2 P 40 Heat
Hello Stampers,
I am using the 2 P 40 in my latest project. What I want to know is, if it
may get a little warm while working. I am using 20 input pins, each pulled
down via 10K and connected via 22K to a 12V-signal. That makes about 3.5V at
each input.
Is that OK and is it normal that the 2 P 40 gets a little warm?
Thanks for help,
Uli
each input.
Thanks for help,
Uli
ulibasic@r... writes:
> Thanks for help,
> Uli
have not used the 2 P 40 before but.....if you can keep your finger on it for
and extended period of time, you are likely ok....if it burns your finger,
likely something is amuck.
while in operation, so I suppose a certain degree of heat is normal.
Sent: Wednesday, May 28, 2003 3:49 PM
Subject: [noparse][[/noparse]basicstamps] 2 P 40 Heat
> Hello Stampers,
at
> each input.
> Thanks for help,
> Uli
I assume you are doing input only, as you
certainly can't DRIVE a 12-volt signal.
Is your 12-volt signal referenced to the same
ground as your stamp?
For input only, the stamp shouldn't be pulling
any kind of current from its input pins, which
would be the source of heat -- on input, the
pins look like a high-impedance.
What are your other pins driving? That could
be the source of heat.
The big possiblity is that your Stamp ground
and your signal ground are not connected, and
you may have more than the 3.5 volts at each
input pin than you think. If it's over 5V,
this would not be good.
--- In basicstamps@yahoogroups.com, "ulibasic" <ulibasic@r...> wrote:
> Hello Stampers,
if it
pulled
about 3.5V at
> each input.
> Thanks for help,
> Uli
I have a BS2p24 and my program had a loop where I was waiting for input. I
replaced a pause 100 with nap 3 in the loop and it cooled down the stamp by
about 5 degrees celsius! Using nap my stamp is usually only 2 degrees C
above ambient. But I am not sourcing or sinking a lot of current either.
If your application and devices can tolerate the wake up I/O interruption
from nap it might cool your stamp down a bit.
Chuck Chargin Jr.
At 09:49 AM 5/28/2003 +0200, you wrote:
>Hello Stampers,
>each input.
>Thanks for help,
>Uli
