sonar module weatherproofing question
Hi Folks,
I'm working on an outdoor project that uses the Devantech module, and I need
some advice on outdoor protection. Has anyone come up with a good way to
protect the sensor from weather and vandals? Ideally, I'd put the sucker in
a
sealed box, but then I'd have other problems. I was thinking about a
plastic
film or wire mesh covering apertures in a sealed box, but I've got a feeling
that the sensor would keep seeing those.
Any ideas?
thanks,
d...
* David Okagaki dokagaki@w...
* "The light at the end of the tunnel is that of the on coming train!"
a
plastic
Any ideas?
thanks,
d...
We had ultrasonic condenser microphones outdoors for a bat study.
The microphone was mounted in a piece of PVC tube, facing downward
out the opening to protect it from rain. The tube was sealed at the
top of course. A piece of ceramic tile was mounted at 45 degrees
below the opening to serve as a reflector for sounds coming in from
the side. It worked quite well for that purpose.
-- Tracy
>Hi Folks,
>a
>plastic
>Any ideas?
>thanks,
>d...
something similar with one and it always reported a very short distance, not
the actual object distance. A larger tube may work though.
> -- Tracy
> >Hi Folks,
need
in
> >a
> >plastic
feeling
