Joystick type switch?
Anyone have any idea what one is called?
The type of switch I'm talking about is like a mini joystick. It operates
all 4 directions, and can be pushed in for a 5th set of contacts. I hope
I'm explaining it clearly.
I searched Digikey, but seeing as they have 50,000 switches, and I don't
know what they are called, I didn't do very well [noparse]:)[/noparse]
Thanks in advance,
-John
Thanks in advance,
-John
>Thanks in advance,
>-John
Hi JOhn -
Here is one surplus source here, from C and H Sales:
<http://www.aaaim.com/cgi-local/shop991/shop.pl/SID=63017657168/page=MISC.htm#JS\
9850>
(cut and paste link if necessary)
Scan down that page for item number JS9850 for a two axis joystick
potentiometer
setup. It has no fifth push-down position however. Beware of the minimum
billing requirements as the switch is only $ 5.00US as you will see.
Bruce Bates
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
one of the companies that sells arcade game parts.
http://www.twobits.com/parts/
> You can make your own, find an old Commodore 64 joystick, or you might try
operates
hope
by www.didel.com
specifically at the bottom of this page:
http://www.didel.com/Frames.html?MainFrame=microkit/
But you might have to work your way down into the microkit page section.
From: John Walton [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rvempDZlEOJ_lgHSgh21ywKHBUpR-ADm43hlH73DqmKqQquPf6gvovx67XGNdQzvztb8Jm41Vs5-RhU]john@l...[/url
Sent: Monday, May 26, 2003 11:35 PM
Subject: [noparse][[/noparse]basicstamps] Joystick type switch?
Thanks in advance,
-John
>The closest thing that I know of in a "mini-joystick" is the one being sold
>by www.didel.com
Earl -
Here is the 2-axis miniature Noble Joystick they are using:
http://www.nobleusa.com/fp_joystick.html
A PDF file is also available on that page. Nice unit !
Bruce
>Thanks in advance,
>-John
John -
After more searching it look like this may be the unit about which you are
speaking:
http://www.varatouch.com/press.html
Bruce
http://www.happcontrols.com/
operates
I hope
don't
> Thanks in advance,
> -John
The xvl series is available with the center tap and they are cheap. I can't
remember where I purchased them, but you can call them and they will point
you to a retailer.
JM
From: John Walton [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=YQa6plp5EVQ3XcYyDRVJVkbuvhVwnPLlGjrpuU92ji29L7qZLWUMmvH3-5lMGmpdNOQo4c_Y8nsw]john@l...[/url
Sent: Tuesday, May 27, 2003 12:35 AM
Thanks in advance,
-John
