closed loop control using basic stamp - DIN controller
Actually, a simple PID controller would be more than enough.
http://www.alphacontrols.com/Fuji/Fuji_PXZ4_Fuzzy_Logic_Controller.htm
l
This is only one vendor, there are litteraly hundreds of these styles
and they come in various styles of outputs. and dozens of
manufacturers.
check you local listings, and possibly E-bay.
the nice thing is that the PID is on-board and pre-programmed and the
units have a display. all for usually under $200.00.
another nice thing is that the newer ones will self tune ! they will
upset the system and then self load the values so that it will self
determine the P and the I and the D for your exact system.
You can do the same thing with a Stamp, but in this case, it seems
the user in interested more in getting control than the hobby of
using the Stamp.
Dave
--- In basicstamps@yahoogroups.com, AMG AMG <controlsdude2000@j...>
wrote:
> I don't really think you need a PC and VB. Based on your
description,
> the stamp should have all the "brains" you require.
> I will do some looking thru some info at work... might have
something on
> a servo operated valve. I know I have something on a motor
actuated ball
> valve. What are the flow requirements, medium, temperature, etc.
etc?
> On Mon, 26 May 2003 06:59:47 -0000 "cskjdk" <jkostura@s...>
> writes:
> > I need an inexpensive way to automatically control the pressure
> > within a vacuum chamber. Process gas is introduced into the
chamber
> > and the pressure is controlled by adjusting a "throttle" valve
> > between the chamber and the vacuum pump (currently done by hand
with
> > reference to the pressure guage). The guage has a 0-5V linear
output
> > which I monitor with a DVM. I would like to use a pc and Visual
> > Basic to provide the brains but don't know where to go from there.
> Stepper
> > motor to actuate the valve?, motor controller required?,other
> > hardware needed?
> ________________________________________________________________
> The best thing to hit the internet in years - Juno SpeedBand!
> Surf the web up to FIVE TIMES FASTER!
> Only $14.95/ month - visit www.juno.com to sign up today!
l
manufacturers.
using the Stamp.
Dave
description,
something on
actuated ball
etc?
> writes:
chamber
with
output
> Stepper
> > hardware needed?
