Serial RAM
At 07:24 AM 5/23/03 +0000, cchargin wrote:
>Hello all,
>I have been searching the net for serial RAM to use with the stamp (i
>have a BS2p24). The only offerings I can find are the Rampack B and a
>256 byte I2C chip from Philips.
>I have the Rampack B, but even running it at 19.2 (both the Rampack
>and the stamp recommend against 19.2) it is slow compared to
>read/write from an I2C eeprom.
>Even though I may never hit the 1 million write mark on an eeprom, I
>would prefer using external RAM for the frequently changing data in my
>project.
>Does anyone know of any 4 KB or larger serial RAM?
>As a side project I am going to see if I can interface a SRAM chip to
>the stamp using I2C IO expanders. Has anyone tried this already?
>Thanks in advance for suggestions and comments.
>Chuck Chargin Jr.
Chuck -
You may want to look at the ferro-electronic (FRAM) memory from Ramtron here:
http://www.ramtron.com/products/producthome.htm
As you will note 10 BILLION read/write cycles, 10 year data retention, and
"no wait" writes. Serial configurations and memory from 4K to 256K are
available. It appears samples are available.
Hope that helps.
Bruce Bates
>Hello all,
>project.
>Chuck Chargin Jr.
Chuck -
Hope that helps.
Bruce Bates
project.
Chuck Chargin Jr.
http://www.mouser.com/index.cfm?handler=listproduct&&categoryid=95&lst_pcode
=5790
Sent: Friday, May 23, 2003 2:24 AM
Subject: [noparse][[/noparse]basicstamps] Serial RAM
> Hello all,
> project.
> Chuck Chargin Jr.
(SRAM has infinite read/write cycles, but it
all goes away on power-off. EEPROM has a
fixed number of read/write cycles, but does
not go away on power off)
--- In basicstamps@yahoogroups.com, "Ricky Konvicka" <rkonvicka@h...>
wrote:
> Mouser has a bunch of ram of the I2c variety. Here is a few.
> =5790
> From: "cchargin" <cchargin@e...>
> > Hello all,
stamp (i
and a
Rampack
eeprom, I
in my
> > project.
chip to
> > Chuck Chargin Jr.
Subject and
bus. It is a 64k EEPROM.
I have PIC bacic pro code that should work with the stamp with a few
minor changes if you need it.
Jason
--- In basicstamps@yahoogroups.com, "Allan Lane" <allan.lane@h...>
wrote:
> SRAM! The page you called out is all EEPROM.
<rkonvicka@h...>
> > =5790
> > > Hello all,
> stamp (i
B
> and a
> Rampack
> eeprom, I
data
> in my
> > > project.
> chip to
already?
> > > Chuck Chargin Jr.
> Subject and
I have looked into FRAM, but I can not find any place that will sell 1 or 2
chips, they all want me to buy a whole rail (I think it was 30 chips!) or I
have to buy a minimum of $50 from them (and they don't have any other cool
stuff to buy).
Anyone seen FRAM on a site that caters to hobbyists?
Ramtrons data sheet states that you would have to access the FRAM 30 times
a second for 10 years before it would wear out (the 32 KB chip). I guess I
could live with that. However, it still bothers me that the sun will burn
out in about 5 billion years. [noparse]:)[/noparse]
Chuck Chargin Jr.
> >Hello all,
> >project.
> >Chuck Chargin Jr.
>Chuck -
>Hope that helps.
>Regards,
>Bruce Bates
>Thanks for the reply,
>stuff to buy).
You might want to check with Future/Active as they appear to be willing
to sell the FM24C256 in quantities of one of $ 9.50US each.
<http://www1.future-active.com/Comergent/en/US/adirect/future?cmd=OnlineOrdering\
PageDisplay>
Other than the FM25C256 larger quantities are required. Admittedly, this
may be a glitch in the Future/Active ordering system.
Alternative to that is asking for samples on the Ramtron web site as others
have done successfully before.
Bruce
