basement (my
    > etc.
    > Fred
    > Randy Jones wrote:
    > > Hi Fred,
    > and fully closed
    > > to do so.
    > > Randy
    > > project.
    > collector.
    > > to do it with
    > Coulomb/volt
    > farads)
    > considered charged.
    > > resistor
    > constant.
    > > then.
    > > > One possibility:
    > one minute.
    > > now possible.
    > > > direction.
    > > > Thanks
    > > > Fred
    > ignored.
    > ignored.
    Do you Yahoo!?
    edited 2003-06-03 09:28
    Fred,
    Well... there are probably contributors on this list who have forgotten more
    about battery systems than I know ;-) But I'll take a shot at it...
    Before deciding on a battery, I would want to know how much voltage and
    current the water valves, etc. would require. For example, would you
    perhaps need 12 VDC to operate the water valves? Or possibly 6 VDC? I'll
    assume 12 volts, since it might be a good match for your solar panel.
    I'm thinking about a small 12 V lead/acid gel battery, which isn't very
    expensive (especially compared to monster capacitors). Is your solar panel
    possibly one of the units designed to maintain the charge of an automotive
    battery? The specs made me think that might be the case. Any idea what the
    maximum voltage output of the panel is under maximum sun with no current
    output? You might be able to connect it directly to a 12 volt lead acid
    battery depending on the panel's max output and the battery.
    I'm trying to remember the "rule of thumb" about how much output per day you
    could reasonably expect from your solar panel. It depends on the weather,
    season, and geographical location, of course. I seem to remember something
    about using four hours of output in maximum sunlight as an approximation of
    what you'd get from an entire day. I think that was assuming the panel was
    in a fixed position (not tracking the sun), but don't remember any
    assumptions associated with season or geographic location. What if we
    assumed the equivalent of two hours of full output per day. That seems
    pretty conservative. I think you said your panel could do 125 mA at 12V, so
    that would be...say, 250 mA hour at 12 volts. It would be good for the
    battery to have enough capacity to hold several days worth of charge -- just
    in case the earth stopped rotating for a while and we were on the dark
    side... or something.
    How about a battery with 1 A hour (1000 mA hour)? Heck, you could even use
    the nicad RC car battery cells for this... If I remember right, the "sub C"
    cells were good for 1.7 A hour (1700 mA hour). This goes back about 10
    years, and I'm not real confident about it. ,,,Okay, just googled the RC
    battery packs and they are showing 3000 mA hr NiMH -- so 1700 mA hr (or
    more) nicads sounds about right.
    With a battery of nicad cells you would probably need some kind of charging
    regulation. If you didn't need to efficiently capture a large percentage of
    the solar panel's output, it might be okay to just use a series resistor to
    limit the charge to a trickle rate which could continue indefinitely without
    battery damage. If you needed to more efficiently capture the panel's
    output, you could connect a pass transistor in parallel with the trickle
    charge resistance, and turn it on when the battery voltage is below a
    certain level (using perhaps a comparator and voltage reference).
    An inexpensive microcontroller with A/D could make a nice charge controller.
    I attended a Microchip PIC seminar today where they were demoing some of the
    new PICs with their "nanoWatt" technology (very low power operation)... They
    showed one of the 18-pin parts reading a temperature sensor with the
    built-in A/D and running a LCD display showing the reading... from the power
    generated by a grapefruit cell. The new 18-pin 16F819 (under $3) has this
    very low power technology, and is presently one of the more popular PICs
    selling on eBay. It wouldn't be too busy with the charge regulation...
    might as well make it read the moisture sensors and control the water valves
    too!
    Pinning down the energy requirements of the water valves would be a good
    first step before putting too much effort into battery selection. Any plans
    or thoughts yet in that department?
    Randy
    Sent: Monday, June 02, 2003 10:30 AM
    > Randy
    electricity from the house. Do you have any
    battery? There are some cheap portable drill
    them.
    stamp" around to take care of business.
    the basement (my sump pump has failed
    > Fred
    > Randy Jones wrote:
    > > Hi Fred,
    instead of
    solar
    store
    gear
    the
    sound
    commanded
    > > to do so.
    > > Randy
    > > project.
    challenge
    > > to do it with
    I
    sec
    ohm
    > > resistor
    in
    > > then.
    > > > One possibility:
    are
    > > now possible.
    > > > direction.
    > > > Thanks
    > > > Fred
    and
    Neat that on rainy days you don't need to water so you don't need to
    factor in 5 extra days of charge due to cloud cover.
    good
    Any plans
