help needed with Basic Stamp
hey I need help with my basic stamp project
I HAVE TO MEASURE THE rpm OF A ROTATING MEMBER /ROLLING MEMBER
THEN PROCESS THAT RPM WITH A BASIC STAMP AND USE IT TO DRIVE A
STEPPER MOTOR AT CERTAIN RATIO TO TO rpm OF THE ROLLING MEMBER
PLEASE ADVISE WHAT KIND OF SHAFT ENCODER I SHOULD USE !!!
I HAVE A PARALLAX NX-1000 BOARD WITH BS2P24 BASIC STAMP
PLEASE HELP
PLEASE HELP
connection available to the rotating part you are measuring. You can use
the count command on the stamp and count the number of pulses from the
encoder to get the RPM. The math for the conversion can then be done on the
stamp and I would use an external stepper motor driver running off the
commanded speed of the Stamp. You can run the stepping of the motor from
the stamp but depending on the speed needed and the RPM of the controlling
member you may not be able to get a smooth enough response. More details
would help.
Larry G. Nelson Sr.
>PLEASE HELP
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
hey i have got a Iwatsu optical encoder with a resolution of 200 cycles per
revolution , for past one week i have beeb trying to write a code for driving
stepper motor with input from this encoder but unsucessfully
as i have a NX-1000 board
can someone suggest me some webpage/publication where there is better
description of how stepper motors work and some example codes for a similar
thing what i'm trying to achieve
jimmy
"Larry G. Nelson Sr" <larrysr@m...> wrote:
There are many options. Some of this is dependant on the mechanical
would help.
Larry G. Nelson Sr.
>PLEASE HELP
from the same email address that you subscribed. Text in the Subject and Body of
SMS using the Yahoo! Messenger;Download latest version.
encoders. Try the Nut and Volts site, under downloads, nuts and volts
From: jimmy singh [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=5N8d_yGpnq9LiPjZQkS0zjt1gto-1g3flYY6-LVifgRRkdR2RgT077gYb6QLOGIkSAOJesanD5ht6uWNGKiCfQ]jimmy22502001@y...[/url
Sent: Monday, June 30, 2003 12:08 PM
Cc: larrysr@m...
Subject: Re: [noparse][[/noparse]basicstamps] help needed with Basic Stamp
Hi ,
per revolution , for past one week i have beeb trying to write a code for
driving stepper motor with input from this encoder but unsucessfully
jimmy
would help.
Larry G. Nelson Sr.
>PLEASE HELP
