SERIN / SEROUT - Newbie Question
I've looked thru a multitude of these posts for a solution to the
following dilemma :
Trying to test some simple code with a BS2, PBasic Editor v1.33, the
BOE carrier board and a standard serial connector cable into my PC
'{$STAMP BS2}
SEROUT 16, 16780, [noparse][[/noparse]65]
I've downloaded RealTerm for emulation. If I open RealTerm and then
try running the above source code with my Editor, I get the following
error message from the PBasic editor --> No BASIC Stamps found!
The download status dialogue in the Editor also displays the
following message --> COM1: can't open port; in use
Can anyone estimate what I'm doing wrong?
Thanks.
Shaun K
following dilemma :
'{$STAMP BS2}
Thanks.
Shaun K
Every time I have received a message like that (and it's been many
times) I realize that I had forgotten to plug the power into the Stamp
Development Board.
> following dilemma :
> '{$STAMP BS2}
> Thanks.
> Shaun K
> from the same email address that you subscribed. Text in the Subject
> and Body of the message will be ignored.
When you open RealTerm, it's grabbing Com1. Then, when you try to
open the Editor, IT tries to grab Com1, only RealTerm has it, so it
fails to grab it.
What you probably want to do is:
MainLoop:
SEROUT 16, 16780, [noparse][[/noparse]"Hi", 13] ' ,13 is CR
GOTO MainLoop
END
Once you've downloaded to the Stamp, you don't need the editor any
more. Actually, you can open a 'debug window' in the Editor, which
does the same thing RealTerm would do, and doesn't make the Editor
complain.
Having said that, if you program the stamp as above, you can then
shut down the Editor, start up RealTerm, and run it. RealTerm should
get the data.
--- In basicstamps@yahoogroups.com, "therealcadzilla" <cad-
> following dilemma :
the
> '{$STAMP BS2}
following
> Thanks.
> Shaun K
inserted an additional PAUSE 1000 statement for a more tactile
response (timing of status indicators)I would have to ask the next
question regarding the capture of this SEROUT data into some usable
format. Really what I'm asking is would some applications (i.e.
Visual Basic, etc . . .) be preferrable over others for gathering
this information for further use upstream?
Thanks Again!
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> Yup, been there, done that.
> fails to grab it.
> MainLoop:
> GOTO MainLoop
> END
> complain.
should
> get the data.
> > following dilemma :
> the
> > '{$STAMP BS2}
then
> following
> > Thanks.
> > Shaun K
