SHTX humidity/temp sensor
Hey,
Has anyone messed around with the SHTX sensor from Parallax? I am
looking to buy one, but would like to hear any war stories about the
device before I buy.
Walter
Walter
>Hey,
>Thanks,
>Walter
Hi Walter -
Here is the experience of one Stamp user who uses it in a commercial
application:
http://www.emesystems.com/OL2sht1x.htm
Bruce Bates
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
I got one to work, so it can't be too hard. I used the code at Tracy's site.
You can get a free sample, but you have to then mount it on something
yourself. I have had one running for a few months now no problems. But time
will tell if it is able to withstand the real world.
Jonathan
www.madlabs.info
Sent: Friday, May 23, 2003 9:03 PM
Subject: [noparse][[/noparse]basicstamps] SHTX humidity/temp sensor
> Hey,
> Thanks,
> Walter
But, sounds easy enough. Thanks for the link.
--- In basicstamps@yahoogroups.com, "Jonathan Peakall"
<jpeakall@m...> wrote:
> Walter,
Tracy's site.
something
But time
> Jonathan
> www.madlabs.info
> From: "walter woodrow" <oopicwow@y...>
> > Hey,
the
> > Thanks,
> > Walter
Subject and
While I have never used the SHTX sensor, I tried a sensor from an obsolete
RS80 Radiosonde which has a module for sensing barometric pressure, relative
humidity and temperature. The T and R.H. sensors respond quickly (i.e.
stabilize within seconds) and the P sensor track very well the changes in
barometric pressure. The only trick is that the sensor produces an audio
output signal with 6 tones corresponding to High and Low references,
T-board, T-ambient and Relative Humidity. I use the basic stamp to decode
the frequency of the output tones and then calculate the values with the
coefficients supplied with the radio sonde.
I paid about $4US the sonde on Ebay. For me most of the fun was figuring out
how to decode the information.
I can send you more information if you are interested
Don
>Reply-To: basicstamps@yahoogroups.com
>Date: Sat, 24 May 2003 04:03:48 -0000
>Hey,
>Thanks,
>Walter
_________________________________________________________________
Help STOP SPAM with the new MSN 8 and get 2 months FREE*
http://join.msn.com/?page=features/junkmail
I will give the SHTX sensor a try first (already have it on order).
I am also looking for a soil moisture sensor. I found on the
Internet where I could use a 555 timer and a special etched PCB. I
also found a vendor called irrometer.com that sells what they call a
watermark sensor. It may have the same type of output as your
radiosonde, but still waiting for them to email the detail. Does the
equipment you have measure soil moisture?
Thanks again,
Walter
--- In basicstamps@yahoogroups.com, "Donald Desaulniers"
<donald_desaulniers@h...> wrote:
> Walter,
obsolete
relative
(i.e.
changes in
audio
references,
decode
with the
figuring out
> Don
> >Hey,
the
> >Thanks,
> >Walter
Subject and
Radiosondes are usually on balloons, so they are not in a position to
measure soil moisture! (unless done via infrared remote sensing).
The Watermark sensor has an AC resistance that changes in response to
moisture content of the surrounding soil.
http://www.emesystems.com/smx.htm
I have it for sale as a waterproof sealed module, and the circuit is
given there too if you want to try to roll your own.
With regard the the SHTxx, I've used lots of them with very good and
consistent results. Like all absorption hygrometers, they do have
problems at the high end of the range, if they are kept for long
periods (days at a time) at 100%RH.
-- Tracy
Walter
a
the
to
to
is
and
> -- Tracy
> > Walter,
> obsolete
> relative
> (i.e.
> changes in
> audio
> references,
> decode
> with the
> figuring out
Please send me more information. I launch my own radiosondes
but would like info on the NWS ones.
Thanks.
Paul Verhage
I do not want to clutter this discussion group with non BS info.
Please send me you email so that I may send you the info I have on the RS80
Radiosonde.
>From: <verhap@o...>
>Subject: Re: [noparse][[/noparse]basicstamps] Re: SHTX humidity/temp sensor
>Date: Mon, 26 May 2003 13:56:36 -700
> > > Walter,
> > obsolete
> > relative
> > (i.e.
> > changes in
> > audio
> > references,
> > decode
> > with the
> > figuring out
>Thanks.
>Paul Verhage
Add photos to your e-mail with MSN 8. Get 2 months FREE*.
http://join.msn.com/?page=features/featuredemail
