hex code!
Am wondering if these two statements r the same
serout 16,16468 [noparse][[/noparse]hex 12]
serout 16,16468,[noparse][[/noparse]$c]
Thanks in anticipation
Sumana Garikipati
Sumana Garikipati
12. Keep in mind that the serial formatters DEC, HEX, and BIN (as well as the
"I" and "S" versions) are numeric-to-string (character) convertors.
-- Jon Williams
-- Parallax
In a message dated 5/28/2003 1:57:24 PM Central Standard Time,
sumanagarikipati@y... writes:
> Sumana Garikipati
Thanks for the reply.So how do I send the hex numbers
then??.For example to reset a bluetooth Module I need to send
a set of hex commands eg: reset : 01 03 0c 00 total of 4 bytes.
which one shd I use?? $ or hex???
Sumana Garikipati
--- In basicstamps@yahoogroups.com, jonwms@a... wrote:
> No. The first sends the character "C" (ASCII 67). The second
sends ASCII
well as the
> -- Jon Williams
> -- Parallax
> > Sumana Garikipati
sends ASCII
well as the
> -- Jon Williams
> -- Parallax
> > Sumana Garikipati
perform a numeric to string (text) conversion.
Try this is your editor:
value VAR Byte
Main:
value = 12
DEBUG DEC value, CR
DEBUG HEX value
Note that the DEBUG screen requires conversion to text format -- unless
you're sending a specific control character.
-- Jon Williams
-- Parallax
In a message dated 5/29/2003 10:07:02 AM Central Standard Time,
porter.sadler@s... writes:
> Jon, Ok I'm thick. Why does the first one give the character "C".
> sends ASCII
> well as the
> >-- Jon Williams
> >-- Parallax
> >>Sumana Garikipati
serout 16,16468,[noparse][[/noparse]$01,$03,$0c,$00]
will send the reset sequence. The following specifies the same
numbers in either decimal or binary:
serout 16,16468,[noparse][[/noparse]1,3,12,0] ' numbers written as decimal
serout 16,16468,[noparse][[/noparse]%1,%11,%1100,%0] ' written as binary
The numbers sent by SEROUT are the same in all three forms. It is
just the notation that is different.
No, as Jon said (and someone else questioned) the first one sends out
the ascii character "c", because the number 12 in decimal (=$c in
hex, =%1100 in binary) is converted to a string (ascii 67 = "c") by
the HEX modifier. So on a display screen you see the letter "c".
The second form, sending just $c with no modifier sends the actual
value, $c in hex, which is the same as the binary %1100, which is
"12" in decimal. If you send that to a display screen, you might see
a funny character, or maybe your screen would go blank, because, in
ascii, 12 is a control character that usually means "form feed".
-- Tracy
>Sir,
>Sumana Garikipati
>sends ASCII
>well as the
>> -- Jon Williams
>> -- Parallax
>> > Sumana Garikipati
>Subject and Body of the message will be ignored.
