ADC interface
Archiver
I'd like to interface a total of 4 11-channel ADC's from TI to my BS2p
serially, but in order to conserve I/O space on the micon i was wondering if
i could simply run all four ADC's I/O clock pins to a single pin on the
micon. Since i will only be using one ADC at once, couldn't i also tie all
the DATA IN pins to a single pin on the micon and likewise with the DATA
OUT? If i do this, do i have to provide any buffering on the individual
ADC's?
Christian
_________________________________________________________________
MSN 8 with e-mail virus protection service: 2 months FREE*
http://join.msn.com/?page=features/virus
ADC's?
Christian
cwentz86@h... writes:
> ADC's?
Are you using TLC2543's?
Sid
>From: Newzed@a...
>Reply-To: basicstamps@yahoogroups.com
>Subject: Re: [noparse][[/noparse]basicstamps] ADC interface
>Date: Sun, 25 May 2003 20:15:22 EDT
>In a message dated 5/25/2003 6:53:18 PM Eastern Daylight Time,
>wondering if
>all
> > ADC's?
>Sid
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Help STOP SPAM with the new MSN 8 and get 2 months FREE*
http://join.msn.com/?page=features/junkmail
> i'm using TLV2553's
I have done what you want to do with shift registers but not ADCs. My guess
is that the best approach would be to keep the clock lines separate and
parallel all the others. I would also put a 1K resistor in each clock, datain,
dataout and chip select line just in case.
Sid
Connect ADC inputs and outputs to a single IO line (each output
through a resistor, e.g. 1k). Connect all ADC clocks to a common
clock line. Connect each ADC Chip Select (CS) individually to the
one of the other IO pins of the stamp. Disable all CS at startup
and enable one to access a specific ADC.
My be the Chip Select line is named differently on your ADC but
it serves the same purpose
Regards
Adrian
One other suggestion: if you really want to conserve I/O lines, you
could control those four -CS lines using just three data lines with
the 74259 addressable latch (a demux. with a latchable data bit).
Run those three lines to A (aka - A0), B (A1), and D (Data), ground
C (A2)*, tie the four -CS lines to Q0 - Q3. That'll give you four
usable outputs which you can address using A,B and then
enable/disable with the latched data bit.
http://www.fairchildsemi.com/ds/DM/DM74LS259.pdf
*Note: you could control 8 A/D's with the addition of just one more
address line!
--- In basicstamps@yahoogroups.com, "Christian Wentz"
BS2p
wondering if
on the
also tie all
the DATA
individual
> ADC's?
> Thanks,
> Christian
